標題: arduino超聲波傳感器代碼 [打印本頁]
作者: h124020135    時間: 2019-1-1 16:38
標題: arduino超聲波傳感器代碼
int trigger_pin = 2;
int echo_pin = 3;
int led_pin = 10;
int time;
int distance;
void setup ( ) {
        Serial.begin (9600);
        pinMode (trigger_pin, OUTPUT);
        pinMode (echo_pin, INPUT);
        pinMode (led_pin, OUTPUT);
void loop ( ) {
    digitalWrite (trigger_pin, HIGH);
    delayMicroseconds (10);
    digitalWrite (trigger_pin, LOW);
    time = pulseIn (echo_pin, HIGH);
    distance = (time * 0.034) / 2;
  if (distance <= 20)
        Serial.println (" Door Open ");
        Serial.print (" Distance= ");
        Serial.println (distance);
        digitalWrite (led_pin, HIGH);
        delay (500);
  else {
        Serial.println (" Door closed ");
        digitalWrite (led_pin, LOW);
        delay (500);
作者: admin    時間: 2019-1-1 20:36
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
