標題: GY-53-L1X激光測距Arduino源碼 [打印本頁]
作者: 2dxc    時間: 2018-11-4 21:33
激光測距源碼,跟大家分享一下
  1. /////////////////////
  2. /*
  3. GY53----MINI
  4. VCC----VCC
  5. GND----GND
  6. 1:GY53L1_TX---10
  7. 2:GY53L1_RX---11
  8. */
  9. #include <SoftwareSerial.h>
  10. SoftwareSerial mySerial(10, 11); // RX, TX
  11. //////////////////
  12. unsigned char re_Buf[11],counter=0;
  13. unsigned char sign=0;
  14. byte data_Buf[3]={0};
  15. void setup() {
  16.    Serial.begin(9600);
  17.    mySerial.begin(9600);
  18.    mySerial.listen();
  19.   delay(1);
  20. // mySerial.write(0XA5);
  21. // mySerial.write(0X45);    //初始化,連續(xù)輸出模式
  22.   //mySerial.write(0XEA);    //初始化,連續(xù)輸出模式
  23. }
  24. void loop() {
  25.   unsigned char i=0,sum=0;
  26.    unsigned char RangeStatus=0,Time=0,Mode=0;
  27.   uint16_t distance=0;
  28.    while (mySerial.available()) {
  29.     re_Buf[counter]=(unsigned char)mySerial.read();
  30.     if(counter==0&&re_Buf[0]!=0x5A) return;      // 檢查幀頭
  31.     counter++;
  32.     if(counter==8)                //接收到數(shù)據(jù)
  33.     {
  34.        counter=0;                 //重新賦值,準備下一幀數(shù)據(jù)的接收
  35.        sign=1;
  36.     }
  37.   }
  38.   if(sign)
  39.   {
  40.      sign=0;
  41.      for(i=0;i<7;i++)
  42.       sum+=re_Buf[i];
  43.      if(sum==re_Buf[i] )        //檢查幀頭,幀尾
  44.      {
  45.           data_Buf[0]=re_Buf[4];
  46.           data_Buf[1]=re_Buf[5];
  47.           data_Buf[2]=re_Buf[6];
  48.           distance=data_Buf[0]<<8|data_Buf[1];
  49.           RangeStatus=(data_Buf[2]>>4)&0x0f;
  50.           Time=(data_Buf[2]>>2)&0x03;
  51.           Mode=data_Buf[2]&0x03;
  52.            Serial.print("distance: ");
  53.            Serial.print( distance);
  54.            Serial.print(" mm,RangeStatus: ");
  55.            Serial.print( RangeStatus);
  56.            Serial.print(" ,Time: ");
  57.            Serial.print( Time);
  58.            Serial.print(",Mode: ");
  59.            Serial.println( Mode);
  60.    }
  61.   }
  62. }
  63. /*void serialEvent() {
  64.   while (Serial.available()) {
  65.     re_Buf[counter]=(unsigned char)Serial.read();
  66.     if(counter==0&&re_Buf[0]!=0x5A) return;      // 檢查幀頭
  67.     counter++;
  68.     if(counter==8)                //接收到數(shù)據(jù)
  69.     {
  70.        counter=0;                 //重新賦值,準備下一幀數(shù)據(jù)的接收
  71.        sign=1;
  72.     }
  73.   }
  74. }*/
全部資料51hei下載地址:
arduino.zip (1.83 KB, 下載次數(shù): 18)
作者: qijun68    時間: 2018-11-13 08:02
這個模塊輸出的距離單位是厘米還是毫米?
