MQ-5有4腳,VCC,GND,AOUT,DOUT
VCC,GND分別接51hei單片機開發板的+5V與……DOUT接外部中斷1(P3.3),中斷則報警……AOUT接ADC0804的VIN+,也就是hei板J2的3腳,J2的1腳接外部中斷0(P3.2),在ADC0804轉換中用,轉換與顯示……注意電源供電,否則工作不正常……
#include <reg52.h>
#include <intrins.h>
uchar code tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
sbit adc_cs=P2^0;
sbit adc_rd=P3^7;
sbit adc_wr=P3^6;
sbit beep=P2^2;
sbit P26=P2^6;
sbit P27=P2^7;
sbit P24=P2^4;
bit beep_flag;
bit adc_flag;
bit adc_start;
void delay(uint temp)
while(temp--);
void init(void)
P24=0;
P27=1;
P0=0xff;
P27=0;
P26=1;
P0=0x00;
P26=0;
TMOD=0x01;
TH0=0x3c;
TL0=0xb0;
ET0=1;
TR0=1;
IT1=0;
EX1=1;
IT0=1;
EX0=1;
EA=1;
void int0_srv() interrupt 0
adc_flag=1;
void int1_srv() interrupt 2
beep_flag=1;
void timer0_srv() interrupt 1
uchar temp;
TH0=0x3c;
TL0=0xb0;
temp++;
if(temp==40)
temp=0;
adc_start=1;
uchar adc_change(void)
uchar value;
adc_cs=1;
adc_wr=1;
delay(2);
adc_cs=0;
delay(2);
adc_wr=0;
delay(10);
adc_wr=1;
delay(2);
adc_cs=1;
while(!adc_flag);
adc_flag=0;
adc_rd=1;
_nop_();
adc_cs=0;
delay(2);
adc_rd=0;
_nop_();
value=P1;
_nop_();
adc_rd=1;
delay(2);
adc_cs=1;
return value;
uchar adc_value;
uchar ge,shi,bei;
uint i;
init();
if(beep_flag)
beep_flag=0;
beep=0;
delay(10000);
beep=1;
delay(10000);
if(adc_start)
adc_start=0;
adc_value=adc_change();
bei=adc_value/100;
adc_value=adc_value%100;
shi=adc_value/10;
ge=adc_value%10;
for(i=0;i<100;i++)/////////
P27=1;
P0=0xfe;
P27=0;
P26=1;
P0=tab[bei];
delay(50);
P0=0x00;
P26=0;
P27=1;
P0=0xfd;
P27=0;
P26=1;
P0=tab[shi];
delay(50);
P0=0x00;
P26=0;
P27=1;
P0=0xfb;
P27=0;
P26=1;
P0=tab[ge];
delay(50);
P0=0x00;
P26=0;
上面的程序還有點小問題,蜂鳴器工作時,數碼管要閃,要暗下來,我用二個中斷,二個定時器來處理,修正后相當完善。
