標題: 單片機舵機按鍵控制程序單片機問題 [打印本頁]
作者: J.C.Maxwell    時間: 2018-12-10 10:43
STC89C52RC單片機控制六路舵機的按鍵程序怎么寫?     是這樣嗎?
  1. #include <reg52.h>
  2. #include <math.h>
  3. typedef unsigned char uchar;
  4. typedef unsigned int uint;
  5. uchar flag1;                                                        //舵機按鍵標志
  6. uchar flag2;                                                        //舵機按鍵標志
  7. uchar flag3;                                                        //舵機按鍵標志
  8. uchar flag4;                                                        //舵機按鍵標志
  9. uchar flag5;                                                        //舵機按鍵標志
  10. uchar flag6;                                                        //舵機按鍵標志
  11. uchar order=0;
  12. sbit  KEY1_1=P1^0;                  //第一路按鍵1
  13. sbit  KEY1_2=P1^1;                  //第一路按鍵2
  14. sbit PWM_OUT1=P2^1;                  //第一路PWM輸出口
  15. sbit  KEY2_1=P1^2;        //第二路按鍵1
  16. sbit  KEY2_2=P1^3;        //第二路按鍵2
  17. sbit PWM_OUT2=P2^2;       //第二路PWM輸出口
  18. sbit  KEY3_1=P1^4;        //第三路按鍵1
  19. sbit  KEY3_2=P1^5;        //第三路按鍵2
  20. sbit PWM_OUT3=P2^3;       //第三路PWM輸出口
  21. sbit  KEY4_1=P1^6;        //第四路按鍵1
  22. sbit  KEY4_2=P1^7;        //第四路按鍵2
  23. sbit PWM_OUT4=P2^4;       //第四路PWM輸出口
  24. sbit  KEY5_1=P3^2;        //第五路按鍵1
  25. sbit  KEY5_2=P3^3;        //第五路按鍵2
  26. sbit PWM_OUT5=P2^5;       //第五路PWM輸出口
  27. sbit  KEY6_1=P3^4;        //第六路按鍵1
  28. sbit  KEY6_2=P3^5;        //第六路按鍵2
  29. sbit PWM_OUT6=P2^6;       //第六路PWM輸出口
  30. uint PWM_Value1;                                    //定義pwm值
  31. uint PWM_Value2;
  32. uint PWM_Value3;
  33. uint PWM_Value4;
  34. uint PWM_Value5;
  35. uint PWM_Value6;
  36.
  37. void Delay(unsigned int s)          //延遲子函數
  38. {
  39.   unsigned int i;
  40.   for(i=0; i<s; i++);
  41.   for(i=0; i<s; i++);
  42. }
  43. /*定時器初始化*/
  44. void Init_Timer0()
  45. {
  46.   TMOD=0x11;
  47.   TH0=(65536-1500)/256;
  48.   TL0=(65536-1500)%256;
  49.   EA = 1;
  50.   ET0 = 1;
  51.   TR0 = 1;
  52.   PT0=1;
  53. }
  54. /*主函數*/
  55. void main(void)
  56. {
  57.   Delay(6000);
  58.   PWM_Value1 = 1250;                                        //pwm初值為1500
  59.   PWM_Value2 = 1250;
  60.   PWM_Value3 = 1250;
  61.   PWM_Value4 = 1250;
  62.   PWM_Value5 = 1250;
  63.   PWM_Value6 = 1250;
  64.   Init_Timer0();
  65.   while(1)
  66.   {
  67.            /*第一路*/
  68.            if((KEY1_1 ==0 )||(KEY1_2 ==0 ))                                                        //按鍵1或按鍵2被按下
  69.               {
  70.                 if(KEY1_1 ==0 )        //確認按鍵1被按下
  71.                    {
  72.                      flag1 = 1;        //標志位賦值1
  73.                    }
  74.                 if(KEY1_2 ==0 )        //確認按鍵2被按下
  75.                    {
  76.                      flag1 = 2;        //標志位賦值2
  77.                    }
  78.               }
  79.           else
  80.               {
  81.                 flag1 = 0;        //否則標志位為0
  82.               }
  83.               Delay(20);        //延時20ms
  84.
  85.                    /*第二路*/
  86.            if((KEY2_1 ==0 )||(KEY2_2 ==0 ))                                                        //按鍵1或按鍵2被按下
  87.               {
  88.                 if(KEY2_1 ==0 )        //確認按鍵1被按下
  89.                    {
  90.                     flag2 = 1;        //標志位賦值1
  91.                    }
  92.                if(KEY2_2 ==0 )        //確認按鍵2被按下
  93.                    {
  94.                     flag2 = 2;        //標志位賦值2
  95.                    }
  96.              }
  97.            else
  98.              {
  99.               flag2 = 0;        //否則標志位為0
  100.              }
  101.               Delay(20);        //延時20ms
  102.                    /*第三路*/
  103.                   if((KEY3_1 ==0 )||(KEY3_2 ==0 ))                                                        //按鍵1或按鍵2被按下
  104.              {
  105.                if(KEY3_1 ==0 )        //確認按鍵1被按下
  106.                   {
  107.                    flag3 = 1;        //標志位賦值1
  108.                   }
  109.               if(KEY3_2 ==0 )        //確認按鍵2被按下
  110.                   {
  111.                    flag3 = 2;        //標志位賦值2
  112.                   }
  113.             }
  114.          else
  115.             {
  116.               flag3 = 0;        //否則標志位為0
  117.             }
  118.              Delay(20);        //延時20ms
  119.                   /*第四路*/
  120.                    if((KEY4_1 ==0 )||(KEY4_2 ==0 ))                                                        //按鍵1或按鍵2被按下
  121.             {
  122.               if(KEY4_1 ==0 )        //確認按鍵1被按下
  123.                 {
  124.                  flag4 = 1;        //標志位賦值1
  125.                 }
  126.              if(KEY4_2 ==0 )        //確認按鍵2被按下
  127.                 {
  128.                  flag4 = 2;        //標志位賦值2
  129.                 }
  130.             }
  131.           else
  132.             {
  133.              flag4 = 0;        //否則標志位為0
  134.             }
  135.              Delay(20);        //延時20ms
  136.                      /*第五路*/
  137.                       if((KEY5_1 ==0 )||(KEY5_2 ==0 ))                                                        //按鍵1或按鍵2被按下
  138.               {
  139.                if(KEY5_1 ==0 )        //確認按鍵1被按下
  140.                   {
  141.                    flag5 = 1;        //標志位賦值1
  142.                   }
  143.                if(KEY5_2 ==0 )        //確認按鍵2被按下
  144.                   {
  145.                    flag5 = 2;        //標志位賦值2
  146.                   }
  147.              }
  148.           else
  149.              {
  150.               flag5 = 0;        //否則標志位為0
  151.              }
  152.               Delay(20);        //延時20ms
  153.                          /*第六路*/
  154.                            if((KEY6_1 ==0 )||(KEY6_2 ==0 ))                                                        //按鍵1或按鍵2被按下
  155.                {
  156.                 if(KEY6_1 ==0 )        //確認按鍵1被按下
  157.                    {
  158.                     flag6 = 1;        //標志位賦值1
  159.                    }
  160.                if(KEY6_2 ==0 )        //確認按鍵2被按下
  161.                   {
  162.                    flag6 = 2;        //標志位賦值2
  163.                   }
  164.               }
  165.             else
  166.               {
  167.                flag6 = 0;        //否則標志位為0
  168.               }
  169.                Delay(20);        //延時20ms
  170.   }
  171. }
  172.
  173. /*****中斷程序*******/
  174. void timer0(void) interrupt 1
  175. {
  176.    if(flag1==1)        PWM_Value1 += 10;                                                        //如果標志位為1時,pwm的值加1
  177.    if(flag1==2)        PWM_Value1 -= 10;                                                        //如果標志位為2時,pwm的值減1
  178.    if(PWM_Value1>=2500)        //如果pwm的值大于2500
  179.    PWM_Value1 = 2500;        //則保持在2500
  180.    if(PWM_Value1<=500)        //如果pwm的值小于500
  181.    PWM_Value1=500;        //則保持在500
  182.    if(flag2==1)        PWM_Value2 += 10;                                                        //如果標志位為1時,pwm的值加1
  183.    if(flag2==2)        PWM_Value2 -= 10;                                                        //如果標志位為2時,pwm的值減1
  184.    if(PWM_Value2>=2500)        //如果pwm的值大于2500
  185.    PWM_Value2 = 2500;        //則保持在2500
  186.    if(PWM_Value2<=500)        //如果pwm的值小于500
  187.    PWM_Value2=500;        //則保持在500
  188.    if(flag3==1)        PWM_Value3 += 10;                                                        //如果標志位為1時,pwm的值加1
  189.    if(flag3==2)        PWM_Value3 -= 10;                                                        //如果標志位為2時,pwm的值減1
  190.    if(PWM_Value3>=2500)        //如果pwm的值大于2500
  191.    PWM_Value3 = 2500;        //則保持在2500
  192.    if(PWM_Value3<=500)        //如果pwm的值小于500
  193.    PWM_Value3=500;        //則保持在500
  194.    if(flag4==1)        PWM_Value4 += 10;                                                        //如果標志位為1時,pwm的值加1
  195.    if(flag4==2)        PWM_Value4 -= 10;                                                        //如果標志位為2時,pwm的值減1
  196.    if(PWM_Value4>=2500)        //如果pwm的值大于2500
  197.    PWM_Value4 = 2500;        //則保持在2500
  198.    if(PWM_Value4<=500)        //如果pwm的值小于500
  199.    PWM_Value4=500;        //則保持在500
  200.    if(flag5==1)        PWM_Value5 += 10;                                                        //如果標志位為1時,pwm的值加1
  201.    if(flag5==2)        PWM_Value5 -= 10;                                                        //如果標志位為2時,pwm的值減1
  202.    if(PWM_Value5>=2500)        //如果pwm的值大于2500
  203.    PWM_Value5 = 2500;        //則保持在2500
  204.    if(PWM_Value5<=500)        //如果pwm的值小于500
  205.    PWM_Value5=500;        //則保持在500
  206.    if(flag6==1)        PWM_Value6 += 10;                                                        //如果標志位為1時,pwm的值加1
  207.    if(flag6==2)        PWM_Value6 -= 10;                                                        //如果標志位為2時,pwm的值減1
  208.    if(PWM_Value6>=2500)        //如果pwm的值大于2500
  209.    PWM_Value6 = 2500;        //則保持在2500
  210.    if(PWM_Value6<=500)        //如果pwm的值小于500
  211.    PWM_Value6=500;        //則保持在500
  212.         switch(order)
  213.
  214.         {
  215.
  216.                 case 1:(PWM_OUT1=1);
  217.
  218.                            TH0=(65536-PWM_Value1)>>8;
  219.
  220.                            TL0=(uchar)(65536-PWM_Value1);
  221.
  222.                            break;
  223.
  224.                 case 2:(PWM_OUT1=0);
  225.
  226.                            TH0=(65536-(5000-PWM_Value1))>>8;
  227.
  228.                            TL0=(uchar)(65536-(5000-PWM_Value1));
  229.
  230.                            break;
  231.                    case 3:
  232.
  233.                            TH0=60536>>8;
  234.
  235.                            TL0=(uchar)60536;
  236.
  237.                            break;
  238.
  239.                 case 4:
  240.
  241.                            TH0=60536>>8;
  242.
  243.                            TL0=(uchar)60536;
  244.
  245.                            order=0;
  246.
  247.                            break;
  248.
  249.                  case 5:(PWM_OUT2=1);
  250.
  251.                            TH0=(65536-PWM_Value2)>>8;
  252.
  253.                            TL0=(uchar)(65536-PWM_Value2);
  254.
  255.                            break;
  256.
  257.                 case 6:(PWM_OUT2=0);
  258.
  259.                            TH0=(65536-(5000-PWM_Value2))>>8;
  260.
  261.                            TL0=(uchar)(65536-(5000-PWM_Value2));
  262.
  263.                            break;
  264.                    case 7:
  265.
  266.                            TH0=60536>>8;
  267.
  268.                            TL0=(uchar)60536;
  269.
  270.                            break;
  271.
  272.                 case 8:
  273.
  274.                            TH0=60536>>8;
  275.
  276.                            TL0=(uchar)60536;
  277.
  278.                            order=0;
  279.
  280.                            break;
  281.                 case 9:(PWM_OUT3=1);
  282.
  283.                            TH0=(65536-PWM_Value3)>>8;
  284.
  285.                            TL0=(uchar)(65536-PWM_Value3);
  286.
  287.                            break;
  288.
  289.                 case 10:(PWM_OUT3=0);
  290.
  291.                            TH0=(65536-(5000-PWM_Value3))>>8;
  292.
  293.                            TL0=(uchar)(65536-(5000-PWM_Value3));
  294.
  295.                            break;
  296.                 case 11:
  297.
  298.                            TH0=60536>>8;
  299.
  300.                            TL0=(uchar)60536;
  301.
  302.                            break;
  303.
  304.                 case 12:
  305.
  306.                            TH0=60536>>8;
  307.
  308.                            TL0=(uchar)60536;
  309.
  310.                            order=0;
  311.
  312.                            break;
  313.                 case 13:(PWM_OUT4=1);
  314.
  315.                            TH0=(65536-PWM_Value4)>>8;
  316.
  317.                            TL0=(uchar)(65536-PWM_Value4);
  318.
  319.                            break;
  320.
  321.                 case 14:(PWM_OUT4=0);
  322.
  323.                            TH0=(65536-(5000-PWM_Value4))>>8;
  324.
  325.                            TL0=(uchar)(65536-(5000-PWM_Value4));
  326.
  327.                            break;
  328.                 case 15:
  329.
  330.                            TH0=60536>>8;
  331.
  332.                            TL0=(uchar)60536;
  333.
  334.                            break;
  335.
  336.                 case 16:
  337.
  338.                            TH0=60536>>8;
  339.
  340.                            TL0=(uchar)60536;
  341.
  342.                            order=0;
  343.
  344.                            break;
  345.
  346.                 case 17:(PWM_OUT5=1);
  347.
  348.                            TH0=(65536-PWM_Value5)>>8;
  349.
  350.                            TL0=(uchar)(65536-PWM_Value5);
  351.
  352.                            break;
  353.
  354.                 case 18:(PWM_OUT5=0);
  355.
  356.                            TH0=(65536-(5000-PWM_Value5))>>8;
  357.
  358.                            TL0=(uchar)(65536-(5000-PWM_Value5));
  359.
  360.                            break;
  361.                    case 19:
  362.
  363.                            TH0=60536>>8;
  364.
  365.                            TL0=(uchar)60536;
  366.
  367.                            break;
  368.
  369.                 case 20:
  370.
  371.                            TH0=60536>>8;
  372.
  373.                            TL0=(uchar)60536;
  374.
  375.                            order=0;
  376.
  377.                            break;
  378.                 case 21:(PWM_OUT6=1);
  379.                            TH0=(65536-PWM_Value6)>>8;
  380.                            TL0=(uchar)(65536-PWM_Value6);
  381.                            break;
  382.                 case 22:(PWM_OUT6=0);
  383.                            TH0=(65536-(5000-PWM_Value6))>>8;
  384.                            TL0=(uchar)(65536-(5000-PWM_Value6));
  385.                            break;
  386.                 case 23:
  387.                            TH0=60536>>8;
  388.                            TL0=(uchar)60536;
  389.                            break;
  390.                 case 24:
  391.                            TH0=60536>>8;
  392.                            TL0=(uchar)60536;
  393.                            order=0;
  394.                            break;
  395.         default: order=0;
  396.                            break;
  397.         }
  398.         order++;
  399. }
作者: 1ZAQ    時間: 2024-5-9 14:36
可以,沒什么問題
作者: clclcl123    時間: 2024-5-9 15:54
是這樣寫的
作者: Hephaestus    時間: 2024-5-11 22:12
你親自測試一下不就知道好用不好用了嗎?
