STM32F030工程模板下載
搞科研
2018-10-10 12:43
STM32F030工程模板下載
關于STM32F030的具體模板,共開發者參考
(41.11 KB, 下載次數: 53)
2018-10-10 15:00 上傳
STM32F030C8T6模板
時鐘都在system_stm32f0xxx.里設定。用那個開那個,輸出都是48MHZ,最大頻率,可以在里面改變大小頻率
#define PLL_SOURCE_HSI // HSI (~8MHz) used to clock the PLL, and the PLL is used as system clock source(~ 8MHz)
//#define PLL_SOURCE_HSE // HSE (8MHz) used to clock the PLL, and the PLL is used as system clock source
//#define PLL_SOURCE_HSE_BYPASS // HSE bypassed with an external clock (8MHz, coming from ST-Link) used to clock
使用內部時鐘 48MHZ
#include "stm32f0xx.h"
#include "delay.h"
void LedInit(void)
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE); //GPIOF時鐘打開
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //模式:輸出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //輸入類型:上拉/下拉/無
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //輸出類型:推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //輸出速率
GPIO_Init(GPIOA,&GPIO_InitStructure);
int main(void)
delay_init();///定時器初始化,
LedInit();///LED燈初始代,
while (1)
GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2);
delay_ms(200); //延時
GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2);
delay_ms(200);
工程模板-F030.zip
(297.96 KB, 下載次數: 222)
2018-10-10 12:43 上傳
STM32F030
woshigeshuai
2020-6-28 17:13
感謝分享,剛好下載看一下
