標題: ad7705數字萬用表程序 電壓五檔、電流五檔、電阻七檔 [打印本頁]
作者: 以夢為馬1    時間: 2019-4-14 16:08
文件名稱:ad7705.c
功能:數字萬用表
說明:電壓五檔、電流五檔、電阻七檔
#include<reg52.h>
#include<intrins.h>
sbit ADC_CLK=P1^7 ;
sbit ADC_DIN=P3^0 ;
sbit ADC_DOUT=P3^0 ;
sbit ADC_DRDY=P3^1;
sbit lcden=P3^3;
sbit lcdrs=P3^2;
sbit U=P1^6;
sbit I=P3^5;
sbit R=P3^7;
/*電壓檔*/
sbit a=P1^4;
sbit b=P1^3;
sbit c=P1^2;
sbit d=P1^1;
sbit e=P1^0;
/*電流檔*/
sbit f=P2^0;
sbit g=P2^1;
sbit h=P2^2;
sbit i=P2^3;
sbit j=P2^4;
/*電阻檔*/
sbit k=P1^0;
sbit l=P1^1;
sbit m=P1^2;
sbit n=P1^3;
sbit o=P1^4;
sbit p=P2^1;
sbit q=P2^0;
/*短路口*/
sbit DUANLU=P2^5;
void delayms(uint xms);
uint choose();
void readad_16deal_choose();
void InitADC(void);
void InitLCD(void);
void write_com(uchar com);
void write_data(uchar date);
uint WriteToReg_ADC(uint byteword);
uint ReadADC_16BitValue();
void readad_16deal0() ;
void readad_16deal11() ;
void readad_16deal12() ;
void readad_16deal13() ;
void readad_16deal14() ;
void readad_16deal15() ;
void readad_16deal21() ;
void readad_16deal22() ;
void readad_16deal23() ;
void readad_16deal24() ;
void readad_16deal25() ;
void readad_16deal31() ;
void readad_16deal32() ;
void readad_16deal33() ;
void readad_16deal34() ;
void readad_16deal35() ;
void readad_16deal36() ;
void readad_16deal37() ;
void display();
void display0();
uint ch;
uint readad_16bit;
unsigned long v=0;
unsigned long v0=0;
float DATAF,DATAF2;
int DATA=0;
char TRUE;
char count=0;
char code table0[]="welcome!      ";
char code table11[]="DC-200mV~200mV";
char code table12[]="DC-2~2V       ";
char code table13[]="DC-20~20V     ";
char code table14[]="DC-200~200V   ";
char code table15[]="DC-500~500V   ";
char code table21[]="DC-2~2mA      ";
char code table22[]="DC-20~20mA    ";
char code table23[]="DC-200~200mA  ";
char code table24[]="DC-2~2A       ";
char code table25[]="DC-15~15A     ";
char code table31[]="         0~20";
char code table32[]="        0~200";
char code table33[]="         0~2k";
char code table34[]="        0~20k";
char code table35[]="       0~200k";
char code table36[]="         0~2M";
char code table37[]="       0~100M";
     DUANLU=1;
         InitLCD();
           InitADC();
           readad_16deal0();
           display();
uint choose()
{  U=0;a=0;b=0;c=0;d=0;e=0;
   I=0;f=0;g=0;h=0;i=0;j=0;
   R=0;k=0;l=0;m=0;n=0;o=0;p=0;q=0;
           if(U)
                 if(a)ch=11;
                else if(b) ch=12;
                else if(c) ch=13;
                else if(d) ch=14;
                else if(e) ch=15;
        else if(I)
                if(f)ch=21;
                else if(g)ch=22;
                else if(h)ch=23;
                else if(i)ch=24;
                else if(j)ch=25;
        else if(R)
                if(k)ch=31;
                else if(l)ch=32;
                else if(m)ch=33;
                else if(n)ch=34;
                else if(o)ch=35;
                else if(p)ch=36;
                else if(q)ch=37;
        else ch=0;
        return ch;
{   switch(choose())
                case 11: readad_16deal11();break;//電壓
                case 12: readad_16deal12();break;
                case 13: readad_16deal13();break;
                case 14: readad_16deal14();break;
                case 15: readad_16deal15();break;
                case 21: readad_16deal21();break;//電流
                case 22: readad_16deal22();break;
                case 23: readad_16deal23();break;
                case 24: readad_16deal24();break;
                case 25: readad_16deal25();break;
                case 31: readad_16deal31();break;//電阻
                case 32: readad_16deal32();break;
                case 33: readad_16deal33();break;
                case 34: readad_16deal34();break;
                case 35: readad_16deal35();break;
                case 36: readad_16deal36();break;
                case 37: readad_16deal37();break;
  uint i,j;
  for(i=xms;i>0;i--)
   for(j=110;j>0;j--);
void InitADC(void)
        uchar z;
        ADC_CLK=1;
        ADC_DIN=1;
        for(z=0;z<40;z++)
                ADC_CLK=0;
                ADC_CLK=1;
        }                                                           //防止接口迷失,通信寄存器返回到等待寫狀態
        WriteToReg_ADC(0x20);                 //通道1,下一個寫時鐘寄存器
        WriteToReg_ADC(0x00);                 //寫時鐘寄存器設置更新速率為20Hz  0x03:200Hz
        WriteToReg_ADC(0x10);                 //通道1,下一個寫設置寄存器
        //WriteToReg_ADC(0x40);                 //寫設置寄存器 ,設置成雙極性、無緩沖、增益為1、濾波器不工作、自校準
        switch(choose())
        {        case 0:        display0();break;
                case 11: WriteToReg_ADC(0x58);break;        //增益8        以下全為雙極性
                case 12:
                case 13:
                case 14:
                case 15: WriteToReg_ADC(0x40);break;        //增益1
                case 21: WriteToReg_ADC(0x58);break;        //增益8
                case 22: WriteToReg_ADC(0x58);break;        //增益8
                case 23: WriteToReg_ADC(0x58);break;        //增益8
                case 24: WriteToReg_ADC(0x58);break;        //增益8
                case 25: WriteToReg_ADC(0x40);break;
                case 31: WriteToReg_ADC(0x48);break;        //增益2
                case 32: WriteToReg_ADC(0x48);break;
                case 33: WriteToReg_ADC(0x48);break;
                case 34: WriteToReg_ADC(0x48);break;
                case 35: WriteToReg_ADC(0x48);break;
                case 36: WriteToReg_ADC(0x48);break;
                case 37: WriteToReg_ADC(0x40);break;  //增益1
        delayms(50);
void InitLCD(void)
          lcden=0;
      write_com(0x38);         //設置16*2顯示,5*7點陣,8位數據接口
      write_com(0x0c);         //開顯示,不顯示光標
      write_com(0x06);         //寫一個字符后地址指針加1
      write_com(0x01);         //顯示清零,數據指針清零
          lcdrs=0;
          P0=com;
          delayms(5);
          lcden=1;
          delayms(5);
          lcden=0;
           lcdrs=1;
           P0=date;                              //注意:新板數據口是P0,舊板是P1
           delayms(5);
           lcden=1;
           delayms(5);
           lcden=0;
/*********寫ad轉換寄存器**********/
        uint Token,z;
        uint AD16bit_WriteToReg;
        ADC_CLK=1;
        Token=0x80;
    AD16bit_WriteToReg=byteword;
        for(z=0;z<8;z++)
                if(AD16bit_WriteToReg & Token)
                        ADC_DIN=1; // 輸入數據位
                        ADC_DIN=0;
                delayms(1);
                ADC_CLK=1;
                delayms(1);
                ADC_CLK=0;
                ADC_CLK=1;
            Token=Token>>1;
        ADC_CLK=1;
        ADC_DIN=1;                         //結束
        return(TRUE);
/******************讀16位AD數值******************/
        uint z;
        unsigned long AD16bit;
        //uint AD16bit;
        WriteToReg_ADC(0x38);
    while (ADC_DRDY) ;                 //等待數據準備
        { //delayms(5);
          ADC_CLK=1;
          AD16bit=0x0000;
                for(z=0;z<16;z++)
                        AD16bit=AD16bit<<1;
                        ADC_CLK=0;
                        delayms(1);
                        if(ADC_DOUT==1)AD16bit=AD16bit|0x0001;
                        ADC_CLK=1;
        ADC_CLK=1;
        ADC_DIN=1;
        return(AD16bit);
        char count=0;
        readad_16bit=ReadADC_16BitValue();
        if(readad_16bit>0x8000)DATA=readad_16bit-0x8000;
        if(readad_16bit<0x8000)DATA=0x8000-readad_16bit;
        DATAF=DATA;
/*********************電壓***********************/
void readad_16deal11() //200m
         DATAF2=DATAF/32767*31250000;
         v0=DATAF2;
         v=v0;
         if(v>20000000)v=20000000;
         for(count=0;count<14;count++)
                write_com(0x80+count);
                write_data(table11[count]);
void readad_16deal12()  // 2v
     DATAF2=DATAF/32767*250000;
         v0=DATAF2;
         v=v0;
         if(v>200000)v=200000;
                write_data(table12[count]);
void readad_16deal13() // 20v
{    DATAF2=DATAF/32767*250000*11;
         v0=DATAF2;
         v=v0;
         if(v>2000000)v=2000000;
                write_data(table13[count]);
void readad_16deal14()  // 200v
{    DATAF2=DATAF/32767*250000*101;
         v0=DATAF2;
         v=v0;
                write_data(table14[count]);
void readad_16deal15()  //500v
{    DATAF2=DATAF/32767*250000*491;
         v0=DATAF2;
         v=v0;
         if(v>50000000)v=50000000;
                write_data(table15[count]);
/*******************電流*********************/
void readad_16deal21() //2mA
{    DATAF2=DATAF/32767*2500000000/8/106;
         v0=DATAF2;
         v=v0;
                write_data(table21[count]);
void readad_16deal22() //20mA
{    DATAF2=DATAF/32767*250000000/8/18*15;
         v0=DATAF2;
         v=v0;
                write_data(table22[count]);
void readad_16deal23() //200mA
{    DATAF2=DATAF/32767*250000000/8/16*12;
         v0=DATAF2;
         v=v0;
                write_data(table23[count]);
void readad_16deal24() //2A
{    DATAF2=DATAF/32767*250000/8/18*15;
         v0=DATAF2;
         v=v0;
                write_data(table24[count]);
void readad_16deal25() //15A
{    DATAF2=DATAF/32767*1562500;
         v0=DATAF2;
         v=v0;
         if(v>1500000)v=15000000;
                write_data(table25[count]);
/*********************電阻********************/
void readad_16deal31() // 20Ω
{    DATAF2=(DATAF/32767*125000)*2120/(250-(DATAF/32767*125));
         v0=DATAF2;
         v=v0;
//         if(v>2000000)v=2000000;
         if(DATAF<30000)DUANLU=0;
         else DUANLU=1;
         for(count=0;count<13;count++)
                write_data(table31[count]);
         write_com(0x80+13);
         write_data(0xf4);
void readad_16deal32() //200Ω
{    DATAF2=(DATAF/32767*125000)*20060/(250-(DATAF/32767*125));
         v0=DATAF2;
         v=v0;
//         if(v>20000000)v=20000000;
                write_data(table32[count]);
         write_com(0x80+13);
         write_data(0xf4);
void readad_16deal33() // 2kΩ
{    DATAF2=(DATAF/32767*125)*200000/(250-(DATAF/32767*125));
         v0=DATAF2;
         v=v0;
//         if(v>200000)v=200000;
                write_data(table33[count]);
         write_com(0x80+13);
         write_data(0xf4);
void readad_16deal34() //20kΩ
{    DATAF2=(DATAF/32767*125)*2001000/(250-(DATAF/32767*125));
         v0=DATAF2;
         v=v0;
                write_data(table34[count]);
         write_com(0x80+13);
         write_data(0xf4);
void readad_16deal35() // 200kΩ
{    DATAF2=(DATAF/32767*125)*19980000/(250-(DATAF/32767*125));
         v0=DATAF2;
         v=v0;
                write_data(table35[count]);
         write_com(0x80+13);
         write_data(0xf4);
void readad_16deal36() //2MΩ
{    DATAF2=(DATAF/32767*1.3*125)*200000/(250-(DATAF/32767*1.3*125));
         v0=DATAF2;
         v=v0;
                write_data(table36[count]);
         write_com(0x80+13);
         write_data(0xf4);
void readad_16deal37() //100MΩ
{    DATAF2=(DATAF/32767*2.5)*510000/(2.5-(DATAF/32767*2.5));
         v0=DATAF2;
         v=v0;
//         if(v>10000000)v=10000000;
                write_data(table37[count]);
         write_com(0x80+13);
         write_data(0xf4);
void display()                                                   //檔符顯示前移到各檔處理函數中
{        //本函數可共用
        char disp[9]="12345678";
        disp[0]= (v/10000000)+0x30;           //0對應的十進制ASCII碼48換為十六進制即為0x30
        v%=10000000;
        disp[1]= (v/1000000)+0x30;
        v%=1000000;
        disp[2]= (v/100000)+0x30;
        v%=100000;
        disp[3]= (v/10000)+0x30;
        v%=10000;
        disp[4]= (v/1000)+0x30;
        v%=1000;
        disp[5]= (v/100)+0x30;
        v%=100;
        disp[6]= (v/10)+0x30;
        v%=10;
        disp[7]= (v/1)+0x30;
                write_com(0x80+0x41);
                write_data('-');
                write_data('+');
        for(count=0;count<3;count++)
                write_com(0x80+0x42+count);
                write_data(disp[count]);
        write_com(0x80+0x42+3);
        write_data('.');
        for(count=3;count<8;count++)
                write_com(0x80+0x42+count+1);
void display0()
                write_data(table0[count]);
作者: CHENGLCD    時間: 2020-7-17 09:42
要是有個電路圖就更好了
作者: 龍小白    時間: 2022-9-16 08:59
支持樓上,謝謝樓主
