spi的程序,用單片機驅動at93c46存儲芯片
dudululu
2018-11-21 14:24
spi的單片機源程序如下:
#include"reg52.h"
uchar code s[9]={0x10,0x20,0x30,0x40,0x50,0x60,0x70,0x80,0x90};
sbit cs=P3^4;
sbit ck=P3^5;
sbit di=P3^6;
sbit d0=P3^7;
#define readcode 0x0c
#define writecode 0x0a
void delay1ms()
unsigned char i,j;
for(i=0;i<10;i++)
for(j=0;j<33;j++)
函數功能:延時若干毫秒
入口參數:n
void delaynms(unsigned char n)
unsigned char i;
for(i=0;i<n;i++)
delay1ms();
void delay(uchar n)
int i;
for(i=0;i<n;i++)
void clock(void)
ck=0;
delay(2);
ck=1;
delay(2);
void send(uchar da_ta)
int i;
for(i=0;i<8;i++)
di=(bit)(da_ta&0x80);
da_ta<<=1;
clock();
uchar receive(void)
uchar data1=0;
int i;
clock();
for(i=0;i<8;i++)
data1*=2;
if(d0)
data1++;
clock();
delay(2);
return(data1);
uchar readdata(uchar add)
uchar read_data;
cs=1;
send(readcode);
send(add);
read_data=receive();
cs=0;
return(read_data);
void writedata(uchar add,uchar write_data)
cs=1;
send(writecode);
send(add);
send(write_data);
cs=0;
delay(4);
cs=1;
delay(4);
while(!d0);
cs=0;
{ int i;
P2=0X00;
for(i=0;i<9;i++)
writedata(0x00+i,s[i]);
P2=readdata(0x00+i);
delaynms(1000);
spi.rar
(27.01 KB, 下載次數: 30)
2018-11-21 14:24 上傳
tutuwxy2
2018-11-27 21:48
你不會是duluchun吧?
