標題: stm32驅動HCRS04超聲波測距模塊,分享一下我的驅動程序 [打印本頁]
作者: wuleng    時間: 2019-4-17 21:01
#include "RCWL.h"
#define RCWL1601_PORT GPIOB
#define RCWL16014_CLK RCC_APB2Periph_GPIOB
#define RCWL1601_TRIG GPIO_Pin_5
#define RCWL1601_ECHO GPIO_Pin_6
#define RCC_APB1Periph_TIM  RCC_APB1Periph_TIM2
#define RCTW_TIM TIM2
#define RCTW_IRQn  TIM2_IRQn
#define TRIG_Send PBout(5)
#define ECHO_Reci PBin(6)
u16 msRcCount = 0; //毫秒計數
void RCWL1601_NVIC(void);
void  RCWL1601_Init()
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure_RCWL;     //生成用于定時器設置的結構體
    GPIO_InitTypeDef GPIO_InitStructure_RCWL;
    RCC_APB2PeriphClockCmd(RCWL16014_CLK,ENABLE);
        // IO初始化
    GPIO_InitStructure_RCWL.GPIO_Pin = RCWL1601_TRIG;       //發送電平引腳
    GPIO_InitStructure_RCWL.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure_RCWL.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
    GPIO_Init(RCWL1601_PORT,&GPIO_InitStructure_RCWL);
    GPIO_ResetBits(RCWL1601_PORT,RCWL1601_TRIG);
    GPIO_InitStructure_RCWL.GPIO_Pin = RCWL1601_ECHO;     //返回電平引腳
    GPIO_InitStructure_RCWL.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空輸入
    GPIO_ResetBits(RCWL1601_PORT,RCWL1601_ECHO);
            //定時器初始化使用基本定時器TIM6
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM,ENABLE);   //使能對應RCC時鐘
        //配置定時器基礎結構體
    TIM_DeInit(RCTW_TIM);
    TIM_TimeBaseStructure_RCWL.TIM_Period =(1000-1); //設置在下一個更新事件裝入活動的自動重裝載寄存器周期的計數到1000為1ms
    TIM_TimeBaseStructure_RCWL.TIM_Prescaler =(72-1); //設置用來作為TIMx時鐘頻率除數的預分頻值1M的計數頻率1US計數
    TIM_TimeBaseStructure_RCWL.TIM_ClockDivision = TIM_CKD_DIV1; //不分頻
    TIM_TimeBaseStructure_RCWL.TIM_CounterMode = TIM_CounterMode_Up;  // TIM向上計數模式
    TIM_TimeBaseInit(RCTW_TIM,&TIM_TimeBaseStructure_RCWL); //根據TIM_TimeBaseInitStruct中指定的參數初始化TIMX的時間基數單位
    TIM_ClearFlag(RCTW_TIM,TIM_FLAG_Update);   //清除更新中斷,免得一打開中斷立即產生中斷
    TIM_ITConfig(RCTW_TIM,TIM_IT_Update,ENABLE);    //打開定時器更新中斷
    RCWL1601_NVIC();
    TIM_Cmd(RCTW_TIM,DISABLE);
//提示:靜態函數的作用域僅限于定義它的源文件內,所以不需要在頭文件里聲明
static void  OpenTimerForHc()         //打開定時器
        TIM_SetCounter(RCTW_TIM,0); //清除計數
        msRcCount = 0;
        TIM_Cmd(RCTW_TIM,ENABLE);  //使能TIMX外設
static void  CloseTimerForHc()        //關閉定時器
     TIM_Cmd(RCTW_TIM,DISABLE);  //使能TIMX外設
// NVIC配置
void RCWL1601_NVIC()
    NVIC_InitTypeDef NVIC_InitStructure;
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    NVIC_InitStructure.NVIC_IRQChannel = RCTW_IRQn;             //選擇串口1個中斷
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //搶占式中斷優先級設置為1
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;         //響應式中斷優先級設置為1
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;        //使能中斷
    NVIC_Init(&NVIC_InitStructure);
//定時器6中斷服務程序
void  TIM2_IRQHandler(void)    // TIM3中斷
        if(TIM_GetITStatus(RCTW_TIM,TIM_IT_Update)!= RESET)   //檢查TIM3更新中斷發生與否
                TIM_ClearITPendingBit(RCTW_TIM,TIM_IT_Update);  //清除TIMX更新中斷標志
                msRcCount++;
//獲取定時器時間
u32 GetEchoTimer(void)
        u32 t = 0;
        t= msRcCount*1000; //得到MS
        t+= TIM_GetCounter(RCTW_TIM); //得到us
        RCTW_TIM-> CNT = 0;  //將TIM2計數寄存器的計數值清零
        Delay_Ms(50);
        return t;
//一次獲取超聲波測距數據兩次測距之間需要相隔一段時間,隔斷回響信號
//為了消除余震的影響,取五次數據的平均值進行加權濾波。
float   RCWL1601GetLength(void)
        u32 t = 0;
        int  i = 0;
        float  lengthTemp = 0;
        float  sum = 0;
        while(i!=5)
        TRIG_Send = 1;      //發送口高電平輸出
        Delay_Us(20);
        TRIG_Send = 0;
        while (ECHO_Reci==0);      //等待接收口高電平輸出
            OpenTimerForHc();        //打開定時器
        i = i + 1;
        while (ECHO_Reci==1);
            CloseTimerForHc();        //關閉定時器
        t = GetEchoTimer();        //獲取時間,分辨率為1US
        lengthTemp =((float )t /58.0); //厘米
        sum = lengthTemp + sum;
        lengthTemp = sum / 5.0;
        return lengthTemp;
函數名稱:Delay_Ms_Ms
**功能描述:延時1MS(可通過仿真來判斷他的準確度)
**參數描述:time(ms)注意時間<65535
void  Delay_Ms(uint16_t time)   //延時函數
    uint16_t i,j;
    for (i = 0; i <time; i ++)
        for (j = 0; j <10260; j ++);
**函數名稱:Delay_Ms_Us
**功能描述:延時1us(可通過仿真來判斷他的準確度)
**參數描述:time(us)注意時間<65535
void  Delay_Us(uint16_t time)   //延時函數
    uint16_t i,j;
        for (j = 0; j <9; j ++);
作者: admin    時間: 2019-4-17 21:26
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
