標題: 基于stm32采集ads1255這款24位ad的源代碼 [打印本頁]
作者: wft214535841    時間: 2018-9-10 13:20
次代碼為stm32f系列單片機采集ads1255這款24位ad的源代碼,通訊采用spi方式,24位ad的精度是可20ms采集一次,效率很高
單片機源程序:
  1. #include "main.h"
  2. #include "stm32f1xx_hal.h"
  3. #include "dma.h"
  4. #include "iwdg.h"
  5. #include "spi.h"
  6. #include "tim.h"
  7. #include "usart.h"
  8. #include "gpio.h"
  9. /* USER CODE BEGIN Includes */
  10. #include "common.h"
  11. #include "ads1255.h"
  12. #include "Protocol.h"
  13. /* USER CODE END Includes */
  14. /* Private variables ---------------------------------------------------------*/
  15. /* USER CODE BEGIN PV */
  16. /* Buffer used for reception */
  17. #define BUFFER_SIZE 64  //宏定義緩沖區大小
  18. /* Private variables ---------------------------------------------------------*/
  19. uint16_t rx_len1 = 0;//定義一個接收長度變量
  20. uint8_t recv_end_flag1 = 0;//定義一個接收結束標變量
  21. uint8_t rx_buffer1[64];//定義一個接收緩沖數組,128個元素
  22. uint8_t sendcommand_flag=0x03;
  23. /* USER CODE END PV */
  24. /* Private function prototypes -----------------------------------------------*/
  25. void SystemClock_Config(void);
  26. /* USER CODE BEGIN PFP */
  27. /* Private function prototypes -----------------------------------------------*/
  28. /* USER CODE END PFP */
  29. /* USER CODE BEGIN 0 */
  30. /* USER CODE END 0 */
  31. int main(void)
  32. {
  33.   /* USER CODE BEGIN 1 */
  34.   /* USER CODE END 1 */
  35.   /* MCU Configuration----------------------------------------------------------*/
  36.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  37.   HAL_Init();
  38.   /* USER CODE BEGIN Init */
  39.   /* USER CODE END Init */
  40.   /* Configure the system clock */
  41.   SystemClock_Config();
  42.   /* USER CODE BEGIN SysInit */
  43.   /* USER CODE END SysInit */
  44.   /* Initialize all configured peripherals */
  45.   MX_GPIO_Init();
  46.   MX_DMA_Init();
  47.   MX_IWDG_Init();
  48.   MX_SPI2_Init();
  49.   MX_TIM2_Init();
  50.   MX_USART1_UART_Init();
  51. //  MX_TIM3_Init();
  52.   /* USER CODE BEGIN 2 */
  53.   HAL_TIM_Base_Start_IT(&htim2);
  54.   ads1255_init();
  55.
  56.   Uart_Event_Init(); //初始化串口事件
  57.
  58.   __HAL_UART_ENABLE_IT(&huart1,UART_IT_IDLE);        //使能串口1空閑中斷
  59.    UartEventType DataReceive;
  60. //  HAL_TIM_Base_Start_IT(&htim3);
  61.   /* USER CODE END 2 */
  62.   /* Infinite loop */
  63.   /* USER CODE BEGIN WHILE */
  64.   while (1)
  65.   {
  66.   /* USER CODE END WHILE */
  67.   /* USER CODE BEGIN 3 */
  68.     HAL_IWDG_Refresh(&hiwdg);
  69.     if(Uart_Event_Get(&DataReceive)==true)
  70.     {
  71.       sendcommand_flag=rx_buffer1[4];
  72.     }
  73.
  74.     if(sendcommand_flag==0x01)
  75.     {
  76.       HAL_UART_Transmit_DMA(&huart1,FidDataFunction(),12);
  77.     }
  78.     else
  79.     {
  80.
  81.     }
  82.     HAL_UART_Receive_DMA(&huart1,rx_buffer1,BUFFER_SIZE);
  83.   }
  84.
  85. //      printf("\r\n****** FID Controller System ******\r\n ");
  86. //      printf("Set SYSCLK to %dHz\r\n", HAL_RCC_GetSysClockFreq());
  87. //      printf("Set HCLK   to %dHz\r\n", HAL_RCC_GetHCLKFreq());
  88. //      printf("Set PCLK1  to %dHz\r\n", HAL_RCC_GetPCLK1Freq());
  89. //      printf("Set PCLK2  to %dHz\r\n", HAL_RCC_GetPCLK2Freq());
  90. //      printf("signal value:%0.4lf\r\n",sign);
  91.   }
  92.   /* USER CODE END 3 */
  93. /** System Clock Configuration
  94. */
  95. void SystemClock_Config(void)
  96. {
  97.   RCC_OscInitTypeDef RCC_OscInitStruct;
  98.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  99.     /**Initializes the CPU, AHB and APB busses clocks
  100.     */
  101.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
  102.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  103.   RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  104.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  105.   RCC_OscInitStruct.LSIState = RCC_LSI_ON;
  106.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  107.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  108.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  109.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  110.   {
  111.     _Error_Handler(__FILE__, __LINE__);
  112.   }
  113.     /**Initializes the CPU, AHB and APB busses clocks
  114.     */
  115.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  116.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  117.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  118.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  119.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  120.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  121.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  122.   {
  123.     _Error_Handler(__FILE__, __LINE__);
  124.   }
  125.     /**Configure the Systick interrupt time
  126.     */
  127.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  128.     /**Configure the Systick
  129.     */
  130.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  131.   /* SysTick_IRQn interrupt configuration */
  132.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  133. }
  134. /* USER CODE BEGIN 4 */
  135. /* USER CODE END 4 */
  136. /**
  137.   * @brief  This function is executed in case of error occurrence.
  138.   * @param  None
  139.   * @retval None
  140.   */
  141. void _Error_Handler(char * file, int line)
  142. {
  143.   /* USER CODE BEGIN Error_Handler_Debug */
  144.   /* User can add his own implementation to report the HAL error return state */
  145.   while(1)
  146.   {
  147.   }
  148.   /* USER CODE END Error_Handler_Debug */
  149. }
  150. #ifdef USE_FULL_ASSERT
  151. /**
  152.    * @brief Reports the name of the source file and the source line number
  153.    * where the assert_param error has occurred.
  154. ……………………
  155. …………限于本文篇幅 余下代碼請從51黑下載附件…………
FIDGC.rar (8.92 MB, 下載次數: 178)
作者: kinggwi    時間: 2018-9-21 12:00
最近在調試這顆IC,參考一下。。。。
作者: huangyiff    時間: 2020-3-24 09:42
最近在調試,參考一下。
作者: kfhzy    時間: 2020-4-3 08:56
參考一下。
作者: 小馬123    時間: 2020-5-12 18:05
厲害了我的哥,參考一下
作者: 1191991388    時間: 2020-6-5 10:53
贊,借鑒一下,我最近在看AD4111,樓主有推薦么
作者: 的官方回復    時間: 2020-7-31 16:09
謝謝,參考一下
作者: lightday    時間: 2021-11-24 10:00
有人知道這邊初始化時延時為什么都要幾秒嗎?
