標題: PIC12F675電機控制程序案例源碼 [打印本頁]
作者: 正輝照明    時間: 2018-12-1 14:28
編譯器用的是PICC9.83
你試試吧,一定要關閉AD才行哦。
//           __________________
//       VDD-| 1            14 |-VSS
//   電機GP5-| 2            13 |-GP0/AN0/DAT  LED
//   AN3/GP4-| 3            12 |-GP1/AN1/CLK
//GP3/RMCLR--| 4            11 |-GP2/AN2
//           |________________ |
//               16F675
#include <pic.h>
#define uint  unsigned int
#ifndef OPEN
#define OPEN  1
#endif
#ifndef OFF
#define OFF  0
#endif
#define        SET                                1
#define        CLEAR                        0
#define        TRUE                        1
#define        FALSE                        0
__CONFIG(FOSC_EXTRCIO & WDTE_OFF & MCLRE_OFF  & BOREN_OFF  & CP_OFF & PWRTE_ON);
  //內部RC 看門狗關閉 GP3為IO 代碼不保護
//#pragma config BOREN = OFF, CPD = OFF, FOSC = XT, MCLRE = OFF, WDTE = OFF, CP = OFF, PWRTE = OFF
#define   KEY     GPIO3
#define   LED     GPIO0
#define   BEEP    GPIO1
#define   SCR     GPIO5
#define   GHG     GPIO4
  /*********程序聲明****************/
void  InitAPP(void);
//void  ScanKey();
void InitAPP()
        /* Comment out if using simulator, ICD2, or ICE2000
        #asm        //Load Factory Calibration Value Into OSCCAL
                call 0x3FF
                bsf        _STATUS,5
                movwf _OSCCAL
        #endasm
    TRISIO=0x00;                    //Set All I/O's As OUT
        VRCON = 0;                         //參考電壓斷電
        CMCON = 0x07;                     // configure comparator inputs as digital I/O
        ANSEL =  0;                                  // configure A/D inputs as digital I/O
        ADON=  0;
        GIE = 1;
                             //Enable All Interrupts
  //  RAPU=0;         //上拉總使能
  //  WPUA5=1;            //RA5使能
   // RAIE=1;
     IOCB5=1;        //管腳中斷使能
/*********定時器初始化***************/
void  TimeInt()
    OPTION_REG  &= 0x80;                   //
    TMR0  = 0x14;                    //  250uS
    T0IE = 1;                          //Timer0 Overflow Interrupt Enabled
    T0IF = 0;                        //Clear Timer0 Overflow Interrupt Flag
//Isr() - Interrupt Service Routine
//      - Timer0 Overflow & GP3 Pin Change Are Used
void interrupt Isr()
{     static  uint  count;
        if ( (T0IE & T0IF) == 1)            //If A Timer0 Interrupt, Then
                 TMR0  = 0x14;
                 if(++count==40)
                     count=0;
                 LED=~LED;
                    T0IF = 0;                 //Clear Timer0 Interrupt Flag
   else if ( (GPIE & GPIF) == SET)          //If A GP3 Pin-Change Interrupt
     if(GHG==0)
       SCR = 1;  //關閉電機
       BEEP=0; //打開蜂鳴器
     else if(GHG==1)
      SCR=0;//打開電機
      BEEP=1; //關閉蜂鳴器
       GPIF=0;
        else if ( (INTE & INTF) == SET)   //If A GP2/INT External Intrrupt
        else if ( PEIE == SET)                          //If Peripheral Interrupts Enabled, Check Peripheral
        {                                 //Interrupts
                if ( (EEIE & EEIF) == SET)          //If A EEPROM Interrupt
                else if ( (ADIE & ADIF) == SET) //If A A/D Converter Interrupt
                else if ( (CMIE & CMIF) == SET) //If A Comparator Interrupt
                else if ( (TMR1IE & TMR1IF) == SET) //If A Timer1 Interrupt
//Main() - Main Routine
void  main()
    InitAPP();
    TimeInt();
