stm8051F3獨立看門狗的使用源程序
jijiahui555
2019-5-13 16:12
stm8051F3獨立看門狗的使用,對初學者很實用。
#include "stm8l15x.h"//STM8L051/151等系列共用庫函數
//定義LED端口
#define LED1_PORT GPIOD
#define LED1_PINS GPIO_Pin_0
#define LED2_PORT GPIOC
#define LED2_PINS GPIO_Pin_4
#define LED3_PORT GPIOB
#define LED3_PINS GPIO_Pin_2
#define KEY1_PORT GPIOB
#define KEY1_PINS GPIO_Pin_1
#define KEY2_PORT GPIOA
#define KEY2_PINS GPIO_Pin_2
#define KEY3_PORT GPIOB
#define KEY3_PINS GPIO_Pin_3
#define RELOAD_VALUE 255
****入口參數:無
****出口參數:無
****函數備注:不精確延時函數
****版權信息:藍旗嵌入式系統
void Delay(__IO uint16_t nCount)
/* Decrement nCount value */
while (nCount != 0)
nCount--;
static void IWDG_Config(void)
//使能IWDG
IWDG_Enable();
//解除寫保護
IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
//LSI驅動IWDG,LSI 256分頻=38000/256
IWDG_SetPrescaler(IWDG_Prescaler_256);
/* IWDG timeout = (RELOAD_VALUE + 1) * Prescaler / LSI
= (255 + 1) * 256 / 38 000
= 1723.63 ms */
IWDG_SetReload((uint8_t)RELOAD_VALUE);
/* Reload IWDG counter */
IWDG_ReloadCounter();
****函數說明:主函數
****入口參數:無
****出口參數:無
****函數備注: 主函數,軟件獨立看門狗
按鍵觸發中斷,中斷服務程序里面調用軟件中斷TRAP,TRAP里面是while(1),
這樣就不會喂狗,從而導致IWDG計數器計數到0,引發復位。復位后程序判斷
復位標志是不是IWDG引起的復位,如果是,則點亮LED。
void main(void)
CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_1);
GPIO_Init(LED1_PORT,LED1_PINS,GPIO_Mode_Out_PP_High_Slow);//初始化LED端口
GPIO_Init(KEY1_PORT, KEY1_PINS, GPIO_Mode_In_PU_IT);//初始化按鍵,上拉輸入,帶中斷
EXTI_DeInit (); //恢復中斷的所有設置
EXTI_SetPinSensitivity (EXTI_Pin_1,EXTI_Trigger_Falling);//外部中斷1,下降沿觸發,向量號9
enableInterrupts();//使能中斷
if(RST_GetFlagStatus(RST_FLAG_IWDGF) != RESET)//判斷IWDG復位有沒有發生
GPIO_ResetBits(LED1_PORT, LED1_PINS);//點亮LED
//清掉復位標志
RST_ClearFlag(RST_FLAG_IWDGF);
else //如果不是IWDG引起的復位
GPIO_SetBits(LED1_PORT, LED1_PINS);
//配置IWDG
IWDG_Config();
while (1)
IWDG_ReloadCounter(); //喂狗
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
stn8.IWDG-獨立看門狗.7z
(5.88 MB, 下載次數: 4)
2019-5-14 04:41 上傳
stm8051F3獨立看門狗
