為什么在仿真上面程序能夠跑起來(lái),但是實(shí)物焊接出來(lái),顯示屏一是只亮背光
[打印本頁(yè)]
skcxks
時(shí)間:
2019-1-7 00:11
#include "reg51.h"
#define Port P2 //定義數(shù)據(jù)端口
sbit begin=P3^2;
sbit RS=P3^5; //定義和LCD的連接端口,寫(xiě)數(shù)據(jù)指令端口
sbit RW=P3^6; //讀寫(xiě)端口
sbit E=P3^7; //使能端口
sbit Busy=P2^7; //讀忙端口
uchar min=40,sec=0,count=0;
uchar a=0,b=0;
uchar str[]="0123456789";
uchar str1[16]="Team A: **";
uchar str2[16]="Team B: **";
//延時(shí)函數(shù)
void delay()
uchar i,j; //延時(shí)變量
for(i=0;i<50;i++) //t表示循環(huán)次數(shù)
for(j=0;j<100;j++) ;
// 讀忙信號(hào)判斷
void Read_Busy(void)
uchar k=255;
Port=0xff;
RS = 0;
RW = 1;
E = 1;
while((k--)&&(Busy));
E = 0;
// 寫(xiě)指令函數(shù)
void Write_Comm(uchar lcdcomm)
Read_Busy( ); //先讀忙
RS = 0; //端口定義為寫(xiě)指令
RW = 0;//端口寫(xiě)入使能
E = 1; //端口輸入總使能
Port=lcdcomm; //數(shù)據(jù)端送指令
E = 0; //端口輸入總禁止
//寫(xiě)數(shù)據(jù)函數(shù)
void Write_Chr(uchar lcddata)
Read_Busy( ); //先讀忙
RS = 1;//端口寫(xiě)數(shù)據(jù)使能
E = 1;//端口總輸入使能
Port = lcddata; //數(shù)據(jù)端口送數(shù)據(jù)
E = 0; //端口總輸入禁止
//初始化LCD
void Init_LCD(void)
delay(); //稍微延時(shí),等待LCD進(jìn)入工作狀態(tài)
Write_Comm(0x38); //8位2行5*8
Write_Comm(0x0c); //顯示開(kāi)/關(guān),光標(biāo)開(kāi)閃爍開(kāi)
Write_Comm(0x01);//清顯示
Write_Comm(0x02); //光標(biāo)歸位
void t0() interrupt 1
count++;
if(count==20)
sec--;
count=0;
if(sec==0)
min--;
sec=59;
if(min==0)
TR0=0;
min=0;
sec=0;
void ex0() interrupt 0
TR0=~TR0;
while(begin==0);
void scankey()//負(fù)責(zé)改變比分
switch(P1)
case 0xfe:
a=a+1;
if(a>99)a=99;
break;
case 0xfd:
a=a+2;
if(a>99)a=99;
break;
case 0xfb:
a=a+3;
if(a>99)a=99;
break;
case 0xf7:
if(a>0)a=a-1;
break;
case 0xef:
b=b+1;
if(b>99)b=99;
break;
case 0xdf:
b=b+2;
if(b>99)b=99;
break;
case 0xbf:
b=b+3;
if(b>99)b=99;
break;
case 0x7f:
if(b>0)b=b-1;
break;
while(P1!=0xff);
void display()//負(fù)責(zé)送顯
uchar m;
str1[8]=str[a/10];
str1[9]=str[a%10];
str1[14]=str[min/10];
str1[15]=str[min%10];
Write_Comm(0x80);
for(m=0;m<16;m++)
Write_Chr(str1[m]);
str2[8]=str[b/10];
str2[9]=str[b%10];
str2[14]=str[sec/10];
str2[15]=str[sec%10];
Write_Comm(0xc0);
for(m=0;m<16;m++)
Write_Chr(str2[m]);
EA=1;
EX0=1;
ET0=1;
TMOD=0x01;
TH0=-50000/256;
TL0=-50000%256;
TR0=0;
Init_LCD();
scankey();
display();
skcxks
時(shí)間:
2019-1-7 00:13
哪里出錯(cuò)了嗎?為什么在仿真上面程序能夠跑起來(lái),但是實(shí)物焊接出來(lái),顯示屏一是只亮背光,二是只有一個(gè)一字出現(xiàn),是延時(shí)出錯(cuò)了,還是對(duì)比度的可調(diào)電阻出錯(cuò)?
yzwzfyz
時(shí)間:
2019-1-7 07:51
這就是“仿”的真諦。
與你的硬件相關(guān)。硬件未必與“仿”的完全一樣。
需要你仔細(xì)研讀硬件的手冊(cè),找出區(qū)別之所在。
楊雪飛
時(shí)間:
2019-1-7 08:38
這是1602顯示,看描述應(yīng)該重點(diǎn)檢查接線(xiàn),或者換LCD,不像是對(duì)比度電阻的問(wèn)題。不過(guò)首先調(diào)整一下對(duì)比度電阻,我沒(méi)用可調(diào),一般120Ω電阻接VSS既可,試了多塊LCD這個(gè)電阻值基本都能達(dá)到最佳狀態(tài)。對(duì)比度沒(méi)有問(wèn)題那就是接線(xiàn)不良。另外也見(jiàn)程序不通用的1602,極少,不知道你遇得上了不是。建議先用最簡(jiǎn)例程點(diǎn)屏正常了再試程序。
笑天我
時(shí)間:
2019-1-7 15:08
我之前也遇到過(guò),我將P0口接了上拉電阻,隨便將可調(diào)電阻重新接了一下就好了
