基于STM32車載LIN總線源碼
Jason86
2018-10-17 11:13
基于STM32車載LIN總線源碼
STM32F0的UART雖然支持LIN模式,但是在HAL庫中卻缺少LIN總線相關的API函數。
基于對總線協議的研究,將USART HAL庫進行改寫,實現了LIN通信。
HAL_StatusTypeDef HAL_UART_Receive_IT(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
/* Check that a Rx process is not already ongoing */
if(huart->RxState == HAL_UART_STATE_READY)
if((pData == NULL ) || (Size == 0U))
return HAL_ERROR;
/* In case of 9bits/No Parity transfer, pData buffer provided as input paramter
should be aligned on a u16 frontier, as data to be received from RDR will be
handled through a u16 cast. */
if ((huart->Init.WordLength == UART_WORDLENGTH_9B) && (huart->Init.Parity == UART_PARITY_NONE))
if((((uint32_t)pData)&1U) != 0U)
return HAL_ERROR;
/* Process Locked */
__HAL_LOCK(huart);
huart->pRxBuffPtr = pData;
huart->RxXferSize = Size;
huart->RxXferCount = Size;
/* Computation of UART mask to apply to RDR register */
UART_MASK_COMPUTATION(huart);
huart->ErrorCode = HAL_UART_ERROR_NONE;
huart->RxState = HAL_UART_STATE_BUSY_RX;
/* Process Unlocked */
__HAL_UNLOCK(huart);
/* Enable the UART Error Interrupt: (Frame error, noise error, overrun error) */
SET_BIT(huart->Instance->CR3, USART_CR3_EIE);
/* Enable the UART Parity Error and Data Register not empty Interrupts */
//SET_BIT(huart->Instance->CR1, USART_CR1_PEIE | USART_CR1_RXNEIE);
return HAL_OK;
return HAL_BUSY;
void HAL_UART_IRQHandler(UART_HandleTypeDef *huart)
uint32_t isrflags = READ_REG(huart->Instance->ISR);
uint32_t cr1its = READ_REG(huart->Instance->CR1);
uint32_t cr3its;
uint32_t errorflags;
uint16_t ore_rdr_data;
/* If no error occurs */
errorflags = (isrflags & (uint32_t)(USART_ISR_PE | USART_ISR_FE | USART_ISR_ORE | USART_ISR_NE));
if (errorflags == RESET)
/* UART in ¿ÕÏÐÖжϣ¬½ÓÊÕÊý¾ÝÍê³É ---------------------------------------------------*/
if(((isrflags & USART_ISR_IDLE) != RESET) && ((cr1its & USART_CR1_IDLEIE) != RESET))
__HAL_UART_CLEAR_IT(huart, UART_CLEAR_IDLEF);
/* Disable the UART Parity Error Interrupt and RXNE interrupt*/
CLEAR_BIT(huart->Instance->CR1, (USART_CR1_RXNEIE | USART_CR1_PEIE));
/* Disable the UART Error Interrupt: (Frame error, noise error, overrun error) */
CLEAR_BIT(huart->Instance->CR3, USART_CR3_EIE);
/* ½ûÖ¹IDLEIEÖÐ¶Ï */
CLEAR_BIT(huart->Instance->CR1, USART_CR1_IDLEIE);
/* Rx process is completed, restore huart->RxState to Ready */
huart->RxState = HAL_UART_STATE_READY;
HAL_UART_RxCpltCallback(huart);
//UART_Receive_IT(huart);
return;
/* UART in mode Receiver ---------------------------------------------------*/
if(((isrflags & USART_ISR_RXNE) != RESET) && ((cr1its & USART_CR1_RXNEIE) != RESET))
return;
/* If some errors occur */
cr3its = READ_REG(huart->Instance->CR3);
if( (errorflags != RESET)
&& ( ((cr3its & USART_CR3_EIE) != RESET)
|| ((cr1its & (USART_CR1_RXNEIE | USART_CR1_PEIE)) != RESET)) )
/* UART parity error interrupt occurred -------------------------------------*/
if(((isrflags & USART_ISR_PE) != RESET) && ((cr1its & USART_CR1_PEIE) != RESET))
__HAL_UART_CLEAR_IT(huart, UART_CLEAR_PEF);
huart->ErrorCode |= HAL_UART_ERROR_PE;
/* UART frame error interrupt occurred --------------------------------------*/
if(((isrflags & USART_ISR_FE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET))
__HAL_UART_CLEAR_IT(huart, UART_CLEAR_FEF);
__HAL_UART_CLEAR_IT(huart, UART_CLEAR_IDLEF); //Çå³ý¿ÕÏбêÖ¾
huart->RxXferCount = huart->RxXferSize;
//HAL_GPIO_TogglePin(LED1_GPIO_Port,LED1_Pin);
SET_BIT(huart->Instance->CR1, USART_CR1_PEIE | USART_CR1_RXNEIE);//ʹÄܽÓÊÕÖжÏ
SET_BIT(huart->Instance->CR1, USART_CR1_IDLEIE);//ʹÄÜ¿ÕÏÐÖжÏ
huart->ErrorCode |= HAL_UART_ERROR_FE;
/* UART noise error interrupt occurred --------------------------------------*/
if(((isrflags & USART_ISR_NE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET))
__HAL_UART_CLEAR_IT(huart, UART_CLEAR_NEF);
huart->ErrorCode |= HAL_UART_ERROR_NE;
/* UART Over-Run interrupt occurred -----------------------------------------*/
if(((isrflags & USART_ISR_ORE) != RESET) &&
(((cr1its & USART_CR1_RXNEIE) != RESET) || ((cr3its & USART_CR3_EIE) != RESET)))
__HAL_UART_CLEAR_IT(huart, UART_CLEAR_OREF);
huart->ErrorCode |= HAL_UART_ERROR_ORE;
/* Call UART Error Call back function if need be --------------------------*/
if(huart->ErrorCode != HAL_UART_ERROR_NONE)
ore_rdr_data = (uint16_t) READ_REG(huart->Instance->RDR); //¶ÁÈ¡Êý¾Ý¼Ä´æÆ÷£¬ÇåÁã
/* If Overrun error occurs, or if any error occurs in DMA mode reception,
consider error as blocking */
if (((huart->ErrorCode & HAL_UART_ERROR_ORE) != RESET) ||
(HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR)))
/* Blocking error : transfer is aborted
Set the UART state ready to be able to start again the process,
Disable Rx Interrupts, and disable Rx DMA request, if ongoing */
UART_EndRxTransfer(huart);
/* Disable the UART DMA Rx request if enabled */
if (HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR))
CLEAR_BIT(huart->Instance->CR3, USART_CR3_DMAR);
/* Abort the UART DMA Rx channel */
if(huart->hdmarx != NULL)
/* Set the UART DMA Abort callback :
will lead to call HAL_UART_ErrorCallback() at end of DMA abort procedure */
huart->hdmarx->XferAbortCallback = UART_DMAAbortOnError;
/* Abort DMA RX */
if(HAL_DMA_Abort_IT(huart->hdmarx) != HAL_OK)
/* Call Directly huart->hdmarx->XferAbortCallback function in case of error */
huart->hdmarx->XferAbortCallback(huart->hdmarx);
/* Call user error callback */
HAL_UART_ErrorCallback(huart);
/* Non Blocking error : transfer could go on.
Error is notified to user through user error callback */
return;
} /* End if some error occurs */
#if !defined(STM32F030x6) && !defined(STM32F030x8)&& !defined(STM32F070xB)&& !defined(STM32F070x6)&& !defined(STM32F030xC)
/* UART wakeup from Stop mode interrupt occurred ---------------------------*/
if(((isrflags & USART_ISR_WUF) != RESET) && ((cr3its & USART_CR3_WUFIE) != RESET))
__HAL_UART_CLEAR_IT(huart, UART_CLEAR_WUF);
/* Set the UART state ready to be able to start again the process */
huart->gState = HAL_UART_STATE_READY;
HAL_UARTEx_WakeupCallback(huart);
return;
#endif /* !defined(STM32F030x6) && !defined(STM32F030x8)&& !defined(STM32F070xB)&& !defined(STM32F070x6)&& !defined(STM32F030xC) */
/* UART in mode Transmitter ------------------------------------------------*/
if(((isrflags & USART_ISR_TXE) != RESET) && ((cr1its & USART_CR1_TXEIE) != RESET))
UART_Transmit_IT(huart);
return;
/* UART in mode Transmitter (transmission end) -----------------------------*/
if(((isrflags & USART_ISR_TC) != RESET) && ((cr1its & USART_CR1_TCIE) != RESET))
UART_EndTransmit_IT(huart);
return;
1021256354
2019-11-4 14:14
有完整工程么?分享出來看看哦!!!!
