程序如下,按下into0鍵后顯示情況如圖(附件)
#include<reg52.h>
#include<51hei.h>
uchar code table1[]=" 2012-04-23 TUR";
uchar code table2[]=" 00:00:00";
sbit duan=P2^6;
sbit wei=P2^7;
sbit lcdrs=P3^5;
sbit lcden=P3^4;
//sbit key=P3^7;
sbit key1=P3^2;
sbit key2=P3^6;
sbit key3=P3^7;
uchar count,shi,fen,miao,keynum;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_cmd(uchar cmd)
lcdrs=0;
// lcden=0;
P0=cmd;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_dat(uchar dat)
lcdrs=1;
// lcden=0;
P0=dat;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
guandz();
guanled();
duan=0;
wei=0;
lcden=0;
keynum=0;
// miao=59;
// fen=58;
// shi=23;
write_cmd(0x38);
write_cmd(0x0c);
write_cmd(0x06);
write_cmd(0x01);
write_cmd(0x80);
for(num=0;num<15;num++)
write_dat(table1[num]);
delay(20);
write_cmd(0x80+40);
for(num=0;num<12;num++)
write_dat(table2[num]);
delay(20);
TMOD=0X01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_sfm(uchar add,uchar dat)
uchar shi,ge;
shi=dat/10;
ge=dat%10;
write_cmd(0x80+0x40+add);
write_dat(0x30+shi);
write_dat(0x30+ge);
void keyscan()
// key=0;
if(key1==0)
delay(5);
if(key1==0)
keynum++;
while(!key1);
if(keynum==1)
TR0=0;
write_cmd(0x80+0x40+11);
write_cmd(0x0f);
if(keynum==2)
write_cmd(0x80+0x40+8);
if(keynum==3)
write_cmd(0x80+0x40+5);
if(keynum==4)
keynum=0;
write_cmd(0x0c);
TR0=1;
init();
keyscan();
if(count==20)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_sfm(7,fen);
write_sfm(10,miao);
void timer0() interrupt 1
count++;
