stm32f103和串口屏通訊 液晶屏測試工裝源程序
17671382908
時(shí)間:
2018-8-27 11:05
利用stm32與串口屏通訊
工程路徑為..\STM32\DCDEMO7\RVMDK\DCDEMO7.uvproj ,請用KEIL4(MDK4)以上版本打開
單片機(jī)源程序如下:
#include "hmi_driver.h"
#include "hmi_user_uart.h"
#include "cmd_queue.h"
#include "cmd_process.h"
#include "stdio.h"
#include "hw_config.h"
#include "ulitity.h"
#include "string.h"
#include "rtc.h"
#include "stm32f10x_bkp.h"
#include "stm32f10x_rtc.h"
#include "stm32f10x_pwr.h"
//#include "key_IN.h"
#define TIME_100MS 10 //100毫秒(10個(gè)單位)
volatile uint32 timer_tick_count = 0; //定時(shí)器節(jié)拍
uint8 cmd_buffer[CMD_MAX_SIZE]; //指令緩存
static uint16 current_screen_id = 0; //當(dāng)前畫面ID
static int32 test_value = 0; //測試值
static uint8 update_en = 0; //更新標(biāo)記
static int32 meter_flag = 0; //儀表指針往返標(biāo)志位
static int32 num = 0; //曲線采樣點(diǎn)計(jì)數(shù)
static uint8 sec = 1; //時(shí)間秒
static int32 curves_type = 0; //曲線標(biāo)志位 0為正弦波,1為鋸齒波
static int32 second_flag=0; //時(shí)間標(biāo)志位
static int32 Progress_Value = 0; //進(jìn)度條的值
static int32 icon_flag = 0; //圖標(biāo)標(biāo)志位
//int32 key_flag = 0;
static uint16 screenid = 0;
extern uint32 OP_XGUS;
int t1 = 5;
void UpdateUI(void); //更新UI數(shù)據(jù)
void picxdisp(uchar n,int x1,int y1,int x2,int y2) ;
* \brief 程序入口
int main()
uint32 timer_tick_last_update = 0; //上一次更新的時(shí)間
qsize size = 0;
//int PRESS ;
//配置時(shí)鐘
Set_System();
//配置串口中斷
Interrupts_Config();
//配置時(shí)鐘節(jié)拍
systicket_init();
// KEY_Init();
RTC_int();
//串口初始化
Uart2Init(9600);
UartInit(9600);
//清空串口接收緩沖區(qū)
queue_reset();
//延時(shí)等待串口屏初始化完畢,必須等待300ms
delay_ms(300);
size = queue_find_cmd(cmd_buffer,CMD_MAX_SIZE); //從緩沖區(qū)中獲取一條指令
if(size>0&&cmd_buffer[1]!=0x07)//接收到指令
ProcessMessage((PCTRL_MSG)cmd_buffer, size);//指令處理
/*PRESS = KEY_Scan();
switch(PRESS)
case 1 :
while(key_flag)
KEY_Scan();
SetScreen(screenid);
screenid++;
break;
case 2 :
screenid -= 1;
break;
case 3 :
screenid += 1;
break;
* \brief 消息處理流程
* \param msg 待處理消息
* \param size 消息長度
void ProcessMessage( PCTRL_MSG msg, uint16 size )
uint8 cmd_type = msg->cmd_type; //指令類型
uint8 ctrl_msg = msg->ctrl_msg; //消息的類型
uint8 control_type = msg->control_type; //控件類型
uint16 screen_id = PTR2U16(&msg->screen_id); //畫面ID
uint16 control_id = PTR2U16(&msg->control_id); //控件ID
uint32 value = PTR2U32(msg->param); //數(shù)值
switch(cmd_type)
case NOTIFY_TOUCH_PRESS: //觸摸屏按下
case NOTIFY_TOUCH_RELEASE: //觸摸屏松開
NotifyTouchXY(cmd_buffer[1],PTR2U16(cmd_buffer+2),PTR2U16(cmd_buffer+4));
break;
case NOTIFY_WRITE_FLASH_OK: //寫FLASH成功
NotifyWriteFlash(1);
break;
case NOTIFY_WRITE_FLASH_FAILD: //寫FLASH失敗
NotifyWriteFlash(0);
break;
case NOTIFY_READ_FLASH_OK: //讀取FLASH成功
NotifyReadFlash(1,cmd_buffer+2,size-6); //去除幀頭幀尾
break;
case NOTIFY_READ_FLASH_FAILD: //讀取FLASH失敗
NotifyReadFlash(0,0,0);
break;
case NOTIFY_READ_RTC: //讀取RTC時(shí)間
NotifyReadRTC(cmd_buffer[2],cmd_buffer[3],cmd_buffer[4],cmd_buffer[5],cmd_buffer[6],cmd_buffer[7],cmd_buffer[8]);
break;
case NOTIFY_CONTROL:
if(ctrl_msg==MSG_GET_CURRENT_SCREEN) //畫面ID變化通知
NotifyScreen(screen_id); //畫面切換調(diào)動(dòng)的函數(shù)
switch(control_type)
case kCtrlButton: //按鈕控件
NotifyButton(screen_id,control_id,msg->param[1]);
break;
case kCtrlText: //文本控件
NotifyText(screen_id,control_id,msg->param);
break;
case kCtrlProgress: //進(jìn)度條控件
NotifyProgress(screen_id,control_id,value);
break;
case kCtrlSlider: //滑動(dòng)條控件
NotifySlider(screen_id,control_id,value);
break;
case kCtrlMeter: //儀表控件
NotifyMeter(screen_id,control_id,value);
break;
case kCtrlMenu: //菜單控件
NotifyMenu(screen_id,control_id,msg->param[0],msg->param[1]);
break;
case kCtrlSelector: //選擇控件
NotifySelector(screen_id,control_id,msg->param[0]);
break;
case kCtrlRTC: //倒計(jì)時(shí)控件
NotifyTimer(screen_id,control_id);
break;
default:
break;
break;
default:
break;
* \brief 畫面切換通知
* \details 當(dāng)前畫面改變時(shí)(或調(diào)用GetScreen),執(zhí)行此函數(shù)
* \param screen_id 當(dāng)前畫面ID
void NotifyScreen(uint16 screen_id)
//TODO: 添加用戶代碼
//在工程配置中開啟畫面切換通知,記錄當(dāng)前畫面ID
//進(jìn)到二維碼頁面生成二維碼
* \brief 觸摸坐標(biāo)事件響應(yīng)
* \param press 1按下觸摸屏,3松開觸摸屏
* \param x x坐標(biāo)
* \param y y坐標(biāo)
void NotifyTouchXY(uint8 press,uint16 x,uint16 y)
* \brief 更新數(shù)據(jù)
void UpdateUI()
* \brief 按鈕控件通知
* \details 當(dāng)按鈕狀態(tài)改變(或調(diào)用GetControlValue)時(shí),執(zhí)行此函數(shù)
* \param screen_id 畫面ID
* \param control_id 控件ID
* \param state 按鈕狀態(tài):0彈起,1按下
void NotifyButton(uint16 screen_id, uint16 control_id, uint8 state)
if(screen_id == 0)
if(control_id==32)
GetControlValue(0,26);
if(control_id==33)
GetControlValue(0,10);
if(control_id==34)
GetControlValue(0,22);
if(control_id==37)
GetControlValue(0,25);
if(control_id==35)
screenid -= 1;
if(control_id==36)
screenid += 1;
* \brief 文本控件通知
* \details 當(dāng)文本通過鍵盤更新(或調(diào)用GetControlValue)時(shí),執(zhí)行此函數(shù)
* \param str 文本控件內(nèi)容
void NotifyText(uint16 screen_id, uint16 control_id, uint8 *str)
int32 value=0;
int32 zalue;
sscanf(str,"%ld",&value); //把字符串轉(zhuǎn)換為整數(shù)
UnlockDeviceConfig();
if(screen_id==0) //畫面ID2:文本設(shè)置和顯示
if(control_id==26) //最高電壓
//限定數(shù)值范圍(也可以在文本控件屬性中設(shè)置)
switch(value)
case 2400:
zalue=1;
SetCommBps(zalue);
UartInit(2400);
SetTextInt32(0,41,zalue,0,1);
break;
case 4800:
zalue=2;
SetCommBps(zalue);
UartInit(4800);
break;
case 9600:
zalue=3;
SetCommBps(zalue);
UartInit(9600);
break;
case 19200:
zalue=4;
SetCommBps(zalue);
UartInit(19200);
break;
case 38400:
zalue=5;
SetCommBps(zalue);
UartInit(38400);
break;
case 57600:
zalue=6;
SetCommBps(zalue);
UartInit(57600);
break;
case 115200:
zalue=7;
SetCommBps(zalue);
UartInit(115200);
break;
LockDeviceConfig();
* \brief 進(jìn)度條控件通知
* \details 調(diào)用GetControlValue時(shí),執(zhí)行此函數(shù)
* \param value 值
void NotifyProgress(uint16 screen_id, uint16 control_id, uint32 value)
* \brief 滑動(dòng)條控件通知
* \details 當(dāng)滑動(dòng)條改變(或調(diào)用GetControlValue)時(shí),執(zhí)行此函數(shù)
* \param value 值
void NotifySlider(uint16 screen_id, uint16 control_id, uint32 value)
* \brief 儀表控件通知
* \param value 值
void NotifyMeter(uint16 screen_id, uint16 control_id, uint32 value)
//TODO: 添加用戶代碼
* \brief 菜單控件通知
* \details 當(dāng)菜單項(xiàng)按下或松開時(shí),執(zhí)行此函數(shù)
* \param item 菜單項(xiàng)索引
* \param state 按鈕狀態(tài):0松開,1按下
void NotifyMenu(uint16 screen_id, uint16 control_id, uint8 item, uint8 state)
//TODO: 添加用戶代碼
* \brief 選擇控件通知
* \details 當(dāng)選擇控件變化時(shí),執(zhí)行此函數(shù)
* \param item 當(dāng)前選項(xiàng)
void NotifySelector(uint16 screen_id, uint16 control_id, uint8 item)
* \brief 定時(shí)器超時(shí)通知處理
void NotifyTimer(uint16 screen_id, uint16 control_id)
//TODO: 添加用戶代碼
* \brief 讀取用戶FLASH狀態(tài)返回
* \param status 0失敗,1成功
* \param _data 返回?cái)?shù)據(jù)
* \param length 數(shù)據(jù)長度
void NotifyReadFlash(uint8 status,uint8 *_data,uint16 length)
//TODO: 添加用戶代碼
* \brief 寫用戶FLASH狀態(tài)返回
void NotifyWriteFlash(uint8 status)
//TODO: 添加用戶代碼
* \brief 讀取RTC時(shí)間,注意返回的是BCD碼
* \param year 年(BCD)
* \param month 月(BCD)
* \param week 星期(BCD)
* \param day 日(BCD)
* \param hour 時(shí)(BCD)
* \param minute 分(BCD)
* \param second 秒(BCD)
void NotifyReadRTC(uint8 year,uint8 month,uint8 week,uint8 day,uint8 hour,uint8 minute,uint8 second)
//sec =(0xff & (second>>4))*10 +(0xf & second); //BCD碼轉(zhuǎn)十進(jìn)制
液晶屏測試工裝程序.rar
(379.37 KB, 下載次數(shù): 76)
2018-8-27 18:28 上傳
點(diǎn)擊文件名下載附件
zhz888_00
時(shí)間:
2019-5-29 02:16
謝謝分享!
kaikaiGeng
時(shí)間:
2020-6-13 02:27
很棒 需要好好研究下
