標(biāo)題: 明遠(yuǎn)智睿MY-IMX6-EK200 Linux-4.1.15 測(cè)試手冊(cè)(3) [打印本頁]
作者: 明遠(yuǎn)智睿    時(shí)間: 2019-1-23 11:02
【接上一章節(jié)明遠(yuǎn)智睿MY-IMX6-EK200 Linux-4.1.15 測(cè)試手冊(cè)(2)】
13  定時(shí)喚醒測(cè)試
設(shè)定 10 秒后產(chǎn)生喚醒事件
# echo +10 > /sys/class/rtc/rtc1/wakealarm
使設(shè)備進(jìn)入
# echo mem > /sys/power/state
睡眠信息
PM: Syncing filesystems ... done.
Freezing user space processes ... (elapsed 0.001 seconds) done.
Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Suspending console(s) (use no_console_suspend to debug)
PM: suspend of devices complete after 59.213 msecs
PM: suspend devices took 0.060 seconds
PM: late suspend of devices complete after 1.004 msecs
PM: noirq suspend of devices complete after 1.031 msecs
Disabling non-boot CPUs ...
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
Enabling non-boot CPUs ...
CPU1 is up
CPU2 is up
CPU3 is up
PM: noirq resume of devices complete after 1.138 msecs
PM: early resume of devices complete after 1.136 msecs
PM: resume of devices complete after 116.878 msecs
PM: resume devices took 0.120 seconds
Restarting tasks ... done.
喚醒信息
(elapsed 0.012 seconds) done.
PM: suspend of devices complete after 693.963 msecs
PM: suspend devices took 0.700 seconds
PM: late suspend of devices complete after 2.419 msecs
PM: noirq suspend of devices complete after 2.303 msecs
PM: noirq resume of devices complete after 1.402 msecs
PM: early resume of devices complete after 1.476 msecs
PM: resume of devices complete after 121.763 msecs
PM: resume devices took 0.130 seconds
14  音頻測(cè)試14.1  播放音頻
# aplay /unit_tests/audio8k16S.wav
Playing WAVE '/unit_tests/audio8k16S.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Stereo
14.2  音頻錄音
錄音
# arecord -d 5 -f S16_LE -t wav foobar.wav
播放錄音
# aplay foobar.wav
15  顯示屏(選配)測(cè)試
特別說明:
     當(dāng)U-Boot 版本u-boot-2016.03 svn315及以上
         內(nèi)核 版本  linux-3.0.35  svn31及以上
                  linux-3.14.52 svn369及以上
                  linux-3.14.52 svn368及以上
         燒錄工具   MfgTool-MYIMX6A9-L* svn181及以上
請(qǐng)參考《MY-IMX6-A9系列:顯示功能測(cè)試》進(jìn)行測(cè)試
一般情況下則按照如下方法測(cè)試
在系統(tǒng)啟動(dòng)過程中,可以看到 Linux 小企鵝和 OpenEmbedded 啟動(dòng)畫面。
16  顯示屏配置測(cè)試
說明:每項(xiàng)顯示功能測(cè)試都需要重啟系統(tǒng)進(jìn)入到u-boot命令行,輸入命令并按確認(rèn)鍵。
U-Boot 2016.03-svn270 (Oct 09 2018 - 14:44:15 +0800)
CPU:   Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
CPU:   Extended Commercial temperature grade (-20C to 105C) at 43C
Reset cause: POR
Board: MYZR i.MX6 Evaluation Kit
Model: MY-IMX6-EK200-6Q-2G
I2C:   ready
DRAM:  2 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
SF: Detected SST25VF016B with page size 256 Bytes, erase size 64 KiB, total 2 MiB
*** Warning - bad CRC, using default environment
No panel detected: default to MY-LVDS-WSVGA
Display: MY-LVDS-WSVGA (1024x600)
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
Normal Boot
Hit any key to stop autoboot:  0
16.1  LVDS1 單屏顯示
=> setenv display ${disp_fb0_lvds1}
=> saveenv; boot
16.2  LVDS0 單屏顯示
=> setenv display ${disp_fb0_lvds0}
=> saveenv; boot
16.3  HDMI 單屏顯示
=> setenv display ${disp_fb0_hdmi}
=> saveenv; boot
16.4  RGB(LCD) 單屏顯示
=> setenv display ${disp_fb0_lcd}
=> saveenv; boot
16.5  LVDS1 + LVDS0 雙屏同步顯示
=> setenv display ${disp_lvds_sync}
=> saveenv; boot
16.6  LVDS1 + LVDS0 雙屏同步顯示
=> saveenv; boot
16.7  LVDS1(主) + HDMI 雙屏異步顯示
=> setenv display ${disp_fb0_lvds1} ${disp_fb1_hdmi}
=> saveenv; boot
16.8  LVDS1(主) + RGB 雙屏異步顯示
=> setenv display ${disp_fb0_lvds1} ${disp_fb1_lcd}
=> saveenv; boot
16.9  LVDS0(主) + HDMI 雙屏異步顯示
=> setenv display ${disp_fb0_lvds0} ${disp_fb1_hdmi}
=> saveenv; boot
16.10  LVDS0(主) + RGB 雙屏異步顯示
=> setenv display ${disp_fb0_lvds0} ${disp_fb1_lcd}
=> saveenv; boot
16.11  HDMI(主) + LVDS1 雙屏異步顯示
=> setenv display ${disp_fb0_hdmi} ${disp_fb0_lvds1}
=> saveenv; boot
16.12  HDMI(主) + LVDS0 雙屏異步顯示
=> setenv display ${disp_fb0_hdmi} ${disp_fb0_lvds0}
=> saveenv; boot
16.13  視頻播放測(cè)試
設(shè)置Linux的環(huán)境變量
export GSTL=gst-launch-1.0
export PLAYBIN=playbin
export GPLAY=gplay-1.0
export GSTINSPECT=gst-inspect-1.0
export MP4_FILE="/unit_tests/akiyo.mp4"
播放視頻到主顯示屏
$GSTL $PLAYBIN uri=file://$MP4_FILE video-sink="imxv4l2sink device=/dev/video17"
播放視頻到第二顯示屏
$GSTL $PLAYBIN uri=file://$MP4_FILE video-sink="imxv4l2sink device=/dev/video18"
17  4G模塊EC20(選配)測(cè)試
# /my-demo/linux-4.1.15/MY_EC20_QuectelCM_L4115_MYIMX6A9.out &
[1] 636
[10-01_14:02:10:616] WCDMA<E_QConnectManager_Linux&Android_V1.1.34
[10-01_14:02:10:617] /my-demo/linux-4.1.15/MY_EC20_QuectelCM_L4115_MYIMX6A7.out profile[1] = (null)/(null)/(null)/0, pincode = (null)
[10-01_14:02:10:619] Find /sys/bus/usb/devices/1-1.2 idVendor=2c7c idProduct=0125
[10-01_14:02:10:620] Find /sys/bus/usb/devices/1-1.2:1.4/net/eth2
[10-01_14:02:10:620] Find usbnet_adapter = eth2
[10-01_14:02:10:620] Find /sys/bus/usb/devices/1-1.2:1.4/GobiQMI/qcqmi2
[10-01_14:02:10:620] Find qmichannel = /dev/qcqmi2
[10-01_14:02:10:665] Get clientWDS = 7
[10-01_14:02:10:697] Get clientDMS = 8
[10-01_14:02:10:729] Get clientNAS = 9
[10-01_14:02:10:760] Get clientUIM = 10
[10-01_14:02:10:792] Get clientWDA = 11
[10-01_14:02:10:825] requestBaseBandVersion EC20CEFAR02A10M4G
[10-01_14:02:10:920] requestGetSIMStatus SIMStatus: SIM_READY
[10-01_14:02:10:953] requestGetProfile[1] cmnet///0
[10-01_14:02:10:985] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE
[10-01_14:02:11:017] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[10-01_14:02:11:081] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE
[10-01_14:02:11:144] requestSetupDataCall WdsConnectionIPv4Handle: 0x87779840
[10-01_14:02:11:241] requestQueryDataCall IPv4ConnectionStatus: CONNECTED
[10-01_14:02:11:274] ifconfig eth2 up
[10-01_14:02:11:305] busybox udhcpc -f -n -q -t 5 -i eth2
[10-01_14:02:11:321] udhcpc (v1.24.1) started
[10-01_14:02:11:433] Sending discover...
[10-01_14:02:11:493] Sending select for 10.127.206.63...
[10-01_14:02:11:552] Lease of 10.127.206.63 obtained, lease time 7200
[10-01_14:02:11:637] /etc/udhcpc.d/50default: Adding DNS 211.136.17.107
[10-01_14:02:11:638] /etc/udhcpc.d/50default: Adding DNS 211.136.20.203
18  4路視頻采集模塊(選配)測(cè)試
# EXEC_FILE=/my-demo/linux-4.1.15/MY_TW6865_DEMO_L4115_MYIMX6A9.out
# ${EXEC_FILE} -x 2 -ot 0 -ol 0 -ow 512 -oh 300 -m 2 &
# ${EXEC_FILE} -x 3 -ot 0 -ol 512 -ow 512 -oh 300 -m 2 &
# ${EXEC_FILE} -x 4 -ot 300 -ol 0 -ow 512 -oh 300 -m 2 &
# ${EXEC_FILE} -x 5 -ot 300 -ol 512 -ow 512 -oh 300 -m 2 &
