一個(gè)簡(jiǎn)單的51單片機(jī) 4x4 Keypad 測(cè)試小程序
[打印本頁(yè)]
oldspring
時(shí)間:
2018-11-21 09:50
這里介紹一個(gè)簡(jiǎn)單的51單片機(jī) 4x4 Keypad 測(cè)試小程序,它同樣可以用在 4x1, 4x2 或者 4x3 Keypad 上。希望對(duì)大家有用。
unsigned short kp, cnt, oldstate = 0;
char txt[6];
// Keypad module connections
char keypadPort at P0;
// End Keypad module connections
// Lcd module connections
sbit LCD_RS at P2_0_bit;
sbit LCD_EN at P2_1_bit;
sbit LCD_D4 at P2_2_bit;
sbit LCD_D5 at P2_3_bit;
sbit LCD_D6 at P2_4_bit;
sbit LCD_D7 at P2_5_bit;
// End Lcd module connections
void main() {
cnt = 0; // Reset counter
Keypad_Init(); // Initialize Keypad
Lcd_Init(); // Initialize Lcd
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1, 1, "Key :"); // Write message text on Lcd
Lcd_Out(2, 1, "Times:");
do {
kp = 0; // Reset key code variable
// Wait for key to be pressed and released
do
// kp = Keypad_Key_Press(); // Store key code in kp variable
kp = Keypad_Key_Click(); // Store key code in kp variable
while (!kp);
// Prepare value for output, transform key to it's ASCII value
switch (kp) {
//case 10: kp = 42; break; // '*' // Uncomment this block for keypad4x3
//case 11: kp = 48; break; // '0'
//case 12: kp = 35; break; // '#'
//default: kp += 48;
case 1: kp = 49; break; // 1 // Uncomment this block for keypad4x4
case 2: kp = 50; break; // 2
case 3: kp = 51; break; // 3
case 4: kp = 65; break; // A
case 5: kp = 52; break; // 4
case 6: kp = 53; break; // 5
case 7: kp = 54; break; // 6
case 8: kp = 66; break; // B
case 9: kp = 55; break; // 7
case 10: kp = 56; break; // 8
case 11: kp = 57; break; // 9
case 12: kp = 67; break; // C
case 13: kp = 42; break; // *
case 14: kp = 48; break; // 0
case 15: kp = 35; break; // #
case 16: kp = 68; break; // D
if (kp != oldstate) { // Pressed key differs from previous
cnt = 1;
oldstate = kp;
else { // Pressed key is same as previous
cnt++;
Lcd_Chr(1, 10, kp); // Print key ASCII value on Lcd
if (cnt == 255) { // If counter varialble overflow
cnt = 0;
Lcd_Out(2, 10, " ");
WordToStr(cnt, txt); // Transform counter value to string
Lcd_Out(2, 10, txt); // Display counter value on Lcd
} while (1);
相關(guān)信息:
http://www.raoushi.com/bbs/dpj-136722-1.html
(45.31 KB, 下載次數(shù): 57)
2018-11-21 09:49 上傳
