標題: 51單片機入門之不同按鍵實現數碼管顯示0到20程序 [打印本頁]
作者: 剪云者    時間: 2019-2-19 16:48
可以通過不同按鍵實現數碼管顯示0到20這些數,兩個數碼管一個代表各位,一個代表十位
#include <reg51.h>
sbit K1=P2^0;
sbit K2=P2^1;
sbit K3=P2^2;
sbit K4=P2^3;
uchar code F[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x3F,0x06,0x5B,0x4F,0x66,0x6D};
uchar code S[]={0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x06,0x06,0x06,0x06,0x06,0x06};
  uchar b,fir,sec,third,forth;
  fir=K1;
  sec=K2;
  third=K3;
  forth=K4;
  b=fir*8+sec*4+third*2+forth*1;
  P0=F[15-b];
  P1=S[15-b];
作者: jll586    時間: 2019-3-3 23:01
這個顯示的是0-19
