基于單片機(jī)的計(jì)算器設(shè)計(jì)的源程序代碼
mkdf
時(shí)間:
2018-11-22 15:32
用到的是stc89c51以及矩陣按鍵和lcd1602模塊
S16 S12 S8 S4分別是123+
S15 S11 S7 S3分別是456-
S14 S10 S6 S2分別是789*
S13 S9 S5 S1分別是0 CLR =
實(shí)現(xiàn)兩個(gè)數(shù)的運(yùn)算,每個(gè)數(shù)的位數(shù)至少可以八位
#include<reg52.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit rw=P2^5;
sbit rs=P2^6;
sbit e=P2^7;
sbit led=P3^7;
sbit beep=P2^0;
uint8 key,num;
uint8 fuhao;//定義具體的那個(gè)符號(hào),是加減還是乘除。
uint8 flag; //定義有沒有按下符號(hào)鍵,這個(gè)是統(tǒng)稱
long a,b,c,d; //定義運(yùn)算數(shù)據(jù)的第一個(gè)和第二個(gè)及等于的數(shù)變量
uint8 k; //定義小數(shù)點(diǎn)后面顯示的位數(shù)
uint8 biao;
uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//保存顯示的數(shù)據(jù)
void delay(uint16 i)
while(i--);
void lcdwrc(uint8 c)
delay(1000);
rs=0;
rw=0;
e=0;
P0=c;
e=1;
delay(1000);
e=0;
void lcdwrd(uint8 dat)
delay(1000);
rs=1;
rw=0;
e=0;
P0=dat;
e=1;
delay(1000);
e=0;
rs=0;
void lcdinit()
delay(1500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
lcdwrc(0x08);
lcdwrc(0x01);
lcdwrc(0x06);
lcdwrc(0x0c);
key=0;
num=0;
flag=0;
fuhao=0;
a=0;
b=0;
c=0;
d=0;
biao=0;
led=0;
void keyscan()
P1=0xfe; //令第一行為0,然后判斷是哪一列按下
if(P1!=0xfe)
delay(1000);
if(P1!=0xfe)
key=P1&0xf0;
switch(key)
case 0xe0: num=0;break; //1
case 0xd0: num=1;break; //2
case 0xb0: num=2;break; //3
case 0x70: num=3;break; //加
while(P1!=0xfe);
if(num==0||num==1||num==2) //確認(rèn)第一行的數(shù)1,2,3
if(flag==0) //沒有按下符號(hào)鍵
//led=1;
a=a*10+dat1[num];
//led=1;
b=b*10+dat1[num];
if(num==3)
//led=0;
flag=1;
fuhao=1;//加號(hào)+
lcdwrd(0x30+dat1[num]);
P1=0xfd; //令第二行為0,判斷是哪一列按下
if(P1!=0xfd)
delay(1000);
if(P1!=0xfd)
key=P1&0xf0;
switch(key)
case 0xe0: num=4;break; //4
case 0xd0: num=5;break; //5
case 0xb0: num=6;break; //6
case 0x70: num=7;break; //減—
while(P1!=0xfd);
if(num==4||num==5||num==6)
//led=1;
a=a*10+dat1[num];
//led=1;
b=b*10+dat1[num];
flag=1;
fuhao=2;//帶表減號(hào)
P1=0xfb; //令第三行為0,判斷哪一列按下
if(P1!=0xfb)
delay(1000);
if(P1!=0xfb)
key=P1&0xf0;
switch(key)
case 0xe0: num=8;break; //7
case 0xd0: num=9;break; //8
case 0xb0: num=10;break; //9
case 0x70: num=11;break; //乘*
while(P1!=0xfb);
if(num==8||num==9||num==10)
//led=1;
a=a*10+dat1[num];
//led=1;
b=b*10+dat1[num];
flag=1;
fuhao=3;//帶表乘號(hào)*
P1=0xf7; //令第四行為0,判斷哪一列按下
if(P1!=0xf7)
delay(1000);
if(P1!=0xf7)
key=P1&0xf0;
switch(key)
case 0xe0: num=12;break; //0
case 0xd0: num=13;break; //清除rst
case 0xb0: num=14;break; //等號(hào)=
case 0x70: num=15;break; //除/
while(P1!=0xf7);
switch(num)
case 12:
//led=1;
a=a*10+dat1[num];
lcdwrd(0x30);
//led=1;
b=b*10+dat1[num];
lcdwrd(0x30);
break;
case 13:
lcdwrc(0x01); //清屏指令
a=0;
b=0;
flag=0;
fuhao=0;
break;
case 15:
flag=1;
fuhao=4;
lcdwrd(0x2f);//除號(hào)/
break;
case 14:
if(fuhao==1)//加
lcdwrc(0x4f+0x80);
lcdwrc(0x04);//設(shè)置光標(biāo)左移,屏幕不移動(dòng)
c=a+b;
while(c!=0) //一位一位顯示
lcdwrd(0x30+c%10);//顯示結(jié)果的最后一位在0x4f的位置
c=c/10;//取前面的結(jié)果數(shù)據(jù)
lcdwrd(0x3d); //顯示等于號(hào)=
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if(fuhao==2) //減
lcdwrc(0x4f+0x80);
if(a>b)
c=a-b;
c=b-a;
if(a<b) lcdwrd(0x2d); //顯示-號(hào)
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if(fuhao==3)//乘法
lcdwrc(0x4f+0x80);
c=a*b;
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if(fuhao==3)//乘法
lcdwrc(0x4f+0x80);
c=a*b;
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if(fuhao==4)
k=0;
lcdwrc(0x4f+0x80);
c=(long)(((float)a/b)*1000);//強(qiáng)制轉(zhuǎn)換為long。
k++;
if(k==3)
lcdwrd(0x2e);
k=0;
if(a/b<0) //如果a比b小的話那么除的結(jié)果最高位是0
lcdwrd(0x30);
lcdwrd(0x3d); //顯示等號(hào)
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
break;
lcdinit();
keyscan();
(403.57 KB, 下載次數(shù): 16)
2018-11-22 15:31 上傳
