標(biāo)題: 單片機(jī)門(mén)禁系統(tǒng)仿真不出來(lái) 求幫助 [打印本頁(yè)]
作者: w7016203w 時(shí)間: 2019-1-9 10:33
#include<reg52.h>
#include<intrins.h>
#define uintunsigned int
#define ucharunsigned char
ucharnum,count,wordbuf[4],pwbuf[4],pw[4],i,flag,tt,a,k;
uchartemp,mima,j,key,key1,key2,key3,key4,key5,key6,key7,key8,key9,key10,key11,key12,key13,key14,key15,key16;
uchar codetable[]={0x79,0x77,0x77,0x3f,0x77,0x3f,0x73,0x79,0x37,0x40,0x76};
uchar codetable1[]={0x3f,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x67};
bit pwflag;
bit enterflag;
bit removeflag;
bit zhuhuflag;
bit fangkeflag;
sbit sda=P2^7;
sbit scl=P2^6;
void dylen(uintz);
void init();
voidwrite_add(uchar address,uchar date);
ucharread_add(uchar address);
voidxianshierror();
voidxianshiopen();
voidxianshigang();
voidxianshimima();
voidxianshishuzi();
void jzkey();
void zhuhu();
void fangke();
void mmbj();
void hujiao();
main()
P1=0X00;
P1=0x04;
//初始密碼
pw[0]=1;
pw[1]=2;
pw[2]=3;
pw[3]=4;
enterflag=0;
removeflag=0;
//定時(shí)中斷
tt=0;
TMOD=0X01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
init();//24c02初始化
for(k=0;k<4;k++) //寫(xiě)入AT24C02
write_add(23+k,pw[k]);
dylen(1000);
pw[k]=read_add(23+k);
jzkey();
zhuhu();
fangke();
mmbj();
hujiao();
if(removeflag==1)
count=0;
flag=3;
P1=0X04;
key14=0;
xianshigang();
void hujiao() //呼叫子程序
if(key14==1)
a=pwbuf[count]+pwbuf[count-1]+pwbuf[count-2]-1;
switch(a)
case 2:
P1=0x12;
break;
case 3:
P1=0x22;
break;
case 4:
P1=0x32;
break;
case 5:
P1=0x42;
break;
case 6:
P1=0x52;
break;
case 7:
P1=0x62;
break;
case 8:
P1=0x72;
break;
void mmbj() //密碼比較子程序
if(enterflag==1)
count=0;
enterflag=0;
for(i=0;i<4;i++)
if(pw==pwbuf)
flag=1;
flag=2;
P1=0x01;//同speaker=1報(bào)警聲;
i=4;
if(flag==1)
xianshiopen();
P1=0x08;
if(flag==2)
xianshierror();
void fangke() //訪客子程序
if(key15==1)
fangkeflag=1;
xianshigang();
if(fangkeflag==1)
xianshishuzi();
zhuhuflag=0;
void zhuhu() //住戶(hù)子程序
if(key16==1)
zhuhuflag=1;
xianshigang();
if(zhuhuflag==1)
xianshimima();
fangkeflag=0;
voidxianshierror() //顯示錯(cuò)誤提示
P2=0xfe,P0=table[9],dylen(5),P2=0xff;
P2=0xfd,P0=table[0],dylen(5),P2=0xff;
P2=0xfb,P0=table[1],dylen(5),P2=0xff;
P2=0xf7,P0=table[2],dylen(5),P2=0xff;
P2=0xef,P0=table[3],dylen(5),P2=0xff;
P2=0xdf,P0=table[4],dylen(5),P2=0xff;
voidxianshiopen()
P2=0xfd,P0=table[9],dylen(5),P2=0xff;
P2=0xfb,P0=table[5],dylen(5),P2=0xff;
P2=0xf7,P0=table[6],dylen(5),P2=0xff;
P2=0xef,P0=table[7],dylen(5),P2=0xff;
P2=0xdf,P0=table[8],dylen(5),P2=0xff;
voidxianshigang()
P2=0xfb,P0=table[9],dylen(5),P2=0xff;
P2=0xf7,P0=table[9],dylen(5),P2=0xff;
P2=0xef,P0=table[9],dylen(5),P2=0xff;
P2=0xdf,P0=table[9],dylen(5),P2=0xff;
voidxianshimima() //顯示密碼保護(hù)
if(count==1)
P2=0xdf,P0=table[10],dylen(5),P2=0xff;
if(count==2)
P2=0xef,P0=table[10],dylen(5),P2=0xff;
if(count==3)
P2=0xf7,P0=table[10],dylen(5),P2=0xff;
if(count==4)
P2=0xfb,P0=table[10],dylen(5),P2=0xff;
voidxianshishuzi() //顯示數(shù)字門(mén)號(hào)
if(count==1)
P2=0xdf,P0=table1[pwbuf[count]],dylen(5),P2=0xff;
if(count==2)
P2=0xdf,P0=table1[pwbuf[count-1]],dylen(5),P2=0xff;
P2=0xef,P0=table1[pwbuf[count]],dylen(5),P2=0xff;
if(count==3)
P2=0xef,P0=table1[pwbuf[count-2]],dylen(5),P2=0xff;
P2=0xf7,P0=table1[pwbuf[count-3]],dylen(5),P2=0xff;
void dylen(uintz)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void jzkey() //矩陣鍵盤(pán)
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
dylen(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case0xee:
pwbuf[count]=0,count++,key16=2,key15=2,removeflag=0;
break;
case 0xde:
pwbuf[count]=1,count++,key16=2,key15=2,removeflag=0;
break;
case 0xbe:
pwbuf[count]=2,count++,key16=2,key15=2,removeflag=0;
break;
case 0x7e:
pwbuf[count]=3,count++,key16=2,key15=2,removeflag=0;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
dylen(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case0xed:
pwbuf[count]=4,count++,key16=2,key15=2,removeflag=0;
break;
case 0xdd:
pwbuf[count]=5,count++,key16=2,key15=2,removeflag=0;
break;
case 0xbd:
pwbuf[count]=6,count++,key16=2,key15=2,removeflag=0;
break;
case 0x7d:
pwbuf[count]=7,count++,key16=2,key15=2,removeflag=0;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
dylen(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case0xeb:
pwbuf[count]=8,count++,key16=2,key15=2,removeflag=0;
break;
case 0xdb:
pwbuf[count]=9,count++,key16=2,key15=2,removeflag=0;
break;
case 0xbb:
enterflag=1,key16=2,key15=2;
break;
case 0x7b:
removeflag=1,key16=2,key15=2;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
dylen(10);
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
temp=P3;
switch(temp)
case0xe7:
key13=12,key16=2,key15=2;
break;
case 0xd7:
key14=1,key16=2,key15=2;
break;
case 0xb7:
key15=1,key16=2;
break;
case 0x77:
key16=1,key15=2;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
void zd()interrupt 1
tt++;
//-------------------------------------------//AT24C02
uchar a;
void delay()
void start() //開(kāi)始信號(hào)
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop() //停止
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
voidrespons() //應(yīng)答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))i++;
scl=0;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
voidwrite_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
delay();
// scl=0;
// delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
k=(k<<1)|sda;
scl=0;
delay();
return k;
void delay1(ucharx)
uchar a,b;
for(a=x;a>0;a--)
for(b=100;b>0;b--);
void write_add(ucharaddress,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
(33.62 KB, 下載次數(shù): 41)
2019-1-9 10:32 上傳
數(shù)碼管顯示不出
作者: 小貓貓愛(ài)吃魚(yú) 時(shí)間: 2019-1-10 21:49
你好!
你這沒(méi)頭沒(méi)尾的發(fā)這么一大堆程序,
也不把功能和設(shè)計(jì)要求說(shuō)明,
讓大家怎么知道你是在做什么!
需要幫助,加 QQ 3205931140
作者: Arvin0011 時(shí)間: 2019-2-11 12:36
資料不夠詳細(xì)
作者: 3090358112 時(shí)間: 2025-4-7 14:15
Proteus仿真看不清
