標題: IIC總線EEPROM芯片24C02C的單片機源碼+proteus仿真 [打印本頁]
作者: tutuwxy2    時間: 2018-10-24 00:13
基于IIC總線的EEPROM讀寫實驗源程序+數碼管顯示寫入內容+protues仿真
  1. //IIC bus EEPROM write and read experiment
  2. //2018.9.8  WXY
  3. #include<reg52.h>
  4. #define  unit  unsigned int
  5. #define  uchar unsigned char
  6. #define  M 10
  7. sbit scl=P0^0;
  8. sbit sda=P0^1;
  9. uchar code writebytes[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
  10. uchar idata recivebytes[10];
  11. /**************function define***************/
  12. void DELAY(unsigned long int n)
  13. {
  14.   while(n!=0)
  15.   n--;
  16. }
  17. /*********************/
  18. void START()
  19. {
  20.   scl=1;
  21.   sda=1;
  22.   DELAY(M);
  23.   sda=0;
  24.   DELAY(M);
  25.   scl=0;
  26.   DELAY(M);
  27. }
  28. /*********************/
  29. void STOP()
  30. {
  31.   sda=0;
  32.   DELAY(M);
  33.   scl=1;
  34.   DELAY(M);
  35.   sda=1;
  36.   DELAY(M);
  37. }
  38. /*********************/
  39. void ACK()
  40. {
  41.   uchar i;
  42.   scl=1;
  43.   DELAY(M);
  44.   while(sda==1&&i<100)
  45.   i++;
  46.   scl=0;
  47.   DELAY(M);
  48. }
  49. /**********************/
  50. void NO_ACK()
  51. {
  52.   sda=1;
  53.   DELAY(M);                  ///////////////
  54.   scl=1;
  55.   DELAY(M);
  56.   scl=0;
  57.   DELAY(M);
  58. }
  59. /**********************/
  60. void  WRITE_A_BYTE(uchar input)
  61. {
  62.   uchar t;
  63.   for(t=8;t!=0;t--)
  64.   {
  65.         sda=(bit)(input&0x80);
  66.         DELAY(M);
  67.         scl=1;
  68.         DELAY(M);
  69.         input=input<<1;
  70.         scl=0;
  71.         DELAY(M);
  72.   }
  73. }
  74. /*****************************/
  75. void  WRITE_N_BYTE(uchar wadd,uchar k)
  76. {
  77.   uchar input;
  78.   START();
  79.   WRITE_A_BYTE(0xa0);
  80.   ACK();
  81.   WRITE_A_BYTE(wadd+k);                         //write
  82.   ACK();
  83.   input=writebytes[k];
  84.   WRITE_A_BYTE(input);
  85.   ACK();
  86.   STOP();
  87. }
  88. /*****************************/
  89. uchar  RECIVE_A_BYTE()
  90. {
  91.   uchar t;
  92.   uchar output=0;
  93.   for(t=8;t!=0;t--)
  94.   {
  95.           scl=1;
  96.         output=output<<1;
  97.     output=output|(uchar)sda;
  98.         DELAY(M);
  99.           scl=0;
  100.         DELAY(M);
  101.   }
  102.   return(output);
  103. }
  104. /**************************************/
  105. uchar  RECIVE_N_BYTE(uchar radd,uchar k)                 //recive n byte
  106. {
  107.   uchar d;
  108.   START();
  109.   WRITE_A_BYTE(0xa0);                                              //Pseudo write operation
  110.   ACK();
  111.   WRITE_A_BYTE(radd+k);
  112.   ACK();
  113.   START();
  114.   WRITE_A_BYTE(0xa1);
  115.   ACK();
  116.   d=RECIVE_A_BYTE();
  117.   NO_ACK();
  118.   STOP();
  119.   return d;
  120. }
  121. ……………………
  122. …………限于本文篇幅 余下代碼請從51黑下載附件…………
IIC與EEPROM.rar (69.69 KB, 下載次數: 168)
作者: 豪豪是個好學生    時間: 2019-4-18 19:11
為什么沒有原理圖啊
