標題: TPS51125 datesheet與電路圖(共37頁pdf下載) [打印本頁]
作者: fay314    時間: 2018-9-30 10:57
TPS51125 datesheet資料僅供參考
TPS51125電路圖:
The TPS51125 is a cost-effective, dual-synchronous
buck controller targeted for notebook system power
supply solutions. The device provides 5-V and 3.3-V
LDOs and requires few external components. The
270-kHz VCLK output can be used to drive an
external charge pump, thus generating gate drive
voltage for the load switches without reducing the
efficiency of the main converter. The TPS51125
supports high-efficiency, fast-transient response and
provides a combined power-good signal. Out-of-
Audio mode light-load operation enables low acoustic
noise at much higher efficiency than conventional
forced PWM operation. Adaptive on-time D-CAP™
control provides convenient and efficient operation.
The part operates with supply input voltages ranging
from 5.5 V to 28 V and supports output voltages from
2 V to 5.5 V. The TPS51125 is available in a 24-pin
QFN package and is specified from -40°C to 85°C
ambient temperature range.
完整的pdf格式文檔51黑下載地址(共37頁):
tps51125.pdf (2.38 MB, 下載次數: 6)
