標題: STM32F103控制PCA9685舵機驅動板程序源碼 [打印本頁]
作者: XXK    時間: 2018-10-19 20:13
  1. #include "pca9685.h"
  2. #include "myiic.h"
  3. #include "delay.h"
  4. #include "math.h"
  5. void pca_write(u8 adrr,u8 data)//向PCA寫數據,adrrd地址,data數據
  6. {
  7.         IIC_Start();
  8.
  9.         IIC_Send_Byte(pca_adrr);
  10.         IIC_Wait_Ack();
  11.
  12.         IIC_Send_Byte(adrr);
  13.         IIC_Wait_Ack();
  14.
  15.         IIC_Send_Byte(data);
  16.         IIC_Wait_Ack();
  17.
  18.         IIC_Stop();
  19. }
  20. u8 pca_read(u8 adrr)//從PCA讀數據
  21. {
  22.         u8 data;
  23.         IIC_Start();
  24.
  25.         IIC_Send_Byte(pca_adrr);
  26.         IIC_Wait_Ack();
  27.
  28.         IIC_Send_Byte(adrr);
  29.         IIC_Wait_Ack();
  30.
  31.         IIC_Start();
  32.
  33.         IIC_Send_Byte(pca_adrr|0x01);
  34.         IIC_Wait_Ack();
  35.
  36.         data=IIC_Read_Byte(0);
  37.         IIC_Stop();
  38.
  39.         return data;
  40. }
  41. void pca_setfreq(float freq)//設置PWM頻率
  42. {
  43.                 u8 prescale,oldmode,newmode;
  44.                 double prescaleval;
  45.                 freq *= 0.92;
  46.                 prescaleval = 25000000;
  47.                 prescaleval /= 4096;
  48.                 prescaleval /= freq;
  49.                 prescaleval -= 1;
  50.                 prescale =floor(prescaleval + 0.5f);
  51.                 oldmode = pca_read(pca_mode1);
  52.
  53.                 newmode = (oldmode&0x7F) | 0x10; // sleep
  54.
  55.                 pca_write(pca_mode1, newmode); // go to sleep
  56.
  57.                 pca_write(pca_pre, prescale); // set the prescaler
  58.
  59.                 pca_write(pca_mode1, oldmode);
  60.                 delay_ms(2);
  61.
  62.                 pca_write(pca_mode1, oldmode | 0xa1);
  63. }
  64. void pca_setpwm(u8 num, u32 on, u32 off)
  65. {
  66.                 pca_write(LED0_ON_L+4*num,on);
  67.                 pca_write(LED0_ON_H+4*num,on>>8);
  68.                 pca_write(LED0_OFF_L+4*num,off);
  69.                 pca_write(LED0_OFF_H+4*num,off>>8);
  70. }
  71. /*num:舵機PWM輸出引腳0~15,on:PWM上升計數值0~4096,off:PWM下降計數值0~4096
  72. 一個PWM周期分成4096份,由0開始+1計數,計到on時跳變為高電平,繼續計數到off時
  73. 跳變為低電平,直到計滿4096重新開始。所以當on不等于0時可作延時,當on等于0時,
  74. off/4096的值就是PWM的占空比。*/
  75. /*
  76.         函數作用:初始化舵機驅動板
  77.         參數:1.PWM頻率
  78.                   2.初始化舵機角度
  79. */
  80. void PCA_MG9XX_Init(float hz,u8 angle)
  81. {
  82.         u32 off=0;
  83.         IIC_Init();
  84.         pca_write(pca_mode1,0x0);
  85.         pca_setfreq(hz);//設置PWM頻率
  86.         off=(u32)(145+angle*2.4);
  87.         pca_setpwm(0,0,off);pca_setpwm(1,0,off);pca_setpwm(2,0,off);pca_setpwm(3,0,off);
  88.         pca_setpwm(4,0,off);pca_setpwm(5,0,off);pca_setpwm(6,0,off);pca_setpwm(7,0,off);
  89.         pca_setpwm(8,0,off);pca_setpwm(9,0,off);pca_setpwm(10,0,off);pca_setpwm(11,0,off);
  90.         pca_setpwm(12,0,off);pca_setpwm(13,0,off);pca_setpwm(14,0,off);pca_setpwm(15,0,off);
  91.         delay_ms(500);
  92. }
  93. /*
  94.         函數作用:控制舵機轉動;
  95.         參數:1.輸出端口,可選0~15;
  96.                   2.起始角度,可選0~180;
  97.                   3.結束角度,可選0~180;
  98.                   4.模式選擇,0 表示函數內無延時,調用時需要在函數后另外加延時函數,且不可調速,第五個參數可填任意值;
  99.                                           1 表示函數內有延時,調用時不需要在函數后另外加延時函數,且不可調速,第五個參數可填任意值;
  100.                                           2 表示速度可調,第五個參數表示速度值;
  101.                   5.速度,可填大于 0 的任意值,填 1 時速度最快,數值越大,速度越小;
  102.         注意事項:模式 0和1 的速度比模式 2 的最大速度大;
  103. */
  104. void PCA_MG9XX(u8 num,u8 start_angle,u8 end_angle,u8 mode,u8 speed)
  105. {
  106.         u8 i;
  107.         u32 off=0;
  108.         switch(mode)
  109.         {
  110.                 case 0:
  111.                         off=(u32)(158+end_angle*2.2);
  112.                         pca_setpwm(num,0,off);
  113.                         break;
  114.                 case 1:
  115.                         off=(u32)(158+end_angle*2.2);
  116.                         pca_setpwm(num,0,off);
  117.                         if(end_angle>start_angle){delay_ms((u16)((end_angle-start_angle)*2.7));}
  118.                         else{delay_ms((u16)((start_angle-end_angle)*2.7));}
  119.                         break;
  120.                 case 2:
  121.                         if(end_angle>start_angle)
  122.                         {
  123.                                 for(i=start_angle;i<=end_angle;i++)
  124.                                 {
  125.                                         off=(u32)(158+i*2.2);
  126.                                         pca_setpwm(num,0,off);
  127.                                         delay_ms(2);
  128.                                         delay_us(speed*250);
  129.                                 }
  130.                         }
  131.                         else if(start_angle>end_angle)
  132.                         {
  133.                                 for(i=start_angle;i>=end_angle;i--)
  134.                                 {
  135.                                         off=(u32)(158+i*2.2);
  136.                                         pca_setpwm(num,0,off);
  137.                                         delay_ms(2);
  138.                                         delay_us(speed*250);
  139.                                 }
  140.                         }
  141.                         break;
  142.         }
  143. }
PCA9685_MG996R.rar (826.45 KB, 下載次數: 504)
作者: liycen    時間: 2018-10-28 16:45
非常感謝,能給點備注嗎?,請問一下函數void PCA_MG9XX(u8 num,u8 start_angle,u8 end_angle,u8 mode,u8 speed)中的數字2.2是什么意思?感謝
非常感謝
作者: liujian1989    時間: 2019-1-18 11:57
感覺寫的不錯,應該是可以用,就是這邊.h的代碼沒貼出來,還要下一下
作者: plj213    時間: 2019-2-24 15:18
非常感謝分享。。。
作者: HanTian1223    時間: 2019-3-10 20:13
你好  你的碼源我已經下載 我有些疑問 就是PCA9685和32板子那個IO口連接呢
作者: 相安無sh    時間: 2019-4-22 11:33
正好需要!感謝!
作者: 橋霧    時間: 2019-5-29 11:02
這個確實很有用,pca9685只在arduino上用過,STM32上沒有直接能用的庫
作者: 吳敏12306    時間: 2019-7-26 11:37
下載了,然后把IIC的對應接口改成自己板子對應的了,給端子接了5.5V電壓,但是對應輸出通道沒有pwm輸出,請問這個是為什么
作者: Alex_12    時間: 2019-8-3 12:34
謝謝樓主了
作者: yzq123    時間: 2019-8-5 20:40
謝樓主
作者: qwzxasd    時間: 2019-8-29 14:35
謝謝大佬提供源碼。
作者: lyh01    時間: 2019-9-17 21:35
謝謝樓主分享,很有用
作者: 啊哈哈哈哈III    時間: 2019-11-3 17:12
感謝感謝,很好用。攢攢啊
作者: wyylzcxl    時間: 2019-11-18 21:50
謝謝分想
作者: 魯大仙    時間: 2020-2-9 19:00
你好 我有些疑問 就是PCA9685和32板子那個IO口連接呢?
作者: 18435211232    時間: 2020-2-25 23:14
liycen 發表于 2018-10-28 16:45
非常感謝,能給點備注嗎?,請問一下函數void PCA_MG9XX(u8 num,u8 start_angle,u8 end_angle,u8 mode,u8 s ...
360/158=2.2
HanTian1223 發表于 2019-3-10 20:13
這個IIC通訊,自己搭配
作者: 18435211232    時間: 2020-2-25 23:15
謝謝樓主分享,很有用
感謝感謝,很好用。攢攢啊
作者: huhouhezai    時間: 2020-3-20 16:02
樓主 模式2調速 不能用 是什么原因
作者: RICO6    時間: 2020-9-23 11:41
這個網站同一個文件第二次下載還需要積分嗎?
作者: 撒sad    時間: 2020-12-2 21:24
為啥用來驅動LED燈不行呢
作者: 撒sad    時間: 2020-12-2 21:25
不知道是IIC錯了還是PWM設置的問題
huhouhezai 發表于 2020-3-20 16:02
樓主 模式2調速 不能用 是什么原因
搞好了嗎???
作者: a1041695151    時間: 2020-12-11 17:40
感謝,寫的很詳細
作者: 1045964948    時間: 2021-10-7 21:45
請問一下為什么我用這個程序驅動舵機沒反應呢,硬件連接沒有問題
作者: silentky    時間: 2021-11-28 22:10
好好好好好好好好好好好好好好好好好好好
