LCD模塊顯示,高手進(jìn)~
[打印本頁(yè)]
samwalton
時(shí)間:
2012-3-11 00:00
LCD模塊顯示,高手進(jìn)~
用一個(gè)外部中斷讀取編碼器圈數(shù),用一個(gè)定時(shí)器實(shí)現(xiàn)30s倒計(jì)時(shí),并將圈數(shù)和時(shí)間在LCD上顯示。程序編譯沒有問(wèn)題,但LCD上出現(xiàn)跳動(dòng)的亂碼,求高手幫幫忙呀~跪謝謝了~~ #include "lcd.h" #include "common.h" int degree=0; int time=35; int circle; unsigned char xdata countdown[2]; unsigned char xdata circlestr[2]; void main(void) { IT0=1; //外部中斷0下降沿觸發(fā) EA=1; //全局中斷打開 EX0=1; //允許外部中斷0 TMOD|=0x01; //定時(shí)器0 16位定時(shí)器 X=65535-10000(10毫秒)=55535=D8F0(十六進(jìn)制)定時(shí)10ms TH0=0xd8; //計(jì)數(shù)時(shí)間 TL0=0xf0; IE=0x82; //這里是中斷優(yōu)先級(jí)控制EA=1(開總中斷),ET0=1(定時(shí)器0允許中斷),這里用定時(shí)器0來(lái)定時(shí) TR0=1; //打開定時(shí)器0 circle=degree/360; //取圈數(shù) circlestr[0]=circle/10+0x30; //取十位 circlestr[1]=circle%10+0x30; //取個(gè)位 countdown[0]=time/10+0x30; //取時(shí)間十位 countdown[1]=time%10+0x30; //取個(gè)位 LCD_Init( ); LCD_ClearScreen(); while( 1 ) { LCD_ShowDot6x8Str(48, 1, circlestr); //LCD顯示圈數(shù) LCD_ShowDot6x8Str(48, 0, countdown); // LCD顯示倒計(jì)時(shí)30s } } void int0()interrupt 0 //外部中斷0 { EA=0; if(P3^3==0) degree++; else degree--; EA=1; } void tim(void) interrupt 1 using 1 //定時(shí)器0中斷 { int count; //99只是一個(gè)數(shù),可以任意改,因?yàn)檫@里只學(xué)習(xí)怎樣實(shí)現(xiàn)倒計(jì)時(shí) TH0=0xd8; //定時(shí)10毫秒 TL0=0xf0; count++; if(count==100) //10毫秒定時(shí),10*100=1000(毫秒)=1秒 if(time>=0) time--; }
[此貼子已經(jīng)被作者于2012-3-11 0:02:36編輯過(guò)]
fancommand
時(shí)間:
2012-3-11 10:29
怎么這么一塌糊涂? 如何看啊?
yanwo19840726
時(shí)間:
2012-3-16 14:36
lcd 清屏了嗎
