標題: 零知開源分享-溫濕度模塊 SHT3X SHT30 SHT31 SHT35 [打印本頁]
作者: roc2    時間: 2019-5-10 11:45
1、說明
MCU:零知開源開發板
溫濕度模塊:SHT3X
開發工具:零知實驗室軟件開發工具
功能:測量環境的溫度和濕度信息
2、硬件連接
將模塊的SCL,SDA分別于零知標準板的 A5,A4, I2C接口連接即可。
3、核心代碼
  1. /**
  2. *        使用SHT3X 模塊測試溫濕度信息
  3. */
  4. #include "HTU3X.h"
  5. #define LED1        PA8
  6. //Create an instance of the object
  7. HTU3X myHumidity;
  8. void setup()
  9. {
  10.   Serial.begin(9600);
  11.   Serial.println("HTU21D Example!");
  12.         pinMode(LED1, OUTPUT);
  13.   myHumidity.begin();
  14. }
  15. void loop()
  16. {
  17.         digitalWrite(LED1, HIGH);
  18.         delay(500);
  19.         digitalWrite(LED1, LOW);
  20.
  21.   float humd, temp;
  22.   myHumidity.readTempAndHumi(&temp, &humd);
  23.   Serial.print("時間:");
  24.   Serial.print(millis());
  25.   Serial.print(" 溫度:");
  26.   Serial.print(temp, 1);
  27.   Serial.print(" °C");
  28.   Serial.print(" 濕度:");
  29.   Serial.print(humd, 1);
  30.   Serial.print("%");
  31.   Serial.println();
  32.   delay(1000);
  33. }
  1. /**
  2. *   file : HTU3X.cpp
  3. */
  5. HTU3X::HTU3X()
  6. {
  7.   //Set initial values for private vars
  8. }
  9. //Begin
  10. /*******************************************************************************************/
  11. //Start I2C communication
  12. void HTU3X::begin(SoftWire &wirePort)
  13. {
  14.   _i2cPort = &wirePort; //Grab which port the user wants us to use
  15.
  16.   _i2cPort->begin();
  17. }
  18. #define MAX_WAIT 100
  19. #define DELAY_INTERVAL 10
  20. #define MAX_COUNTER (MAX_WAIT/DELAY_INTERVAL)
  21. //read 2-byte value with CRC from the HTU3X
  22. byte HTU3X::readValue(uint16_t *res)
  23. {
  24.   byte msb, lsb, checksum;
  25.   msb = _i2cPort->read();
  26.   lsb = _i2cPort->read();
  27.   checksum = _i2cPort->read();
  28.   uint16_t rawValue = ((uint16_t) msb << 8) | (uint16_t) lsb;
  29.   if (checkCRC(rawValue, checksum) != 0)
  30.     return (ERROR_BAD_CRC); //Error out
  31.   *res = rawValue;
  32.   return true;
  33. }
  34. byte HTU3X::readTempAndHumi(float *temp, float *humi)
  35. {
  36.     //Request a humidity reading
  37.   _i2cPort->beginTransmission(HTU3X_ADDR);
  38.   uint16_t cmd = CMD_MEAS_CLOCKSTR_H;
  39.   _i2cPort->write(cmd>>8); //Measure value (prefer no hold!)
  40.   _i2cPort->write(cmd);
  41.   _i2cPort->endTransmission();
  42.
  43.   delay(500);
  44.   _i2cPort->requestFrom(HTU3X_ADDR,6);
  45.   uint16_t rawTemp, rawHumi;
  46.   readValue(&rawTemp);
  47.   readValue(&rawHumi);
  48.   _i2cPort->endTransmission();
  49.   *temp = 175.0f * (float)rawTemp / 65535.0f - 45.0f;
  50.   *humi = 100.0f * (float)rawHumi / 65535.0f;
  51. }
  52.
  53. #define SHIFTED_DIVISOR 0x988000 //This is the 0x0131 polynomial shifted to farthest left of three bytes
  54. byte HTU3X::checkCRC(uint16_t message_from_sensor, uint8_t check_value_from_sensor)
  55. {
  56.   uint8_t bit;
  57.   uint8_t crc = 0xFF;
  58.   uint8_t byteCtr;
  59.    uint8_t data[2] = {message_from_sensor>>8, (uint8_t)message_from_sensor};
  60.   for(byteCtr = 0; byteCtr < 2; byteCtr++)
  61.   {
  62.           crc ^= (data[byteCtr]);
  63.           for(bit = 8; bit > 0; --bit)
  64.           {
  65.                   if(crc & 0x80)
  66.                           crc = (crc << 1) ^ 0x131;
  67.                   else
  68.                           crc = (crc << 1);
  69.           }
  70.   }
  71.
  72.   if(crc != check_value_from_sensor)
  73.           return 1;
  74.   else
  75.           return 0;
  76. }
更多詳細資料可到零知官免費獲取。
