基于DSP28035的SPWM程序
WFF發
2018-10-25 19:24
基于DSP28035的SPWM程序
基于DSP28035的SPWM程序設計
#include "DSP28x_Project.h"
#include "HK_all_include.h"
extern Uint16 RamfuncsLoadSize;
void InitLED(void);
//Uint16 Error;
//Uint16 Tmp = 0;
void main(void)
InitSysCtrl();
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (Uint32)&RamfuncsLoadSize);
//InitLED(); //LED初始化
//SCI_Init();
//open_uart_debug();
// printf("\r\n\r\nDSP is ready!\r\n");
//softResetIIC_BUS(); //軟件復位IIC從設備
//InitI2C_Gpio(); //io 初始化為IIC
//I2CA_Init(); //HW IIC初始化,100KHz
//Timer0_init();
//ADC_Config();
//LigntVal = 0x71;//BIT6到BIT4為亮度調節,BIT0是 1 開啟/0關閉
//TM1650_Send(CMD_SEG,LigntVal); //8級亮度,開啟顯示
//TM1650_Send(DIG1,SEG7Table[0]); //GID1
//TM1650_Send(DIG2,SEG7Table[0]); //GID2
//TM1650_Send(DIG3,SEG7Table[0]); //GID3
//TM1650_Send(DIG4,SEG7Table[0]); //GID4
// Running.showNum = PWM7BLED.PWMstep;
//Running.showNum = AdcResult.ADCRESULT2;
// Running.showhex[0]=SEGHexBLK;
// Running.showhex[1]=SEGHexBLK;
// Running.showhex[2]=SEGHexBLK;
// Running.showhex[3]=SEGHexBLK;
//InitEPwm7(); //初始化PWM7外設功能以及GPIO41作為PWM7B引腳輸出
//PWM7BLED.dutyDir = LEDUP;
EALLOW;
SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
EDIS;
InitEPWM_AQ_DB();
EALLOW;
SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
EDIS;
PieCtrlRegs.PIECTRL.bit.ENPIE = 1; // Enable the PIE block
EINT; // Enable Global interrupt INTM
ERTM;
asm ( " NOP" );
/*if(timer0Base.Mark_Para.Status_Bits.OnemsdFlag == 1)
timer0Base.Mark_Para.Status_Bits.OnemsdFlag = 0;
if(timer0Base.msCounter >= 1000) //ms
timer0Base.msCounter = 0;
if(k >= 400)
k = 0;
EPwm1Regs.CMPA.half.CMPA = TonC[k];
EPwm1Regs.CMPB = TonC[k];
k++;
// AdcRegs.ADCSOCFRC1.all = 0X000F; //軟件觸發AD 的 SOC0--SOC3采樣
//ChangePWMDutyCycle();//改變占空比,進而改變PWM輸出,控制D400
// EPwm1Regs.CMPA.half.CMPA = 500;
// EPwm2Regs.CMPA.half.CMPA = 500;
// EPwm3Regs.CMPA.half.CMPA = 500;
//SegScanTask(&Running); //數碼管、三色LED、按鍵操作函數------關鍵函數
//handleScanKeyforPWM_LED(&Running);//PWM例程的掃描按鍵處理函數
/*void InitLED()
EALLOW;
D400MUX = 0; //GPIO功能
D400DIR = 1; //輸出
D401MUX = 0;
D401DIR = 1;
D402MUX = 0;
D402DIR = 1;
RGB_R_MUX = 0;
RGB_R_DIR = 1;
RGB_G_MUX = 0;
RGB_G_DIR = 1;
RGB_B_MUX = 0;
RGB_B_DIR = 1;
EDIS;
全部資料51hei下載地址:
chengxu.zip
(467.23 KB, 下載次數: 81)
2018-10-25 19:23 上傳
親測有效
zlb111
2019-1-2 16:58
看下,好資料
wanghui7070353
2019-6-5 12:30
學習,,,,,
YWM
2020-5-19 01:46
很少來這里。 沒空玩單片機了
