標題: msp430g2553在LCD1602顯示源程序 [打印本頁]
作者: gy51xx    時間: 2018-9-24 09:47
msp430g2553單片機在LCD1602液晶顯示
  1. #include<msp430.h> /* 必要操作:正確連接1602 */
  2. #define LCD_OUT P1OUT //定義LCD1602的數據口為P1
  3. #define CLR_RS P2OUT&=~BIT0; //置零P2.3位,也就是置零RS
  4. #define SET_RS P2OUT|=BIT0; //置壹P2.3位,也就是置壹RS
  5. #define CLR_RW P2OUT&=~BIT1; //置零P2.4位,也就是置零RW
  6. #define SET_RW P2OUT|=BIT1; //置壹P2.4位,也就是置壹RW
  7. #define CLR_EN P2OUT&=~BIT2; //置零P2.5位,也就是置零EN
  8. #define SET_EN P2OUT|=BIT2; //置壹P2.5位,也就是置壹EN
  9. unsigned char busy; //1602判忙標志
  10. void busy_1602(void) //查詢忙碌標志信號程序
  11. {
  12.     do
  13.     {
  14.             CLR_EN;
  15.             SET_RW;
  16.             CLR_RS;
  17.             busy=LCD_OUT;
  18.             SET_EN;
  19.             _delay_cycles(1000);
  20.             CLR_EN;
  21.             _delay_cycles(1000);
  22.     }
  23.     while(busy&&0x10==1);
  24. }
  25. void LCD_Write_com(unsigned char com) //寫指令到LCM程序
  26. {
  27.     busy_1602();
  28.     CLR_EN;
  29.     CLR_RW;
  30.     CLR_RS;
  31.     LCD_OUT=com;
  32.     _nop();
  33.     SET_EN;
  34.     _nop();
  35.     CLR_EN;
  36. }
  37. void lcd_write_data(unsigned char data) //寫數據到LCM程序
  38. {
  39.     busy_1602();
  40.     CLR_EN;
  41.     CLR_RW;
  42.     SET_RS;
  43.     LCD_OUT=data;
  44.     _nop();
  45.     SET_EN;
  46.     _nop();
  47.     CLR_EN;
  48. }
  49. void init_1602(void) //啟動LCM程序
  50. {
  51.     LCD_Write_com(0x38);
  52.     LCD_Write_com(0x0c);
  53.     LCD_Write_com(0x06);
  54. }
  55. void lcd_clear(void)    //清屏函數
  56. {
  57.     LCD_Write_com(0x01);
  58.     _nop();
  59.     _nop();
  60.     _nop();
  61. }
  62. void lcd_write_string(unsigned char x,unsigned char y,unsigned char *s) //字符串顯示函數
  63. {
  64.     if (y==0)
  65.     {
  66.         LCD_Write_com(0x80 + x);
  67.     }
  68.         else
  69.         {
  70.             LCD_Write_com(0xC0 + x);
  71.         }
  72.      while(*s)
  73.     {
  74.          lcd_write_data(*s);
  75.         s++;
  76.     }
  77. }
  78. /*                     //字符顯示函數 */
  79. void lcd_write_char(unsigned char x,unsigned char y, unsigned char Data)
  80. {
  81.     if(y==0)
  82.     {
  83.         LCD_Write_com(0x80 + x);
  84.     }
  85.     else
  86.     {
  87.         LCD_Write_com(0xC0 + x);
  88.     }
  89.     lcd_write_data(Data);
  90. }
  91. void main(void) //主程序開始
  92. {
  93.     WDTCTL=WDTPW+WDTHOLD;
  94.     P1DIR=0xFF;
  95.     P2DIR=0xFF;
  96.     init_1602();
  97.     while(1)
  98.     {
  99.         lcd_write_string(0,0,"WARRNING!!!");
  100.     }
  101. }
msp430g25531602顯示.docx (13.89 KB, 下載次數: 75)
作者: 我是傳奇1255    時間: 2019-1-24 10:43
非常有用,感謝分享
作者: 我是傳奇1255    時間: 2019-5-30 21:49
非常有用,感謝分享
作者: abc2313467    時間: 2019-7-20 10:10
這個管腳連線是怎么連的
作者: L1BB    時間: 2019-7-26 08:36
大家注意,定義里面代碼和注釋不一樣,按照注釋修改定義就能用
