標題: 分享一個電子秤(基于HX711+12864+STC89C51) [打印本頁]
作者: xiaohancf    時間: 2018-8-24 10:02
本帖最后由 xiaohancf 于 2018-8-24 10:07 編輯
先貼程序main.c:
#include "main.h"
#include "LCD12864.h"
#include "HX711.h"
unsigned long HX711_Buffer = 0;
unsigned int Weight_Maopi = 0,Weight_Shiwu = 0;
//主函數
    LCD12864_Reset();                                //初始化液晶
    LCD12864_HAIZI_SET();                            //設置為普通模式
    LCD12864_NoWaitIdle_COM_Write(0x80);                        //指針設置
    LCD12864_write_word("※※※※※※※※");
    LCD12864_NoWaitIdle_COM_Write(0x90);                        //指針設置
    LCD12864_write_word("※※歡迎使用※※");
    Delay_ms(1000);         //延時1s,等待傳感器穩定
    Get_Maopi();                //稱毛皮重量
    LCD12864_NoWaitIdle_COM_Write(0x01);            //清空
        Get_Weight();            //稱重
        if(  Weight_Shiwu > 10000 )
        LCD12864_write_word("※※※超重※※※");
        else if( Weight_Shiwu < 10000)
        //顯示當前重量
        LCD12864_write_word("重量:");
        if( Weight_Shiwu/10000 != 0)
            LCD12864_Data_Write(Weight_Shiwu/10000 + 0x30);
            LCD12864_Data_Write(' ');
        LCD12864_Data_Write(Weight_Shiwu%10000/1000 + 0x30);
        LCD12864_Data_Write('.');
        LCD12864_Data_Write(Weight_Shiwu%1000/100 + 0x30);
        LCD12864_Data_Write(Weight_Shiwu%100/10 + 0x30);
        LCD12864_Data_Write(Weight_Shiwu%10 + 0x30);
        LCD12864_write_word(" Kg");
        if( Weight_Shiwu*2/10000 != 0)
            LCD12864_Data_Write(Weight_Shiwu*2/10000 + 0x30);
        LCD12864_Data_Write(Weight_Shiwu*2%10000/1000 + 0x30);
        LCD12864_Data_Write(Weight_Shiwu*2%1000/100 + 0x30);
        LCD12864_Data_Write(Weight_Shiwu*2%100/10 + 0x30);
        LCD12864_Data_Write(Weight_Shiwu*2%10 + 0x30);
        LCD12864_write_word(" ");
//稱重
void Get_Weight()
    HX711_Buffer = HX711_Read();
    HX711_Buffer = HX711_Buffer/100;
    if(HX711_Buffer > Weight_Maopi)
        Weight_Shiwu = HX711_Buffer;
        Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                //獲取實物的AD采樣數值。
        Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/2.09+0.05);     //計算實物的實際重量
        //因為不同的傳感器特性曲線不一樣,因此,每一個傳感器需要矯正這里的2.15這個除數。
        //當發現測試出來的重量偏大時,增加該數值。
        //如果測試出來的重量偏小時,減小改數值。
        //該數值一般在2.15附近調整之間。因傳感器不同而定。
        //+0.05是為了四舍五入百分位
    Weight_Shiwu=Weight_Shiwu/2;
//獲取毛皮重量
void Get_Maopi()
    unsigned char i = 0;
    unsigned int Temp_Weight = 0;
    Weight_Maopi = 0;
    for( i = 0 ; i < 10 ; i++)
        Temp_Weight = HX711_Buffer/100;
        if( Temp_Weight > Weight_Maopi)
            Weight_Maopi = Temp_Weight;
//MS延時函數(12M晶振下測試)
void Delay_ms(unsigned int n)
    unsigned int  i,j;
    for(i=0;i<n;i++)
        for(j=0;j<123;j++);
main.h:
#ifndef __MAIN_H__
#define __MAIN_H__
#include <reg52.h>
//函數或者變量聲明
extern void Delay_ms(unsigned int n);
extern void Get_Maopi();
extern void Get_Weight();
#endif
LCD12864.h:
#ifndef __LCD12864_H__
#define __LCD12864_H__
#include <reg52.h>
#include <intrins.h>
//引腳定義
sbit LCD12864_RS_PORT  = P1^0;
sbit LCD12864_RW_PORT = P1^1;
sbit LCD12864_E_PORT    = P1^2;
#define LCD12864_DA_PORT P2
//函數或者變量聲明
extern void LCD12864_WaitIdle();
extern void LCD12864_COM_Write( unsigned char com_da);
extern void LCD12864_NoWaitIdle_COM_Write(unsigned char com_da);
extern void LCD12864_Data_Write(unsigned char da);
extern void lcd_delay_ms(unsigned char x);
extern void LCD12864_Reset();
extern void LCD12864_write_word(unsigned char *s);
//extern void LCD12864_PHOTO_SET();
extern void LCD12864_HAIZI_SET();
//extern void LCD12864_HAIZI_WRITE(unsigned char xpos,unsigned char ypos,unsigned char daH,unsigned char daL);
//extern void LCD12864_PHOTO_WRITE(unsigned char *img);
#endif
HX711.h:
#ifndef __HX711_H__
#define __HX711_H__
#include <reg52.h>
//IO設置
sbit HX711_DOUT=P3^4;
sbit HX711_SCK=P3^5;
//函數或者變量聲明
extern void Delay__hx711_us(void);
extern unsigned long HX711_Read(void);
#endif
LCD12864.c:
//LCD12864  忙 信號檢測
    unsigned char i;
    LCD12864_DA_PORT = 0xff;
    LCD12864_RS_PORT = 0;
    LCD12864_RW_PORT = 1;
    LCD12864_E_PORT = 1;
    while((LCD12864_DA_PORT&0x80)==1); /*等待BF 不為1*/
    LCD12864_E_PORT = 0;
    for(i=0;i<5;i++);
//檢測忙信號寫入命令字    com_da 為待寫入的命令字
    LCD12864_RW_PORT = 0;
    LCD12864_DA_PORT = com_da;
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
//不檢測忙信號寫入命令字        com_da 為待寫入的命令字
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
//數據寫入        da  為待寫入的8位數據
    LCD12864_WaitIdle(); /*檢測忙信號*/
    LCD12864_RS_PORT = 1;
    LCD12864_DA_PORT = da;
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
//寫連續字符函數
    while(*s>0)
        LCD12864_Data_Write(*s);
        s++;
//1MS為單位的延時程序,不準確
    unsigned char j;
    while(x--){
        for(j=0;j<125;j++)
//LCD12864初始化
    lcd_delay_ms(100); /*適當延時待LCD自動復位完成*/
    LCD12864_NoWaitIdle_COM_Write(0x30); /*使用8位并口通訊*/
    lcd_delay_ms(10);
    lcd_delay_ms(10);
    LCD12864_NoWaitIdle_COM_Write(0x0c); /*顯示開及光標設置*/
    lcd_delay_ms(10);
    LCD12864_NoWaitIdle_COM_Write(0x01); /*顯示清屏*/
    lcd_delay_ms(30);
    LCD12864_NoWaitIdle_COM_Write(0x06); /*DDRAM的地址計數器(AC)加1*/
    lcd_delay_ms(30);
//void LCD12864_PHOTO_SET()
//    LCD12864_COM_Write(0x36);
//    lcd_delay_ms(10);
    LCD12864_COM_Write(0x30);
    lcd_delay_ms(10);
    lcd_delay_ms(10);
//void LCD12864_HAIZI_WRITE(unsigned char xpos,unsigned char ypos,unsigned char daH,unsigned char daL)
////ST7920 漢字字符寫入
////參數說明:     xpos 待寫入的X位置
////ypos 待寫入的Y位置
////daH 待寫入的漢字的高八位 daL待寫入的漢字的低八位
//    unsigned char xy_pos;
//    if((xpos>=8)||(ypos>=4) ) return; /*X位置超出顯示范圍退出*/
//    if(ypos==0)         xy_pos = 0x80 + xpos;
//    else if(ypos==1) xy_pos = 0x90 + xpos; /*計算轉換地址*/
//    else if(ypos==2) xy_pos = 0x88 + xpos;
//    else if(ypos==3) xy_pos = 0x98 + xpos;
//    LCD12864_COM_Write(xy_pos); /*寫地址*/
//    lcd_delay_ms(1);
//    LCD12864_Data_Write(daH); /*寫高八位數據*/
//    lcd_delay_ms(1);
//    LCD12864_Data_Write(daL); /*寫低八位數據*/
//    lcd_delay_ms(1);
//void LCD12864_PHOTO_WRITE(unsigned char *img)
//    unsigned char x,y,i,j;
//    unsigned int k=0;
//    y=0x80; /*設置起始 繪圖區的 Y地址坐標*/
//    x=0x80; /*設置起始 繪圖區的 X地址坐標*/
//    for(i=0;i<32;i++){  /*寫上半部*/
//        LCD12864_COM_Write(y);
//        LCD12864_COM_Write(x);
//        for(j=0;j<16;j++){
//            LCD12864_Data_Write(img[k]);
//            k++;
//        y++;
//    x=0x88; /*設置起始 繪圖區的 X地址坐標*/
//    for(i=0;i<32;i++){  /*寫下半部*/
//            k++;
//        y++;
HX711.c:
#include "HX711.h"
//延時函數
    _nop_();
    _nop_();
//讀取HX711
unsigned long HX711_Read(void)    //增益128
    unsigned long count;
    unsigned char i;
      HX711_DOUT=1;
    Delay__hx711_us();
      HX711_SCK=0;
      count=0;
      while(HX711_DOUT);
      for(i=0;i<24;i++)
          HX711_SCK=1;
          count=count<<1;
        HX711_SCK=0;
          if(HX711_DOUT)
            count++;
     HX711_SCK=1;
    Delay__hx711_us();
    HX711_SCK=0;
    return(count);
電路圖
電路圖
12864中文.doc
2.61 MB, 下載次數: 25, 下載積分: 黑幣 -5
附上12864說明
作者: zy757    時間: 2018-8-25 23:10
樓主最好把液晶屏顯示的也發一張圖更有吸引力
