標題: 51單片機外部中斷int0應用 原理圖加程序注釋-學習筆記 [打印本頁]
作者: 保持平常心    時間: 2018-10-21 17:35
51單片機外部中斷int0應用電路原理圖如下:
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. uchar code DSY_CODE[]=
  5. {
  6.          0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x7f,0x6f,0x00
  7. };
  8. uchar Display_Buffer[3]={0,0,0};//依次存放個位,十位,百位
  9. uint Count = 0;
  10. sbit Clear_Key = P3^6;
  11. void Show_Count_ON_DSY()
  12. {
  13.          Display_Buffer[2] = Count / 100;        //取百位值
  14.         Display_Buffer[1] = Count % 100 /10;        //取十位值
  15.         Display_Buffer[0] = Count % 10;                        //取個位置
  16.         if(Display_Buffer[2]==0)
  17.         {
  18.                  Display_Buffer[2] = 0x0a;
  19.                 if(Display_Buffer[1]==0)
  20.                 {
  21.                          Display_Buffer[1]=0x0a;
  22.                 }
  23.         }
  24.         P0 = DSY_CODE[Display_Buffer[0]];
  25.         P1 = DSY_CODE[Display_Buffer[1]];
  26.         P2 = DSY_CODE[Display_Buffer[2]];
  27. }
  28. void main()
  29. {
  30.          P0 = 0xff;                //關閉所有的數碼管顯示
  31.         P1 = 0xff;
  32.         P2 = 0xff;
  33.         IE = 0x81;        //0x81=10000001B,定義:EA/-/ET2/ES/ET1/EX1/ET0/EX0。打開EA總中斷開和EX0外部中斷開關。
  34.         IT0 = 1;        //跳變沿出發方式(下降沿)
  35.         while(1)
  36.         {
  37.                  if(Clear_Key == 0)
  38.                         Count = 0;
  39.                 Show_Count_NO_DSY();
  40.         }
  41. }
  42. void EX_INT0() interrupt 0 //外部中斷0服務函數
  43. {
  44.          Count ++;
  45. }
知識點:1 數碼管段碼表
共陰數碼管段碼表
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
共陽段碼表
unsigned char code stab[]={0xff,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
001INT0中斷計數.docx (120.56 KB, 下載次數: 8)
作者: wosiboos    時間: 2018-10-21 22:28
不錯。很直得學習。
