標(biāo)題: HX711 1602顯示 矩陣鍵盤控制程序 [打印本頁]
作者: 572357525    時(shí)間: 2019-5-5 19:20
矩陣鍵盤 P3口控制
單片機(jī)源程序如下:
  1. #include "reg51.h"
  2. #include "LCD1602.h"
  3. #include "HX711.h"
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. sbit Buzzer=P0^0;
  7. unsigned long HX711_Buffer = 0;
  8. unsigned long Weight_Maopi = 0,Weight_Shiwu = 0;
  9. char Price_Count = 0;
  10. unsigned char KEY_NUM = 0;
  11. unsigned char Price_Buffer[3] = {0x00,0x00,0x00};
  12. unsigned long Money = 0;
  13. bit Flag_OK = 0;
  14. //****************************************************
  15. //矩陣鍵盤掃描
  16. //****************************************************
  17. unsigned char KEY_Scan()
  18. {
  19.         unsigned char temp = 0;
  20.         unsigned char com = 0x55 , com1 = 0 , com2 = 0;
  21.         P3=0xf0;
  22.         if(P3!=0xf0)
  23.         {
  24.                 com1=P3;
  25.                 P3=0x0f;
  26.                 com2=P3;
  27.         }
  28.         P3=0xf0;
  29.     while(P3!=0xf0);
  30.         temp=com1|com2;
  31.         if(temp==0xee)com=1;//數(shù)字1
  32.         if(temp==0xed)com=4;//數(shù)字4
  33.         if(temp==0xeb)com=7;//數(shù)字7
  34.         if(temp==0xe7)com=11;//備用鍵*號(hào)鍵
  35.         if(temp==0xd7)com=0;//數(shù)字0
  36.         if(temp==0xb7)com=14;//備用鍵*號(hào)鍵
  37.
  38.         if(temp==0xde)com=2; //數(shù)字2
  39.         if(temp==0xdd)com=5; //數(shù)字5
  40.         if(temp==0xdb)com=8;//數(shù)字8
  41.         if(temp==0xbe)com=3;//數(shù)字3
  42.         if(temp==0xbd)com=6; //數(shù)字6
  43.         if(temp==0xbb)com=9;//數(shù)字9
  44.         if(temp==0x7e)com=16;//數(shù)字A鍵,去皮功能
  45.         if(temp==0x7d)com=15;//數(shù)字B鍵清除鍵,二次測(cè)量
  46.         if(temp==0x7b)com=12;//數(shù)字C輸入單價(jià)錯(cuò)誤時(shí)返回上一步
  47.         if(temp==0x77)com=13;//數(shù)字D鍵,計(jì)算總價(jià)
  48.         return(com);
  49. }
  50. //****************************************************
  51. //稱重
  52. //****************************************************
  53. void Get_Weight()
  54. {
  55.         HX711_Buffer = HX711_Read();
  56.         HX711_Buffer = HX711_Buffer/100;
  57.         if(HX711_Buffer > Weight_Maopi)
  58.         {
  59.                 Weight_Shiwu = HX711_Buffer;
  60.                 Weight_Shiwu = Weight_Shiwu - Weight_Maopi;        //獲取實(shí)物的AD采樣數(shù)值。
  61.         Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/4.22+0.05); //計(jì)算實(shí)物的實(shí)際重量
  62. //因?yàn)椴煌膫鞲衅魈匦郧不一樣,因此,每一個(gè)傳感器需要矯正這里的4.30這個(gè)除數(shù)。
  63. //當(dāng)發(fā)現(xiàn)測(cè)試出來的重量偏大時(shí),增加該數(shù)值。
  64. //如果測(cè)試出來的重量偏小時(shí),減小改數(shù)值。
  65. //該數(shù)值一般在4.0-5.0之間。因傳感器不同而定。
  66. //+0.05是為了四舍五入百分位
  67.                 Buzzer = 1;                                //關(guān)閉警報(bào)
  68.         }
  69. //        else if(HX711_Buffer < Weight_Maopi - 30)
  70. //        {
  71. //                Buzzer = 0;                                //負(fù)重量報(bào)警
  72. //        }
  73. //        else if(HX711_Buffer > Weight_Maopi + 24970)                //大于5Kg的最大量程,報(bào)警
  74. //        {
  75. //                Buzzer = 0;
  76. //        }
  77.         if(Weight_Shiwu > 5000 || HX711_Buffer < Weight_Maopi - 30)
  78.         {
  79.                 Buzzer = 0;
  80.         }
  81.         else
  82.         {
  83.                 Buzzer = 1;
  84.         }
  85.
  86. }
  87. //****************************************************
  88. //獲取毛皮重量
  89. //****************************************************
  90. void Get_Maopi()
  91. {
  92.         HX711_Buffer = HX711_Read();
  93.         Weight_Maopi = HX711_Buffer/100;
  94. }
  95. //****************************************************
  96. //MS延時(shí)函數(shù)(12M晶振下測(cè)試)
  97. //****************************************************
  98. void Delay_ms(unsigned int n)
  99. {
  100.         unsigned int  i,j;
  101.         for(i=0;i<n;i++)
  102.                 for(j=0;j<123;j++);
  103. }
  104. void main()
  105. {
  106.         Init_LCD1602();        //初始化LCD1602
  107.         LCD1602_write_com(0x80);                                                //指針設(shè)置
  108.         LCD1602_write_word("Welcome to use! ");                        //開機(jī)畫面第一行
  109.         Delay_ms(2000);                 //延時(shí)2s
  110. loop:Price_Count = 0;
  111.         Price_Buffer[0] = 0;
  112.         Price_Buffer[1] = 0;
  113.         Price_Buffer[2] = 0;
  114.         Flag_OK = 0;
  115.         LCD1602_write_com(0x80);                                                //指針設(shè)置
  116.         LCD1602_write_word("+WEI |PRI | MON ");
  117.         LCD1602_write_com(0x80+0x40);                                //指針設(shè)置
  118.         LCD1602_write_word("0.000|  . |   . ");
  119.
  120.
  121.         Get_Maopi();                                //稱毛皮重量
  122.         while(1)
  123.         {
  124.                 if( Flag_OK == 0)
  125.                 {
  126.                         Get_Weight();                        //稱重
  127.
  128.                         //顯示當(dāng)前重量
  129.                         LCD1602_write_com(0x80+0x40);
  130.                         LCD1602_write_data(Weight_Shiwu/1000 + 0x30);
  131.                         LCD1602_write_data('.');
  132.                         LCD1602_write_data(Weight_Shiwu%1000/100 + 0x30);
  133.                         LCD1602_write_data(Weight_Shiwu%100/10 + 0x30);
  134.                         LCD1602_write_data(Weight_Shiwu%10 + 0x30);
  135.                 }
  136.                 KEY_NUM = KEY_Scan();
  137.                 if( KEY_NUM != 0x55)                        //當(dāng)返回的不是初值時(shí)候,確認(rèn)按鍵按下。
  138.                 {
  139.                         if(KEY_NUM == 16)                        //數(shù)字A鍵,去皮功能
  140.                         {
  141.                                 Get_Maopi();                        //去皮
  142.                         }
  143.                         if(KEY_NUM == 15)                        //數(shù)字B鍵清除鍵,二次測(cè)量
  144.                         {
  145.                                 goto loop;
  146.                         }
  147.                         if(KEY_NUM == 12)                        //數(shù)字C輸入單價(jià)錯(cuò)誤時(shí)返回上一步
  148.                         {
  149.                                 Price_Count--;
  150.                                 if( Price_Count < 0)
  151.                                 {
  152.                                         Price_Count = 0;
  153.                                 }
  154.
  155.                                 Price_Buffer[Price_Count] = 0;                           //清除上一個(gè)輸入的數(shù)據(jù)
  156.                                 switch(Price_Count)
  157.                                 {
  158.                                         case 0:
  159.                                                         LCD1602_write_com(0x80+0x40+6);
  160.                                                         LCD1602_write_data(' ');
  161.                                                         break;
  162.                                         case 1:
  163.                                                         LCD1602_write_com(0x80+0x40+7);
  164.                                                         LCD1602_write_data(' ');
  165.                                                         break;
  166.                                         case 2:
  167.                                                         LCD1602_write_com(0x80+0x40+9);
  168.                                                         LCD1602_write_data(' ');
  169.                                                         break;
  170.                                         default : break;
  171.                                 }
  172.                         }
  173.                         if(KEY_NUM == 13)                        //數(shù)字D鍵,計(jì)算總價(jià)
  174.                         {
  175.                                 Money = Price_Buffer[0] * 100 + Price_Buffer[1] * 10 + Price_Buffer[2];
  176.                                 Money = Money * Weight_Shiwu / 1000;
  177.                                 LCD1602_write_com(0x80+0x40+11);
  178.                                 LCD1602_write_data(Money/1000 + 0x30);
  179.                                 LCD1602_write_data(Money%1000/100 + 0x30);
  180.                                 LCD1602_write_data(Money%100/10 + 0x30);
  181.                                 LCD1602_write_data('.');
  182.                                 LCD1602_write_data(Money%10 + 0x30);
  183.
  184.                                 Flag_OK = 1;
  185.                         }
  186.                         if(KEY_NUM >= 0 && KEY_NUM <= 9)                                          //顯示輸入的價(jià)值
  187.                         {
  188.                                 Price_Buffer[Price_Count] = KEY_NUM;
  189.
  190.                                 switch(Price_Count)
  191.                                 {
  192.                                         case 0:
  193.                                                         LCD1602_write_com(0x80+0x40+6);
  194.                                                         LCD1602_write_data(Price_Buffer[0] + 0x30);
  195.                                                         break;
  196.                                         case 1:
  197.                                                         LCD1602_write_com(0x80+0x40+7);
  198.                                                         LCD1602_write_data(Price_Buffer[1] + 0x30);
  199.                                                         break;
  200.                                         case 2:
  201.                                                         LCD1602_write_com(0x80+0x40+9);
  202.                                                         LCD1602_write_data(Price_Buffer[2] + 0x30);
  203.                                                         break;
  204.                                         default : break;
  205.                                 }
  206.
  207.                                 Price_Count++;
  208.
  209.                                 if( Price_Count >= 3)
  210.                                 {
  211.                                         Price_Count = 3;
  212.                                 }
  213.                         }
  214.                 }
  215.         }
  216. }
16.zip (45.01 KB, 下載次數(shù): 25)
