基于51單片機和Proteus仿真的簡易波形發生器
futao
2019-5-9 17:13
(81.33 KB, 下載次數: 59)
2019-5-9 17:13 上傳
#include <AT89X52.h>
#include <math.h>
#define ADDR1 0x2c //MAX5820LEUA
sbit key_sin=P1^0;
sbit key_tran=P1^2;
sbit key_tooth=P1^4;
sbit SCL = P2 ^ 0;
sbit SDA = P2 ^ 1;
unsigned char code sin[256]= //正弦表
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,
0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5,
0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,
0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,
0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,
0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,
0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,
0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,
0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,
0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80
bit write_addr(unsigned char,bit);//第一個參數表示地址,第二個參數表示 讀:1 寫:0
bit write_data(unsigned char);//第一個參數表示數據,第二個參數表示 命令字
void stop();
void Delay(unsigned int);
I2C_Delay(unsigned int I2C_VALUE)
while ( --I2C_VALUE!= 0 );
函數:I2C_Init()
功能:I2C 總線初始化,使總線處于空閑狀態
說明:在 main()函數的開始處,通常應當要執行一次本函數
void I2C_Init()
SCL = 1;
I2C_Delay(5);
SDA = 1;
I2C_Delay(5);
函數:I2C_Start()
功能:產生I2C 總線的起始狀態
說明:
SCL處于高電平期間,當SDA 出現下降沿時啟動I2C 總線
不論 SDA 和SCL 處于什么電平狀態,本函數總能正確產生起始狀態
本函數也可以用來產生重復起始狀態
本函數執行后,I2C 總線處于忙狀態
void I2C_Start()
SDA = 1;
I2C_Delay(5);
SCL = 1;
I2C_Delay(5);
SDA = 0;
I2C_Delay(5);
SCL = 0;
I2C_Delay(5);
函數:I2C_Write()
功能:向I2C 總線寫1 個字節的數據
參數:
dat:要寫到總線上的數據
void I2C_Write(char dat)
unsigned char t = 8;
do
SDA = (bit)(dat & 0x80);
dat <<= 1;
SCL = 1;
I2C_Delay(5);
SCL = 0;
I2C_Delay(5);
} while ( --t != 0 );
bit I2C_GetAck()
bit ack;
SDA = 1;
I2C_Delay(5);
SCL = 1;
I2C_Delay(5);
ack = SDA;
SCL = 0;
I2C_Delay(5);
return ack;
void I2C_Stop()
unsigned int t = 10;
SDA = 0;
I2C_Delay(5);
SCL = 1;
I2C_Delay(5);
SDA = 1;
I2C_Delay(5);
while ( --t != 0 ); //在下一次產生Start 之前,要加一定的延時
void Delay(unsigned int I2C_Delay_t)
while ( --I2C_Delay_t!= 0 );
bit write_addr(unsigned char addr,bit mod)
unsigned char address;
address=addr<<1;
if(mod)
address++;
I2C_Start();
I2C_Write(address);
Delay(10);
if(I2C_GetAck())
return 1;
return 0;
bit write_data(unsigned char dat)
I2C_Write(dat);
if(I2C_GetAck())
return 1;
return 0;
void stop()
I2C_Stop();
I2C_Init();
void main(void)
unsigned char i;
loop:
I2C_Init();
if(key_sin==0) //產生正弦波
for(i=192;i<255;i++)
write_addr(ADDR1,0);
write_data(0);
write_data(sin[i]);
stop();
if(!(key_tran!=0&&key_tooth!=0))
goto loop;
for(i=0;i<192;i++)
write_data(0);
write_data(sin[i]);
stop();
goto loop;
if(key_tran==0) //產生三角波
for(i=0;i<255;i++)
write_data(0);
write_data(i);
stop();
if(!(key_sin!=0&&key_tooth!=0))
goto loop;
for(;i>0;i--)
write_data(0);
write_data(i);
stop();
goto loop;
if(key_tooth==0) //產生鋸齒波
for(i=0;i<255;i++)
write_data(0);
write_data(i);
stop();
if(!(key_tran!=0&&key_sin!=0))
goto loop;
全部資料51hei下載地址:
基于51單片機和Proteus仿真的簡易波形發生器.zip
(59.83 KB, 下載次數: 32)
2019-5-9 17:12 上傳
