STM32F1—HAL庫空氣監測程序
搖籃
2019-1-21 11:58
STM32F1—HAL庫空氣監測程序
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
** This notice applies to any and all portions of this file
* that are not between comment pairs USER CODE BEGIN and
* USER CODE END. Other portions of this file, whether
* inserted by the user or by software development tools
* are owned by their respective copyright owners.
* COPYRIGHT(c) 2019 STMicroelectronics
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "oled.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
uint8_t tx_buf[7]={0x42,0x4d,0xab,0x00,0x00,0x01,0x3a};
uint8_t aRxBuffer[50];
volatile uint8_t CNT=0;
uint16_t PM_VAL;
uint16_t TVOC_VAL_H ;
uint16_t TVOC_VAL_L ;
uint16_t HCHO_VAL_H ;
uint16_t HCHO_VAL_L;
uint16_t CO2_VAL;
uint16_t TEM_VAL_H;
uint16_t TEM_VAL_L;
uint16_t HIM_VAL_H;
uint16_t HIM_VAL_L;
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
TIM_HandleTypeDef htim2;
TIM_HandleTypeDef htim3;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_TIM2_Init(void);
static void MX_TIM3_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_USART1_UART_Init();
MX_TIM2_Init();
MX_TIM3_Init();
/* USER CODE BEGIN 2 */
HAL_TIM_Base_Start_IT(&htim2);
OLED_Init();
OLED_Clear();
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
HAL_UART_Receive_IT(&huart1,(uint8_t*)aRxBuffer,24);
OLED_ShowString(25,0,"AIR-SENSER");
OLED_ShowString(0,2,"CO2:");
OLED_ShowString(65,2,"HH:");
OLED_ShowString(105,2,".");
OLED_ShowString(0,4,"HIM:");
OLED_ShowString(49,4,".");
OLED_ShowString(65,4,"TEM");
OLED_ShowString(113,4,".");
OLED_ShowString(0,6,"TVOC");
OLED_ShowString(41,6,".");
OLED_ShowString(65,6,"PM");
OLED_ShowNum(97,6,PM_VAL,3,12);
OLED_ShowNum(33,2,CO2_VAL,4,12);
OLED_ShowNum(97,4,TEM_VAL_H,2,12);
OLED_ShowNum(121,4,TEM_VAL_L,1,12);
OLED_ShowNum(33,4, HIM_VAL_H,2,12);
OLED_ShowNum(57,4, HIM_VAL_L,1,12);
OLED_ShowNum(97,2, HCHO_VAL_H,1,12);
if(HCHO_VAL_L<10)
OLED_ShowNum(113,2, 0,1,12);
OLED_ShowNum(121,2, HCHO_VAL_L,1,12);
}else OLED_ShowNum(113,2, HCHO_VAL_L,2,12);
OLED_ShowNum(33,6,TVOC_VAL_H,1,12);
if(HCHO_VAL_L<10)
OLED_ShowNum(49,6,0,1,12);
OLED_ShowNum(57,6,TVOC_VAL_L,1,12);
}else OLED_ShowNum(49,6, TVOC_VAL_L,2,12);
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
* @brief TIM2 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM2_Init 0 */
/* USER CODE END TIM2_Init 0 */
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_MasterConfigTypeDef sMasterConfig = {0};
/* USER CODE BEGIN TIM2_Init 1 */
/* USER CODE END TIM2_Init 1 */
htim2.Instance = TIM2;
htim2.Init.Prescaler = 49999;
htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
htim2.Init.Period = 71999;
htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM2_Init 2 */
/* USER CODE END TIM2_Init 2 */
* @brief TIM3 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM3_Init 0 */
/* USER CODE END TIM3_Init 0 */
/* USER CODE BEGIN TIM3_Init 1 */
/* USER CODE END TIM3_Init 1 */
htim3.Instance = TIM3;
htim3.Init.Prescaler = 9999;
htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
htim3.Init.Period = 71999;
htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
Error_Handler();
if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
Error_Handler();
if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM3_Init 2 */
/* USER CODE END TIM3_Init 2 */
* @brief USART1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN USART1_Init 0 */
/* USER CODE END USART1_Init 0 */
/* USER CODE BEGIN USART1_Init 1 */
/* USER CODE END USART1_Init 1 */
huart1.Instance = USART1;
huart1.Init.BaudRate = 9600;
huart1.Init.WordLength = UART_WORDLENGTH_8B;
huart1.Init.StopBits = UART_STOPBITS_1;
huart1.Init.Parity = UART_PARITY_NONE;
huart1.Init.Mode = UART_MODE_TX_RX;
huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart1.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART1_Init 2 */
/* USER CODE END USART1_Init 2 */
* @brief GPIO Initialization Function
* @param None
* @retval None
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOA, CS_Pin|RES_Pin|DC_Pin|D0_Pin
|D1_Pin, GPIO_PIN_SET);
/*Configure GPIO pins : CS_Pin RES_Pin DC_Pin D0_Pin
D1_Pin */
GPIO_InitStruct.Pin = CS_Pin|RES_Pin|DC_Pin|D0_Pin
|D1_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
if(htim==(&htim2)){
HAL_UART_Transmit(&huart1,tx_buf,7,10);
if(htim==(&htim3)){
OLED_ShowNum(105,6,PM_VAL,3,12);
OLED_ShowNum(25,2,CO2_VAL,3,12);
OLED_ShowNum(89,2,TEM_VAL_H,2,12);
OLED_ShowNum(113,2,TEM_VAL_L,2,12);
OLED_ShowNum(25,4, HIM_VAL_H,2,12);
OLED_ShowNum(49,4, HIM_VAL_L,2,12);
OLED_ShowNum(97,4, HCHO_VAL_H,2,12);
OLED_ShowNum(113,4, HCHO_VAL_L,2,12);
OLED_ShowNum(33,6,TVOC_VAL_H,2,12);
OLED_ShowNum(57,6,TVOC_VAL_L,2,12);
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
UNUSED(huart);
uint16_t t;
uint16_t WAIT_C=0;
uint16_t CH;
if(aRxBuffer[0]==0x42&&aRxBuffer[1]==0x4d)
for(t=0;t<22;t++)
WAIT_C+=aRxBuffer[t];
CH=(aRxBuffer[22]<<8)+aRxBuffer[23];
if(WAIT_C==CH)
PM_VAL=((aRxBuffer[4])<<8)+aRxBuffer[5];
TVOC_VAL_H=((aRxBuffer[6]<<8)+aRxBuffer[7])/100;
TVOC_VAL_L=((aRxBuffer[6]<<8)+aRxBuffer[7])%100;
HCHO_VAL_H=((aRxBuffer[9]<<8)+aRxBuffer[10])/100;
HCHO_VAL_L=((aRxBuffer[9]<<8)+aRxBuffer[10])%100;
CO2_VAL=(aRxBuffer[12]<<8)+aRxBuffer[13];
TEM_VAL_H=((aRxBuffer[14]<<8)+aRxBuffer[15])/10;
TEM_VAL_L=((aRxBuffer[14]<<8)+aRxBuffer[15])%10;
HIM_VAL_H=((aRxBuffer[16]<<8)+aRxBuffer[17])/10;
HIM_VAL_L=((aRxBuffer[16]<<8)+aRxBuffer[17])%10;
CNT=0;
else CNT=0;
else CNT=0;
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
