一個(gè)很不錯(cuò)的51單片機(jī)直流電機(jī)調(diào)速設(shè)計(jì),仿真程序都有
fsafa
時(shí)間:
2019-5-9 21:55
大家一起學(xué)習(xí)下。仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
(12.74 KB, 下載次數(shù): 58)
2019-5-10 03:46 上傳
單片機(jī)源程序如下:
#include <reg52.h>
* 定時(shí)器初值
#define T0HIGH 0xec
#define T0LOWW 0x8a
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
typedef bit BOOL;
* 單片機(jī)管腳定義
sbit KEY_ON_PIN = P3^4;
sbit KEY_INC_PIN = P3^5;
sbit KEY_DEC_PIN = P3^6;
sbit pwm1=P1^4;
sbit MOTO_LEFT = P2^4;
sbit MOTO_RIGHT = P2^5;
* 按鍵定義
#define KEY_NULL 0xff
#define KEY_LONG_PERIOD 25
#define KEY_CONTINUE_PERIOD 20
#define KEY_DOWN 0x80
#define KEY_CONTINUE 0x40
#define KEY_UP 0x20
#define KEY_STATE_INIT 0
#define KEY_STATE_WOBBLE 1
#define KEY_STATE_PRESS 2
#define KEY_STATE_LONG 3
#define KEY_STATE_CONTINUE 4
#define KEY_STATE_RELEASE 5
#define KEY_ON_VALUE 1
#define KEY_INC_VALUE 2
#define KEY_DEC_VALUE 3
#define KEY_ON (KEY_ON_VALUE | KEY_DOWN)
#define KEY_INC (KEY_INC_VALUE | KEY_DOWN)
#define KEY_INC_CON (KEY_INC_VALUE | KEY_CONTINUE)
#define KEY_DEC (KEY_DEC_VALUE | KEY_DOWN)
#define KEY_DEC_CON (KEY_DEC_VALUE | KEY_CONTINUE)
* 常量定義
#define true 1
#define false 0
#define MOTO_ON MOTO_LEFT = false;\
MOTO_RIGHT = true
#define MOTO_OFF MOTO_LEFT = true;\
MOTO_RIGHT = true
* 全局變量定義
code u8 DisCode[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90, 0x88};
u8 PWMpercent = 0;
u8 DisNum[4] = {0xa0, 0xa0, 0x00};
u8 DisPosition = 0;
u8 SecCount = 0;
u8 u10msNum = 0;
BOOL b10msEvent = false;
BOOL b100msEvent = false;
BOOL b1secEvent = false;
BOOL MotoStart = false;
BOOL MotoRun = false;
void Key_Prosess(void);
void Dynamic_Display(void);
void Speed_Display(void);
* 主函數(shù)
main()
TMOD = 0x01;
TH0 = T0HIGH;
TL0 = T0LOWW;
TR0 = 1;
ET0 = 1;
EA = 1;
P1 = 0x13;
if(true == b10msEvent) //10毫秒定時(shí)標(biāo)志
b10msEvent = false;
Key_Prosess(); //按鍵掃描
Dynamic_Display(); //動(dòng)態(tài)顯示
if(true == MotoStart) //如果電機(jī)啟動(dòng)
if(true == MotoRun)
if(--u10msNum == 0) //如果電機(jī)轉(zhuǎn)動(dòng)時(shí)間到,停止電機(jī)
MotoRun = true;
MOTO_OFF;
if(true == b1secEvent) //PWM周期為1秒,1秒鐘時(shí)間到,開始下一個(gè)周期
b1secEvent = false;
MotoRun = true;
MOTO_ON;
u10msNum = PWMpercent;
* 清顯示
void Num_Clear(void)
u8 i;
for(i=0; i<3; i++)
DisNum[i] = 0xa0;
DisNum[4] = 0x00;
* 讀鍵值
u8 Key_Scan(void)
if(KEY_ON_PIN == false)
return KEY_ON_VALUE;
if(KEY_INC_PIN == false)
return KEY_INC_VALUE;
if(KEY_DEC_PIN == false)
return KEY_DEC_VALUE;
return KEY_NULL;
* 按鍵狀態(tài)掃描
u8 GetKey(void)
static u8 KeyState = KEY_STATE_INIT;
static u8 KeyTimeCount = 0;
static u8 LastKey = KEY_NULL; //保存按鍵釋放時(shí)候的鍵值
u8 KeyTemp = KEY_NULL ;
KeyTemp = Key_Scan();
switch(KeyState)
case KEY_STATE_INIT: //初始狀態(tài)
if(KEY_NULL != KeyTemp) //有鍵按下
KeyState = KEY_STATE_WOBBLE; //進(jìn)入消抖
break;
case KEY_STATE_WOBBLE: //消抖
KeyState = KEY_STATE_PRESS;
break;
case KEY_STATE_PRESS:
LastKey = KeyTemp; //保存鍵值,以便在釋放按鍵狀態(tài)返回鍵值
KeyTemp |= KEY_DOWN; //按鍵按下
KeyState = KEY_STATE_LONG;
break;
case KEY_STATE_LONG:
if(++KeyTimeCount >= KEY_LONG_PERIOD)
KeyTimeCount = 0;
KeyState = KEY_STATE_CONTINUE;
KeyState = KEY_STATE_RELEASE;
break;
case KEY_STATE_CONTINUE:
if(KEY_NULL != (KeyTemp))
if(++KeyTimeCount >= KEY_CONTINUE_PERIOD)
KeyTimeCount = 0;
KeyTemp |= KEY_CONTINUE; //連擊按鍵事件發(fā)生
break;
case KEY_STATE_RELEASE:
LastKey |= KEY_UP; //按鍵釋放
KeyTemp = LastKey;
break;
default:
break;
return KeyTemp;
* 按鍵功能處理
u8 KeyData;
KeyData = GetKey();
switch(KeyData)
case KEY_ON: //開關(guān)電機(jī)
MotoStart = false;
Num_Clear();
MOTO_OFF;
MotoRun = false;
PWMpercent= 0;
MotoStart = true;
MOTO_ON;
MotoStart = true;
MotoRun = true;
u10msNum = PWMpercent = 1;
break;
case KEY_INC: //單步增加
case KEY_INC_CON: //連續(xù)增加
if((PWMpercent < 100) && MotoStart) //PWM從1%~100%
PWMpercent++;
break;
case KEY_DEC: //單步減小
case KEY_DEC_CON: //連續(xù)減小
if((PWMpercent > 1) && MotoStart) //PWM從1%~100%
PWMpercent--;
break;
default:
break;
Speed_Display();
* 速度轉(zhuǎn)換成十進(jìn)制數(shù)
u8 i;
DisNum[0] = PWMpercent / 100;
DisNum[1] = PWMpercent % 100 / 10;
DisNum[2] = PWMpercent % 10;
for(i=1; i<2; i++)
if(DisNum[i] != 0)
break;
DisNum[i] = 0x10;
* 動(dòng)態(tài)顯示速度百分比
static u8 DisPinOn = 0x01;
DisPinOn <<= 1;
if(DisPinOn == 0x10)
DisPosition = 0;
DisPinOn = 0x01;
P0 = 0xff;
P1 = DisPinOn;
P0 = DisCode[DisNum[DisPosition++]];
* 定時(shí)器0中斷
void timer0(void) interrupt 1
TH0 = T0HIGH;
TL0 = T0LOWW;
b10msEvent = true; //10毫秒中斷
if(++SecCount == 100)
SecCount = 0;
b1secEvent = true; //1秒到時(shí)
直流電機(jī)課設(shè).zip
(171.69 KB, 下載次數(shù): 109)
2019-5-9 21:54 上傳
點(diǎn)擊文件名下載附件
1435哈哈哈
時(shí)間:
2019-11-21 18:55
數(shù)碼管老是跳三個(gè)數(shù),是怎么回事
