標題: DS3231迷你時鐘含溫度制作(Arduino源碼)0.96寸OLED顯示 [打印本頁]
作者: 冰冰潔潔    時間: 2018-11-18 12:41
源代碼在附件中,沒有庫的留言。學習在實踐中進步,建議大家多發些源代碼,這樣讓更多人少走彎路,因為你的一點保留說不定會讓世界進步的節奏變的更慢,如果愛迪生沒有告訴大家電燈泡說不定現在我們還點著燈呢。如果沒有人教你說話,現在說不定我們只會比劃。創造要發動更多的人,你是專家不一定能發明,或許別人能給你更多思路,或許世界因你而改變,其實我們每個人的源代碼和創造都來自前人為我們打下的基礎。
制作出來的實物圖如下:
O128顯DS3231時間源程序如下:
  1. //A4 A5并用顯示屏和時鐘D3231
  2. #include <Wire.h>
  3. #include <Adafruit_GFX.h>
  4. #include <Adafruit_SSD1306.h>
  5. #define OLED_RESET 4//oled復位
  6. Adafruit_SSD1306 display(OLED_RESET);
  7. #define LOGO16_GLCD_HEIGHT 16 //定義顯示高度
  8. #define LOGO16_GLCD_WIDTH  16 //定義顯示寬度
  9. #include <DS3231.h>
  10. DS3231 Clock;
  11. bool Century=false;
  12. bool h12;
  13. bool PM;
  14. byte ADay, AHour, AMinute, ASecond, ABits;
  15. bool ADy, A12h, Apm;
  16. int second,minute,hour,date,month,year,DoW;
  17. byte   temperature;//溫度
  18. int y;
  19.
  20. #if (SSD1306_LCDHEIGHT != 64)
  21. #error("Height incorrect, please fix Adafruit_SSD1306.h!");
  22. #endif
  23. //溫(0) 度(1)
  24. static const uint8_t PROGMEM wendu_16x16[] ={
  25. 0x00,0x08,0x00,0x08,0x7C,0x08,0x44,0x08,0x45,0xFE,0x44,0x08,0x44,0x08,0x7C,0x08,
  26. 0x44,0x88,0x44,0x48,0x44,0x48,0x44,0x08,0x7C,0x08,0x44,0x08,0x00,0x28,0x00,0x10,/*"時",0*/
  27. 0x20,0x00,0x13,0xFC,0x10,0x04,0x40,0x04,0x47,0xC4,0x44,0x44,0x44,0x44,0x44,0x44,
  28. 0x47,0xC4,0x44,0x44,0x44,0x44,0x44,0x44,0x47,0xC4,0x40,0x04,0x40,0x14,0x40,0x08,/*"間",1*/
  29. };
  30. static const uint8_t PROGMEM d_16x16[] ={
  31. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x06,0x00,0x00,0x00,0x00,0x00,
  32. 0x00,0x00,0x06,0x00,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"∶",0*/
  33. };
  34. static const uint8_t PROGMEM g_16x16[] ={
  35. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"-",0*/
  36. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"-",0*/
  37. };
  38. static const uint8_t PROGMEM c_16x16[] ={
  39. 0x60,0x00,0x91,0xF4,0x96,0x0C,0x6C,0x04,0x08,0x04,0x18,0x00,0x18,0x00,0x18,0x00,
  40. 0x18,0x00,0x18,0x00,0x18,0x00,0x08,0x00,0x0C,0x04,0x06,0x08,0x01,0xF0,0x00,0x00,/*"℃",0*/
  41. };
  42. //濕(0) 度(1)ˉ-
  43. static const uint8_t PROGMEM shidu_16x16[] ={
  44. 0x00,0x00,0x23,0xF8,0x12,0x08,0x12,0x08,0x83,0xF8,0x42,0x08,0x42,0x08,0x13,0xF8,
  45. 0x10,0x00,0x27,0xFC,0xE4,0xA4,0x24,0xA4,0x24,0xA4,0x24,0xA4,0x2F,0xFE,0x00,0x00,/*"溫",0*/
  46. 0x01,0x00,0x00,0x80,0x3F,0xFE,0x22,0x20,
  47. 0x22,0x20,0x3F,0xFC,0x22,0x20,0x22,0x20,
  48. 0x23,0xE0,0x20,0x00,0x2F,0xF0,0x24,0x10,
  49. 0x42,0x20,0x41,0xC0,0x86,0x30,0x38,0x0E,/*"度",1*/
  50. };
  51. void setup(){
  52. display.begin(SSD1306_SWITCHCAPVCC, 0x3C);// 使用I2C addr 0x3D初始化 (用于128x64)
  53. display.clearDisplay();//清除屏幕和緩沖區
  54.   //1.檢測全屏顯示(看看有沒有大面積壞點)
  55. display.fillScreen(WHITE);//顯示:填充屏幕(白色)
  56. display.display();
  57. delay(2000);
  58. Wire.begin();
  59.       /*
  60.          //改時間
  61.         Clock.setSecond(10);//Set the second
  62.         Clock.setMinute(40);//Set the minute
  63.         Clock.setHour(1);  //Set the hour
  64.         Clock.setDoW(7);    //Set the day of the week
  65.         Clock.setDate(24);  //Set the date of the month
  66.         Clock.setMonth(6);  //Set the month of the year
  67.         Clock.setYear(18);  //Set the year (Last two digits of the year)
  68.       */
  69. }
  70. void ReadDS3231()//讀取時間
  71. {
  72.   second=Clock.getSecond(); //時間
  73.   minute=Clock.getMinute();//時間
  74.   hour=Clock.getHour(h12, PM);//時間
  75.   date=Clock.getDate(); //日期
  76.   month=Clock.getMonth(Century);//日期
  77.   year=Clock.getYear();  //日期
  78.   DoW=Clock.getDoW();//星期
  79.   temperature=Clock.getTemperature();//溫度
  80. }
  81. void loop(){
  82.
  83. display.clearDisplay();//  清除屏幕和緩沖區
  84. ReadDS3231();//讀取時間
  85. display.setTextSize(1);//字號
  86. display.setTextColor(WHITE);
  87. //y=second*2;//移動畫
  88. display.setCursor(0,0); //列、、行
  89. display.println((int)20/10);//時間
  90. display.setCursor( 10,0); //列、、行
  91. display.println((int)20%10);//時間
  92. display.setCursor( 20,0); //列、、行
  93. display.println((int)year/10);//時間
  94. display.setCursor( 30,0); //列、、行
  95. display.println((int)year%10);//時間
  96. display.ShowCN_16( 44,0,g_16x16,sizeof(g_16x16)/32,WHITE); //://列、、行
  97. display.setCursor( 62,0);//列、、行
  98. display.println((int)month/10);//時間
  99. display.setCursor( 74,0);//列、、行
  100. display.println((int)month%10);//時間
  101. display.ShowCN_16( 84,0,g_16x16,sizeof(g_16x16)/32,WHITE); //://列、、行
  102. display.setCursor( 102,0);//列、、行
  103. display.println((int)date/10);//時間
  104. display.setCursor( 115,0);//列、、行
  105. display.println((int)date%10);//時間
  106. display.setTextSize(2);//字號
  107. display.setTextColor(WHITE);
  108. display.setCursor(20,17); //列、、行
  109. display.println((int)hour/10);//時間
  110. display.setCursor(32,17); //列、、行
  111. display.println((int)hour%10);//時間
  112. display.ShowCN_16(42,17,d_16x16,sizeof(d_16x16)/32,WHITE); //://列、、行
  113. display.setCursor(52,17);//列、、行
  114. display.println((int)minute/10);//時間
  115. display.setCursor(64,17);//列、、行
  116. display.println((int)minute%10);//時間
  117. display.ShowCN_16(74,17,d_16x16,sizeof(d_16x16)/32,WHITE); //://列、、行
  118. display.setCursor(85,17);//列、、行
  119. display.println((int)second/10);//時間
  120. display.setCursor(98,17);//列、、行
  121. display.println((int)second%10);//時間
  122. display.setTextSize(2);//set字號
  123. display.setTextColor(WHITE);
  124. display.ShowCN_16(20,35,shidu_16x16,sizeof(shidu_16x16)/32,WHITE); //://列、、行
  125. display.setCursor(60,35); //列、、行
  126. display.println((int)temperature);//溫度
  127. display.ShowCN_16(90,35,c_16x16,sizeof(c_16x16)/32,WHITE); //://列、、行
  128. display.display();
  129. delay(10);
  130. }
作者: long2018    時間: 2019-1-25 15:32
居然有傳說 中的沙發?????太難了,學不來。。。。
作者: xqtop    時間: 2019-2-28 07:27
非常不錯,感謝分享。
作者: cuiyl    時間: 2019-2-28 20:09
非常不錯,感謝分享。
作者: icexja    時間: 2019-3-21 22:15
臥室想搞個時間溫濕度的,感謝樓主了!
作者: 莊周的小燕    時間: 2019-4-10 12:44
非常不錯,感謝分享。
作者: 7010952    時間: 2019-4-15 07:17
硬件齊了,軟件不會。學習任重道遠
作者: 弋孑    時間: 2019-4-19 13:08
有庫嗎
作者: 1212sd    時間: 2019-5-9 23:23
非常不錯,感謝分享。
作者: tigerzq    時間: 2019-5-10 21:50
程序能再給點詳細說明就好了。
作者: countrymanks    時間: 2019-9-19 07:16
能把庫文件一起打包就更好了
作者: apfjm    時間: 2019-12-13 17:03
找到了,下載研究下。
作者: apfjm    時間: 2019-12-13 17:04
正在研究DS1302應該差不多一樣。。DS3231迷你時鐘含溫度制作(Arduino源碼)0.96寸OLED顯示
作者: tigerzq    時間: 2020-1-8 20:40
這個說一下編程思路或者弄個流程圖。手里硬件差不多了,動手試試看
作者: 碌碌無為    時間: 2020-1-14 22:46
DS3231只能提前預設時間嗎,可否與電腦連接后,直接獲取電腦時間?感謝樓主分享。
作者: tigerzq    時間: 2020-1-23 15:41
設計原理,設計思路都詳細說一下,對大家不是更好些嗎?
作者: aing123    時間: 2020-1-28 12:58
很好啊!
作者: 春風化雨    時間: 2020-3-8 21:24
收藏學習
作者: lucq7896    時間: 2020-3-16 07:53
Arduino:1.8.12 (Windows 7), 開發板:"Arduino Uno"
sketch_jul06a:25:2: error: #error ("Height incorrect, please fix Adafruit_SSD1306.h!");
"Adafruit_SSD1306.h" 對應多個庫
已使用: C:\Users\Administrator\sketchbook\libraries\Adafruit_SSD1306
未使用:C:\Users\Administrator\sketchbook\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
exit status 1
在文件 -> 首選項開啟
“編譯過程中顯示詳細輸出”選項
這份報告會包含更多信息。
沒通過啊?
作者: 13118302007    時間: 2020-10-7 22:17
支持樓主的觀點,希望樓主提供一下ShowCN_16(90,35,c_16x16,sizeof(c_16x16)/32,WHITE); 的庫文件,我最近也開始接觸Arduino板子了,想走點近路
作者: yn0879    時間: 2020-10-16 22:01
怎么接線的啊樓主
作者: 白衣紅    時間: 2020-11-16 20:36
編譯ShowCN_16(90,35,c_16x16,sizeof(c_16x16)/32,WHITE);的庫文件
作者: usaboy    時間: 2021-3-24 07:36
thank u for sharing!
作者: cooleaf    時間: 2021-4-29 12:24
感謝樓主分享,如果有再詳細點的說明就更好了,謝謝!!
作者: barve521    時間: 2021-6-5 23:29
如果有再詳細點的說明就更好了
作者: xjx51    時間: 2021-7-30 16:05
樓主這個是幾乘幾的屏幕啊?看起來好大,是128乘128的嗎?
作者: zsa6093313    時間: 2021-7-30 16:16
盡量學習了!剛接觸單片機!
作者: sivadft    時間: 2021-9-7 00:08
DS1302的代碼樓主有研究過嗎?
作者: lern01    時間: 2021-10-23 16:12
編譯通過不了,報錯:DS3231_oled_spi:24:2: error: #error ("Height incorrect, please fix Adafruit_SSD1306.h!");
exit status 1
作者: 土老冒527    時間: 2021-11-19 11:16
ds3231的溫度測試你覺得準嗎?和ds18b20差的可是夠大的
作者: 海闊天空hai    時間: 2022-4-16 20:47
有庫嗎
作者: yun89708    時間: 2024-7-23 17:02
非常不錯,感謝分享。
