#include <reg51.h>
#include <intrins.h>
#define LCD_data P0 //數據口
sbit LCD_RS = P3^5; //寄存器選擇輸入
sbit LCD_RW = P2^0; //液晶讀/寫控制
sbit LCD_EN = P3^4; //液晶使能控制
sbit LCD_PSB = P2^1; //串/并方式控制
sbit wela = P2^7;
sbit dula = P2^6; //關閉LED燈
sbit wr=P3^6;
sbit rd=P3^7;
sbit fm=P2^3;
uint temp;
uchar p=3,q=1,jianzhi;
uint a1,a2,a3,date,q1;
uchar code dis1[] = {"畢業設計電子秤"};
uchar code dis2[] = {"單價:"};
uchar code dis3[] = {"重量:"};
uchar code dis4[] = {"總價:"};
uchar code table[]="0123456789";
uchar code table1[]="Kg";
uchar code table2[]={"元"};
uchar code dis5[] = {"2012畢業設計電子秤"};
uchar code dis6[] = {"姓名:錢志偉"};
uchar code dis7[] = {"學號:5901108126"};
uchar code dis8[] = {"歡迎老師批評指正"};
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};//宏定義延時4個CPU
uchar IRDIS[2];
uchar IRCOM[4];
void delay0(uchar x); //x*0.14MS
void beep();
void dataconv();
void lcd_pos(uchar X,uchar Y); //確定顯示位置
uint AD_read();
key_read ();
void disp_ad();
void disp_dy();
void disp_kj();
void disp_jianpan(uchar jian);
void disp_zongjia(uint qian);
void delay(int ms)
while(ms--)
uchar i;
for(i=0;i<250;i++)
_nop_();
_nop_();
_nop_();
_nop_();
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*寫指令數據到LCD */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/*寫顯示數據到LCD */
/*RS=H,RW=L,E=高脈沖,D0-D7=數據。 */
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void lcd_init()
LCD_PSB = 1; //并口方式
lcd_wcmd(0x34); //擴充指令操作
delay(5);
lcd_wcmd(0x30); //基本指令操作
delay(5);
lcd_wcmd(0x0F); //顯示開,開光標
delay(5);
lcd_wcmd(0x01); //清除LCD的顯示內容
delay(5);
main()
uchar w;
uchar jiage[3];
delay(10); //延時
wela=0;
dula=0;
lcd_init(); //初始化LCD
disp_kj();//開機界面的顯示
delay(500);
disp_dy();//顯示價格重量等固定的文字
disp_ad();//AD轉換值的顯示
while(q)//判斷標志位q是否為0,為0表示鍵盤按了確定鍵
{ uchar n=2;
w=key_read ();//調出鍵值
disp_jianpan(w);//將鍵值顯示
jiage[n]=jianzhi;//將鍵值存入數組中
p++;
n--;
q=1;
p=3;
q1=jiage[2]*100+jiage[1]*10+jiage[0];//得到按鍵數
disp_zongjia(q1);//總價的計算和顯示
void delay0(uchar x) //x*0.14MS
uchar i;
while(x--)
for (i = 0; i<13; i++) {}
uchar pos;
if (X==0)
{X=0x80;}
else if (X==1)
{X=0x90;}
else if (X==2)
{X=0x88;}
else if (X==3)
{X=0x98;}
pos = X+Y ;
lcd_wcmd(pos); //顯示地址
/*AD轉換函數*/
uint AD_read()
wela=1;
P0=0;
_nop_();
wr=0;
_nop_();
wr=1;
P0=0xff;
delay(10);
P0=0;
rd=0;
_nop_();
P1=0xff;
temp=P1;
return temp;
/*鍵盤掃描程序*/
key_read ()
unsigned char key,key1;
P3=0xfe;//給P3.0一個低電平
key1=P3;
key1=key1&0xf0;
if(key1!=0xf0)
delay(10);//取抖
if(key1!=0xf0)
key1=P3;
switch(key1)
case 0xee://選中0號鍵
key=0;
break;
case 0xde://選中1號鍵
key=1;
break;
case 0xbe://選中2號鍵
key=2;
break;
case 0x7e://選中3號鍵
key=3;
break;
P3=0xfd;//給P3.1一個低電平
key1=P3;
key1=key1&0xf0;
if(key1!=0xf0)
delay(10);//取抖
if(key1!=0xf0)
key1=P3;
switch(key1)
case 0xed://選中4號鍵
key=4;
break;
case 0xdd://選中5號鍵
key=5;
break;
case 0xbd://選中6號鍵
key=6;
break;
case 0x7d://選中7號鍵
key=7;
break;
P3=0xfb;//給P3.2一個低電平
key1=P3;
key1=key1&0xf0;
if(key1!=0xf0)
delay(10);//取抖
if(key1!=0xf0)
key1=P3;
switch(key1)
case 0xeb://選中8號鍵
key=8;
break;
case 0xdb://選中9號鍵
key=9;
break;
case 0xbb://選中10號鍵
key=10;
break;
case 0x7b://選中11號鍵
key=11;
break;
P3=0xf7;//給P3.3一個低電平
key1=P3;
key1=key1&0xf0;
if(key1!=0xf0)
delay(10);//取抖
if(key1!=0xf0)
key1=P3;
switch(key1)
case 0xe7://選中12號鍵
key=12;
break;
case 0xd7://選中13號鍵
key=13;
break;
case 0xb7://選中14號鍵
key=14;
break;
case 0x77://選中15號鍵
key=15;
break;
return key;
/* AD轉換數值顯示函數*/
void disp_ad()
uint ad_read;
ad_read=AD_read();//將AD轉換函數的返回值調出
date=(float)ad_read*50.0/256.0;
a1=date;
a2=a1/10;
a3=a1%10;
lcd_pos(2,3);
lcd_wdat(table[a2]);
lcd_pos(2,4);
lcd_wdat('.');
lcd_pos(2,5);
lcd_wdat(table[a3]);
lcd_pos(2,6);
lcd_wdat(table1[0]);
lcd_pos(2,7);
lcd_wdat(table1[1]);
void disp_dy()
uchar i;
lcd_pos(0,0); //設置顯示位置為第一行的第1個字符
i = 0;
while(dis1 != '\0')
{ //顯示字符
lcd_wdat(dis1);
i++;
lcd_pos(1,0); //設置顯示位置為第二行的第1個字符
i = 0;
while(dis2 != '\0')
lcd_wdat(dis2); //顯示字符
i++;
lcd_pos(2,0); //設置顯示位置為第三行的第1個字符
i = 0;
while(dis3 != '\0')
lcd_wdat(dis3); //顯示字符
i++;
lcd_pos(3,0); //設置顯示位置為第四行的第1個字符
i = 0;
while(dis4 != '\0')
lcd_wdat(dis4); //顯示字符
i++;
void disp_kj()
uchar i;
i = 0;
while(dis5 != '\0')
{ //顯示字符
lcd_wdat(dis1);
i++;
i = 0;
while(dis6 != '\0')
i++;
i = 0;
while(dis7 != '\0')
i++;
i = 0;
while(dis8 != '\0')
i++;
uchar a;
a=jian;
if(a<10)
{lcd_pos(1,p);
lcd_wdat(table[a]);//將鍵值顯示
jianzhi=table[a];}//if中要執行多個語句時要加大括號,
else if(a=10)
q=0;//確認鍵
fm=0;//警報響
uchar z1,z2,z3,z4;
float q3,q2;
uint x, z0;
x=qian;
q3=a3*0.1+a2;
q2=x*q3;
z0=q2*10;
z1=(int)z0/1000;
z2=(int)z0%1000/100;
z3=(int)z0%1000%100/10;
z4=(int)z0%1000%100%10;
lcd_pos(3,3);
lcd_wdat(table[(int)z1]);
lcd_pos(3,4);
lcd_wdat(z2);
lcd_pos(3,5);
lcd_wdat(table[(int)z3]);
lcd_pos(3,6);
lcd_wdat('.');
lcd_pos(3,7);
lcd_wdat(table[(int)z4]);
