單片機(jī)紅外遙控解碼程序,自動(dòng)根據(jù)波特率設(shè)置定時(shí)器溢出率以及使用定時(shí)器延時(shí)
[打印本頁(yè)]
HEIZI555
時(shí)間:
2018-10-23 14:53
包含了紅外解碼,自動(dòng)根據(jù)波特率設(shè)置定時(shí)器溢出率以及使用定時(shí)器延時(shí)
串口部分:
void UART1_Init(u32 Boud)
u16 Temp = (65536 - FOSC/Boud/4);
SCON = 0x50;
T2L = Temp;
T2H = Temp >> 8;
AUXR |= 0x15; //啟動(dòng)定時(shí)器
ES = 1; //使能串口中斷
char putchar(u8 c)
SBUF = c;
while(!TI);
TI = 0;
return c;
void UART1_ISR() interrupt 4 using 1
if(RI)
RI = 0; //清中斷標(biāo)志
// if(TI)
// TI = 0; //清中斷標(biāo)志
//定時(shí)器延時(shí)部分
#include "delay.h"
#define TICK_US (FOSC/1000000/12)
volatile u16 told = 0; //計(jì)數(shù)器舊值
volatile u16 tnow = 0; //計(jì)數(shù)器新值
volatile u16 tick = 0; //計(jì)數(shù)值
volatile u16 delay_tick = 0; //延時(shí)計(jì)數(shù)值
void delay_init(void)
T4L = 0;
T4H = 0;
T4T3M &= 0x0F;
T4T3M |= B1000_0000; //啟動(dòng)定時(shí)器 12T
told = 0;
tnow = 0;
tick = 0;
delay_tick = 0;
void delay(u16 us)
told = T4H << 8 | T4L;
tnow = 0;tick = 0;
delay_tick = us * TICK_US;
tnow = T4H << 8 | T4L;
if(tnow != told)
if(tnow > told)
tick += tnow - told;
else //定時(shí)器溢出
tick += 65535 + tnow - told;
told = tnow;
if(tick >= delay_tick)
break;
//紅外解碼
#include "INT.h"
#include "USART.h"
u8 IR_Cnt = 0;
#define T51 (FOSC/1000000/12)
#define REMOTE_ID 0
//遙控器接收狀態(tài)
//[7]:收到了引導(dǎo)碼標(biāo)志
//[6]:得到了一個(gè)按鍵的所有信息
//[5]:保留
//[4]:標(biāo)記上升沿是否已經(jīng)被捕獲
//[3:0]:溢出計(jì)時(shí)器
u8 IR_sta = 0;
u32 IR_Rec = 0;
sbit INT0 = P3^2;
void IR_Init(void)
IT0 = 0; //使能INT0上升沿和下降沿中斷
EX0 = 1; //使能INT0中斷
AUXR &= 0x7F; //定時(shí)器時(shí)鐘12T模式
TMOD &= 0xF0; //設(shè)置定時(shí)器模式
TMOD |= 0x01; //設(shè)置定時(shí)器模式
TF0 = 0; //清除TF0標(biāo)志
TL0 = 0; //設(shè)置定時(shí)初值
TH0 = 0; //設(shè)置定時(shí)初值
TR0 = 0; //定時(shí)器0開始計(jì)時(shí)
ET0 = 1;
//處理紅外鍵盤
//返回值:
// 0,沒(méi)有任何按鍵按下
//其他,按下的按鍵鍵值.
u8 IR_Scan(void)
u8 Key = 0;
if(IR_sta & (1<<6))//得到一個(gè)按鍵的所有信息了
u8 TEMP[2];
TEMP[0] = IR_Rec>>24; //得到地址碼
TEMP[1] = (IR_Rec>>16)&0xff; //得到地址反碼
if((TEMP[0] == (u8)~TEMP[1]) && TEMP[0] == REMOTE_ID)//檢驗(yàn)遙控識(shí)別碼(ID)及地址
TEMP[0] = IR_Rec>>8;
TEMP[1] = IR_Rec;
if(TEMP[0] == (u8)~TEMP[1])
Key = TEMP[0];//鍵值正確
if(Key == 0||(IR_sta&0X80) == 0)//按鍵數(shù)據(jù)錯(cuò)誤/遙控已經(jīng)沒(méi)有按下了
IR_sta&=~(1<<6);//清除接收到有效按鍵標(biāo)識(shí)
IR_Cnt = 0; //清除按鍵次數(shù)計(jì)數(shù)器
return Key;
void INT0_ISR(void) interrupt 0 using 1
if(INT0)//上升沿捕獲
TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
IR_sta |= 0X10; //標(biāo)記上升沿已經(jīng)被捕獲
else //下降沿捕獲
u16 Count_Time = 0;
Count_Time = TH0 << 8|TL0;
if(IR_sta & 0X10) //完成一次高電平捕獲
if(IR_sta & 0X80)//接收到了引導(dǎo)碼
if(Count_Time > (300 * T51) && Count_Time < (800 * T51)) //560為標(biāo)準(zhǔn)值,560us
IR_Rec <<= 1; //左移一位.
IR_Rec |= 0; //接收到0
else if(Count_Time > (1400 * T51) && Count_Time < (1800 * T51)) //1680為標(biāo)準(zhǔn)值,1680us
IR_Rec |= 1; //接收到1
else if(Count_Time > (2200 * T51) && Count_Time < (2600 * T51)) //得到按鍵鍵值增加的信息 2500為標(biāo)準(zhǔn)值2.5ms
IR_Cnt++; //按鍵次數(shù)增加1次
IR_sta&=0XF0; //清空計(jì)時(shí)器
else if(Count_Time > (4200 * T51) && Count_Time < (4700 * T51)) //4500為標(biāo)準(zhǔn)值4.5ms
IR_sta|=1<<7; //標(biāo)記成功接收到了引導(dǎo)碼
IR_Cnt=0; //清除按鍵次數(shù)計(jì)數(shù)器
IR_sta &=~(1<<4);
void TIME0_ISR(void) interrupt 1 using 1
if(IR_sta&0x80)//上次有數(shù)據(jù)被接收到了
IR_sta &= ~0X10; //取消上升沿已經(jīng)被捕獲標(biāo)記
if((IR_sta&0X0F) == 0X00)
IR_sta|=1<<6;//標(biāo)記已經(jīng)完成一次按鍵的鍵值信息采集
if((IR_sta&0X0F) < 14)
IR_sta++;
IR_sta&=~(1<<7);//清空引導(dǎo)標(biāo)識(shí)
IR_sta&=0XF0; //清空計(jì)數(shù)器
羅文杰
時(shí)間:
2018-10-23 22:25
復(fù)制粘貼挺不容易的
