32*64雙色屏 08接口
32個74HC595D 2個74hc244d 2個74hc138d 1個74hc04d 8個APM4953
有單片機 STC12C5A60S2 STC98C52RC 學習板 20CM杜邦線 晶振22.1184M 32.768M 24M 12M
按照軟件連接 可屏幕就是不會亮 軟件如下 是音樂頻譜程序
#include<STC12C5A60S2.H>
#define channel 0x01 //設置AD通道為 P1.0
//----http://80mcu.taobao.com------------------qq:274108610-----------------------------------------------
#define ADC_POWER (1<<7)
#define ADC_SPEEDHH (0x03<<5)
#define ADC_START (1<<3)
#define PADCH (1<<5)
#define ADC_FLAG (1<<4)
sbit SDA_R=P1^5;
sbit SDA_R_TOP=P1^4;
sbit SDA_G=P1^3;
sbit SDA_G_TOP=P1^2;
sbit STCP=P1^6;
sbit SHCP=P1^7;
//放大128倍后的sin整數表(128)
code char SIN_TAB[128] = { 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70, 75, 80, 85, 89, 94, 98, 102,
105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126, 126, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112,
108, 105, 102, 98, 94, 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30,
-36, -42, -48, -54, -59, -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121,
-123, -124, -125, -126, -126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102,
-98, -94, -89, -85, -80, -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6 };
//放大128倍后的cos整數表(128)
code char COS_TAB[128] = { 127, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112, 108, 105, 102, 98, 94,
89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30, -36, -42, -48, -54, -59,
-65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121, -123, -124, -125, -126, -
126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102, -98, -94, -89, -85, -80,
-75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6, 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70,
75, 80, 85, 89, 94, 98, 102, 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126 };
//采樣存儲序列表
code char LIST_TAB[128] = { 0, 64, 32, 96, 16, 80, 48, 112,
8, 72, 40, 104, 24, 88, 56, 120,
4, 68, 36, 100, 20, 84, 52, 116,
12, 76, 44, 108, 28, 92, 60, 124,
2, 66, 34, 98, 18, 82, 50, 114,
10, 74, 42, 106, 26, 90, 58, 122,
6, 70, 38, 102, 22, 86, 54, 118,
14, 78, 46, 110, 30, 94, 62, 126,
1, 65, 33, 97, 17, 81, 49, 113,
9, 73, 41, 105, 25, 89, 57, 121,
5, 69, 37, 101, 21, 85, 53, 117,
13, 77, 45, 109, 29, 93, 61, 125,
3, 67, 35, 99, 19, 83, 51, 115,
11, 75, 43, 107, 27, 91, 59, 123,
7, 71, 39, 103, 23, 87, 55, 119,
15, 79, 47, 111, 31, 95, 63, 127
uchar COUNT=15,COUNT1=0,ADC_Count=0,LINE=15,G,T;
uchar i,j,k,b,p;
int Temp_Real,Temp_Imag,temp; // 中間臨時變量
uint TEMP1;
int xdata Fft_Real[128];
int xdata Fft_Image[128]; // fft的虛部
uchar xdata LED_TAB2[16]; //記錄 漂浮物 是否需要 停頓一下
uchar xdata LED_TAB[16]; //記錄紅色柱狀
uchar xdata LED_TAB1[16]; //記錄 漂浮點
void FFT()
{ //uchar x;
for( i=1; i<=7; i++) /* for(1) */
b=1;
b <<=(i-1); //碟式運算,用于計算 隔多少行計算 例如 第一極 1和2行計算,,第二級
for( j=0; j<=b-1; j++) /* for (2) */
p=1;
p <<= (7-i);
p = p*j;
for( k=j; k<128; k=k+2*b) /* for (3) 基二fft */
Temp_Real = Fft_Real[k]; Temp_Imag = Fft_Image[k]; temp = Fft_Real[k+b];
Fft_Real[k] = Fft_Real[k] + ((Fft_Real[k+b]*COS_TAB[p])>>7) + ((Fft_Image[k+b]*SIN_TAB[p])>>7);
Fft_Image[k] = Fft_Image[k] - ((Fft_Real[k+b]*SIN_TAB[p])>>7) + ((Fft_Image[k+b]*COS_TAB[p])>>7);
Fft_Real[k+b] = Temp_Real - ((Fft_Real[k+b]*COS_TAB[p])>>7) - ((Fft_Image[k+b]*SIN_TAB[p])>>7);
Fft_Image[k+b] = Temp_Imag + ((temp*SIN_TAB[p])>>7) - ((Fft_Image[k+b]*COS_TAB[p])>>7);
// 移位.防止溢出. 結果已經是本值的 1/64
Fft_Real[k] >>= 1;
Fft_Image[k] >>= 1;
Fft_Real[k+b] >>= 1;
Fft_Image[k+b] >>= 1;
// Fft_Real[0]=Fft_Image[0]=0; //去掉直流分量
// Fft_Real[63]=Fft_Image[63]=0;
// x=((((Fft_Real[1]* Fft_Real[1]))+((Fft_Image[1]*Fft_Image[1])))>>5);
for(j=0;j<16;j++)
TEMP1=((((Fft_Real[j+1]* Fft_Real[j+1]))+((Fft_Image[j+1]*Fft_Image[j+1])))>>1);//求功率
if(TEMP1>1)TEMP1--;
else TEMP1=0;
if(TEMP1>31)TEMP1=31;
if(TEMP1>(LED_TAB[j]))LED_TAB[j]=TEMP1;
if(TEMP1>(LED_TAB1[j]))
{ LED_TAB1[j]=TEMP1;
LED_TAB2[j]=14; //提頓速度=12
void Init()
P1ASF = 0x02; //0000,0010, 將 P1.1 置成模擬口
P1M0 = 0x01; //0000,0001用于A/D轉換的P1.x口,先設為開漏
P1M1 = 0x01; //0000,0001 P1.0先設為開漏。斷開內部上拉電阻
AUXR1 &=0xFB; //1111,1011, 令 ADRJ=0
EADC=1; //AD中斷打開
ADC_CONTR = ADC_POWER | ADC_SPEEDHH | ADC_START | channel;
//1110 1001 1打開 A/D (ADC_POWER)轉換電源;11速度為70周期一次;
//0中斷標志清零;1啟動adc(ADC_START);001AD通道打開(這里為P1.1);
//P1M0=P1M1=1;
P2M0=1;
TMOD=0X12;
TH0=0xb0; //
TL0=0xb0;
TH1=0xEE;
TL1=0XC0;
ET0=1; //定時器0 打開
TR0=0; //關閉定時器
ET1=1;
TR1=1;
PT1=0;
PT0=1;
IPH=PADCH;
IP=PADC; //中斷優先級
EA=1; //總中斷打開
void ADC_Finish() interrupt 5
{ ADC_CONTR &= !ADC_FLAG;
Fft_Real[LIST_TAB[ADC_Count]]=(int)((ADC_RES)<<1)+(ADC_RESL>>1)*2;//-512; //按LIST_TAB表里的順序,進行存儲 采樣值,,
// ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel; // 為了采集負電壓,采用 偏置采集。電壓提高到1/2 vcc,,所以要減去256
if(ADC_Count<=127)ADC_Count++;
else {EADC=0;TR0=0;}
void LED_Display() interrupt 3 //中斷一次 顯示一行。。。
TH1=0xf2;
TL1=0XAa;
for (G=0;G<16;G++) //往點陣屏填充 一行的 數據
if(LED_TAB[G]<=LINE+16)SDA_R_TOP=1;
else SDA_R_TOP=0;
if(LED_TAB[G]<=LINE)SDA_R=1;
else SDA_R=0;
if(LED_TAB1[G]==LINE){SDA_G_TOP=1;SDA_G=0;}
else if(LED_TAB1[G]==(LINE+16)){SDA_G_TOP=0;SDA_G=1;}
else SDA_G=SDA_G_TOP=1;
SHCP=1;SHCP=0;
SHCP=1;SHCP=0;
SHCP=1;SHCP=0;
SDA_G_TOP=1;SDA_G=1;SDA_R_TOP=1;SDA_R=1;
SHCP=1;SHCP=0;
STCP=1;STCP=0;
P2=15-LINE;
if(LINE>0)LINE--;
else LINE=15;
if(LED_TAB[COUNT]>0)LED_TAB[COUNT]--; //柱狀遞減,
if(COUNT>0)COUNT--;
else COUNT=15;
if(COUNT>0)COUNT--;
else COUNT=15;
//漂浮物遞減
// if(LED_TAB2[COUNT1]==0) //判斷是否需要停頓
// if(LED_TAB1[COUNT1]>LED_TAB[COUNT1])LED_TAB1[COUNT1]--;//大于柱狀則遞減(保持漂浮物在柱狀之上)
// else LED_TAB2[COUNT1]--;
// COUNT1++;
// if(COUNT1>=16)COUNT1=0;
COUNT1++;
void Ad_Control() interrupt 1 //控制采樣率
ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel; //開始AD采集
// ******************* main() *********************************
uchar i;
Init();
ADC_Count=0;
TR0=1;
EADC=1; //開啟定時器中斷0,,開啟ADC
while(ADC_Count<128);
for(i=0;i<128;i++)
Fft_Image=0;
FFT();
//FFT運算。并轉換為 功率值。。。
// TR1=1;
5跟地線用一根行嗎? 那個EN接正 接負 都不行!!!!還試了字幕程序 也不行!!! 網上有的說EN接3付 接5付黑屏 ? 是嗎???
字幕程序如下
控制卡
P0~P3 A B C D
P16 SCK
P17 STR
R1 P04
G1 P05
R2 P06
G2 P07
#include<stc89c51rc.h>
#define light 3
extern uint uiAllData; //定義亮度
uchar code hanzi[]; //漢字字模
uchar code hanzi1[]; //漢字字模
//0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,
uchar code sw[16]={0X00,0X08,0x04,0x0C,0X02,0X0A,0X06,0X0E,0X01,0X09,0X05,0X0D,0X03,0X0B,0X07,0X0F};/*16行段碼*///138驅動數據
sbit STR=P1^7; //鎖存
sbit SCK=P1^6; //時鐘
sbit SERr= P0^4; //數據
sbit SERg= P0^5;
sbit SERr1= P0^6;
sbit SERg1= P0^7;
uchar Move,Speed,line; //時間溫度變量
uint zimuo; //字模計數器
uchar BUFF[20]; //緩存
uchar BUFF1[20]; //緩存
void DelayMs(void); // 延時
void in_data(); // 調整移動數據
void rxd_data(); // 串口發送移動數據
/**************************延時***********************/
void DelayMs(void)
uchar TempCyc;
for(TempCyc=250;TempCyc>1;TempCyc--)
/*主函數*/
Move=0;
zimuo=0;
P0M0=0XFF;
P0M1=0X00;
P1M0=0X0C;
P1M0=0X00;
while(zimuo<2048)
while(Move<16) //數據移位。
for(Speed=0;Speed<3;Speed++) //移動速度
for(line=0;line<16;line++)
in_data(); //調整移動數據
rxd_data();
P0=sw[line];
STR=1;//鎖存
STR=0;
STR=1;
DelayMs(); //延時,等待一段時間,讓這列顯示的內容在人眼內產生“視覺暫留”現象。
DelayMs();
DelayMs();
DelayMs();
Move++; //移動一步
Move=0;
zimuo=zimuo+32;
zimuo=0;
void in_data(void) //調整數據
char s;
for(s=8;s>=0;s--) //i為向后先擇字節計數器,zimuoo為向后先字計數器
BUFF[2*s+1]=hanzi[zimuo+1+32*s+2*line]; //把第一個字模的第一個字節放入BUFF0中,第二個字模和第一個字節放入BUFF2中
BUFF[2*s]=hanzi[zimuo+32*s+2*line]; //把第一個字模的第二個字節放入BUFF1中,第二個字模的第二個字節放入BUFF3中
BUFF1[2*s+1]=hanzi1[zimuo+1+32*s+2*line]; //把第一個字模的第一個字節放入BUFF0中,第二個字模和第一個字節放入BUFF2中
BUFF1[2*s]=hanzi1[zimuo+32*s+2*line]; //把第一個字模的第二個字節放入BUFF1中,第二個字模的第二個字節放入BUFF3中
/***********************發送移動的數據****************************/
void rxd_data(void) //串行發送數據
uchar s;
uchar inc,tempyid,temp,k,temp1;
if(Move<8)
inc=0;
inc=1;
for(s=0+inc;s<16+inc;s++) //發送16字節數據
if(Move<8)
tempyid=Move;
tempyid=Move-8;
temp=(BUFF>>tempyid)|(BUFF[s+1]<<(8-tempyid)); //h1左移tempyid位后和h2右移8-tempyid相或,取出移位后的數據。
temp=255-temp;
temp1=(BUFF1>>tempyid)|(BUFF1[s+1]<<(8-tempyid)); //h1左移tempyid位后和h2右移8-tempyid相或,取出移位后的數據。
temp1=255-temp1;
if(zimuo<256)
SERg1=SERg=1;
for(k=0;k<8;k++)
SCK=0;
SERr=(bit)(temp&0x01);//這里SERr定義成普通IO口就得了
temp=temp>>1;
SERr1=(bit)(temp1&0x01);
temp1=temp1>>1;
SCK=1;
SERr=SERr1=1;
for(k=0;k<8;k++)
SCK=0;
SERg=(bit)(temp&0x01);//這里SERr定義成普通IO口就得了
temp=temp>>1;
SERg1=(bit)(temp1&0x01);
temp1=temp1>>1;
SCK=1;
const uchar code hanzi[]={/*移動顯示漢字字模,*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",2*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",3*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",6*/
0x00,0x00,0x7E,0x3F,0x40,0x21,0x40,0x21,0x42,0x21,0x24,0x12,0x28,0x12,0x10,0x12,0x30,0x0A,0x68,0x04,0xC8,0x04,0x44,0x0A,0x02,0x11,0x81,0x60,0x40,0x20,0x00,0x00,/*"雙",0*/
0x20,0x00,0x20,0x00,0xE0,0x0F,0x10,0x04,0x08,0x02,0xFC,0x0F,0x8A,0x08,0x88,0x08,0x88,0x08,0xF8,0x0F,0x08,0x00,0x08,0x20,0x08,0x20,0x08,0x20,0xF0,0x3F,0x00,0x00,/*"色",1*/
0x80,0x00,0x80,0x00,0x80,0x1F,0x80,0x00,0x80,0x08,0xF8,0x1F,0x08,0x08,0x08,0x08,0x08,0x08,0xF8,0x0F,0x08,0x08,0x80,0x08,0x14,0x11,0x24,0x22,0x22,0x22,0x00,0x00,/*"點",2*/
0x00,0x01,0x1F,0x01,0x11,0x01,0xE9,0x3F,0x85,0x00,0x89,0x02,0x51,0x02,0xF1,0x3F,0x11,0x02,0x15,0x02,0xE9,0x7F,0x01,0x02,0x01,0x02,0x01,0x02,0x01,0x02,0x01,0x02,/*"陣",3*/
0x02,0x40,0xE4,0x43,0x24,0x42,0x21,0x4A,0xA2,0x4A,0xAA,0x4A,0xA8,0x4A,0xA4,0x4A,0xA4,0x4A,0xA4,0x4A,0xA3,0x4A,0x82,0x40,0x42,0x41,0x42,0x42,0x22,0x52,0x12,0x20,/*"測",4*/
0x00,0x04,0x02,0x14,0x04,0x24,0x0C,0x24,0xE4,0x7F,0x00,0x04,0x07,0x04,0xE4,0x07,0x84,0x04,0x84,0x08,0x84,0x08,0x84,0x50,0x94,0x53,0x6C,0x60,0x04,0x40,0x00,0x00,/*"試",5*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x00,0x00,0x08,0x00,0x00,0x00,/*"!",6*/
0x04,0x00,0x88,0x1F,0x88,0x10,0xBF,0x10,0xA0,0x10,0x90,0x10,0x88,0x10,0x9C,0x1F,0x2A,0x09,0x29,0x09,0x08,0x09,0x08,0x09,0x88,0x48,0x88,0x48,0x48,0x48,0x28,0x70,/*"祝",7*/
0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFF,0x7F,0x80,0x00,0x40,0x01,0x40,0x01,0x40,0x02,0x20,0x02,0x20,0x04,0x10,0x08,0x08,0x18,0x04,0x70,0x02,0x20,/*"大",8*/
0x40,0x00,0x80,0x00,0xFC,0x7F,0x02,0x20,0xFA,0x17,0x80,0x00,0x40,0x00,0xF0,0x04,0x4E,0x0D,0x20,0x03,0x98,0x03,0x66,0x0D,0x18,0x71,0x06,0x21,0xA0,0x00,0x40,0x00,/*"家",9*/
0x80,0x10,0x08,0x31,0x30,0x13,0x10,0x09,0xFE,0x7F,0x02,0x20,0xF1,0x17,0x00,0x02,0x00,0x01,0xFE,0x7F,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x40,0x01,0x80,0x00,/*"學",10*/
0x00,0x00,0xFC,0x3F,0x00,0x20,0x10,0x20,0x20,0x20,0xC0,0x20,0x80,0x28,0x00,0x26,0x80,0x21,0x60,0x20,0x1C,0x20,0x08,0x20,0x00,0x20,0x00,0x24,0x00,0x28,0x00,0x10,/*"習",11*/
0x80,0x08,0x82,0x08,0x84,0x08,0xEC,0x3F,0x84,0x08,0x80,0x08,0x80,0x08,0xEF,0x7F,0x88,0x08,0x88,0x08,0x48,0x08,0x48,0x08,0x28,0x08,0x14,0x00,0xE2,0x7F,0x00,0x00,/*"進",12*/
0x00,0x01,0x00,0x01,0x10,0x1F,0x10,0x01,0x10,0x01,0xFE,0x7F,0x00,0x01,0x10,0x01,0x10,0x11,0x08,0x31,0x06,0x09,0x00,0x04,0x00,0x03,0xE0,0x00,0x1E,0x00,0x00,0x00,/*"步",13*/
/*-- 宋體12; 此字體下對應的點陣為:寬x高=8x16 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: --*/
/*-- 文字: 19--*/
/*-- 文字: 17--*/
