貪吃蛇游戲程序分模塊檢測好用,合在一起單片機執行得時候功能不能實現
lynn710
2018-8-15 02:54
貪吃蛇游戲程序分模塊檢測好用,合在一起單片機執行得時候功能不能實現,一直按復位鍵部分功能可能好用,很多功能執行不了,謝謝
#include"reg52.h"
#include "intrins.h"
sbit RS=P2^6; //并行的指令/數據選擇信號, H數據, L命令
sbit RW=P2^5; //并行讀寫選擇信號, H讀, L寫
sbit E=P2^7; //并行使能端, H有效, L無效
sbit PSB=P3^2; //并/串接口選擇, H并,L串
sbit RET=P3^4; //復位, L有效
sbit kxuanze=P3^1;
sbit kenter=P3^3;
#define LcdData P0
#define N 25
unsigned char moshiceshi;
unsigned char flag,s1num;
#define OS_LONG_EYK_EN 1 //如果應用中需要處理長按鍵動作,則定義為1,否則定義為0(如果應用中不需要處理長按動作,則建議定義為0,以節省代碼空間)
#define GPIO_KEY P1
unsigned char KeyValue;//用來存放讀取到的鍵值
unsigned char code DIG_CODE[17]={
0,0,0,0,0,5,0,0,6,0,4,0,0,3,0,0,0};
static unsigned long Seed = 1;
#define A 48271L
#define M 2147483647L
#define Q (M / A)
#define R (M % A)
struct Food
unsigned char x;
unsigned char y;
unsigned char yes;
}food;//食物結構體
struct Snake
unsigned char x[N];
unsigned char y[N];
unsigned char node;
unsigned char direction;
unsigned char life;
}snake;//蛇結構體
unsigned char Flag_gamedisplay=0;
unsigned char Score=0;
unsigned char Speed_tiaosu; //speed越大,速度越慢
unsigned char KeyBuffer=0;
#define FUNC 1 //(P3^1)表示級別
#define UP 2 //(P3^3)表示左
#define DOWN 3 //(P3^5)表示右
#define LEFT 4 //(P3^4)表示下
#define RIGHT 5 //(P3^2)表示上
#define PASSSCORE 20 //預定義過關成績
void Lcd_WriteData(unsigned char);
unsigned char Check_Busy(void);
unsigned char Lcd_ReadData(void);
void Lcd_WriteCmd(unsigned char);
void Lcd_PutPixel(unsigned char,unsigned char,unsigned char);
//unsigned char Lcd_ReadPixel(unsigned char,unsigned char);
void Lcd_HoriLine(unsigned char,unsigned char,unsigned char Length,unsigned char Color);
void Lcd_VertLine(unsigned char x,unsigned char y,unsigned char Length,unsigned char Color);
void Lcd_Line(unsigned char x1,unsigned char y1,unsigned char x2,unsigned char y2,unsigned char Color);
void Lcd_Rectangle(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char Color);
void Lcd_Circle(unsigned char x,unsigned char y,unsigned char r,unsigned char Color);
void Lcd_Clear(unsigned char);
void Lcd_WriteStr(unsigned char,unsigned char,unsigned char *);
void Lcd_Reset(void);
unsigned char OSReadKey(void);
unsigned char KeyDown(); //檢測按鍵函數
void Delay10ms(void); //延時10ms
double Random(void);
void InitRandom(unsigned long InitVal);
void InitCpu(void);
void DrawBoardf();
void Drawboardt(void);
void PrintScore(void);
void PrintSpeed(void);
void GameOver(void);
void Gameplayt(void);
void GamePlayf(void);
void delay(unsigned int t);
void delayus(unsigned int j);
void lcd_st(unsigned char *st);
void scankey(void);
void moshi(void);
void zhujiemian(void);
unsigned char moshi1(void);
unsigned char moshi2(void);
void speed(void);
void Speed1(void);
void Speed2(void);
void Speed3(void);
void Speed4(void);
void game(void);
Lcd_Reset();
Lcd_WriteStr(0,0,"Welcome");
Lcd_WriteStr(2,2,"貪吃蛇");
delay(20000000);
zhujiemian();
scankey();
測試LCD是否處于忙狀態
如果忙則返回0x80,否則返回0
unsigned char Lcd_CheckBusy(void)
unsigned char Busy;
LcdData=0xff;
RS=0;
RW=1;
E=1;
_nop_();
Busy=LcdData&0x80;
E=0;
return Busy;
向LCD寫入字節數據
void Lcd_WriteData(unsigned char LCD_Data)
while(Lcd_CheckBusy());
RS=1;
RW=0;
E=0;
_nop_();
_nop_();
LcdData=LCD_Data;
E=1;
_nop_();
_nop_();
E=0;
從LCD中讀出數據
unsigned char Temp;
//while(Lcd_CheckBusy());
LcdData=0xff;
RS=1;
RW=1;
E=1;
_nop_();
Temp=LcdData;
E=0;
return Temp;
向LCD中寫入指令代碼
void Lcd_WriteCmd(unsigned char CmdCode)
RS=0;
RW=0;
E=0;
_nop_();
_nop_();
LcdData=CmdCode;
_nop_();
_nop_();
E=1;
_nop_();
_nop_();
E=0;
void set_postion(unsigned char x,unsigned char y)
unsigned char postion;
switch(x)
case 0:x=0x80;break;
case 1:x=0x90;break;
case 2:x=0x88;break;
case 3:x=0x98;break;
default:break;
postion=x+y;
Lcd_WriteCmd(postion);
向LCD指定起始位置寫入一個字符串
void Lcd_WriteStr(unsigned char x,unsigned char y,unsigned char *Str)
if((y>3)||(x>7))
return;//如果指定位置不在顯示區域內,則不做任何寫入直接返回
EA=0;
switch(y)
case 0:
Lcd_WriteCmd(0x80+x);
break;
case 1:
Lcd_WriteCmd(0x90+x);
break;
case 2:
Lcd_WriteCmd(0x88+x);
break;
case 3:
Lcd_WriteCmd(0x98+x);
break;
while(*Str>0)
Lcd_WriteData(*Str);
Str++;
EA=1;
為加速邏輯運算而設置的掩碼表,這是以犧牲空間而換取時間的辦法
code unsigned int MaskTab[]={0x0001,0x0002,0x0004,0x0008,0x0010,0x0020,0x0040,0x0080,
0x0100,0x0200,0x0400,0x0800,0x1000,0x2000,0x4000,0x8000};
向LCD指定坐標寫入一個象素,象素顏色有兩種,0代表白(無顯示),1代表黑(有顯示)
void Lcd_PutPixel(unsigned char x,unsigned char y,unsigned char Color)
unsigned char z,w;
unsigned int Temp;
if(x>=128||y>=64)
return;
Color=Color%2;
w=15-x%16;//確定對這個字的第多少位進行操作
x=x/16;//確定為一行上的第幾字
if(y<32) //如果為上頁
z=0x80;
else //否則如果為下頁
z=0x88;
y=y%32;
EA=0;
Lcd_WriteCmd(0x36);
Lcd_WriteCmd(y+0x80); //行地址
Lcd_WriteCmd(x+z); //列地址
Temp=Lcd_ReadData();//先空讀一次
Temp=(unsigned int)Lcd_ReadData()<<8;//再讀出高8位
Temp|=(unsigned int)Lcd_ReadData();//再讀出低8位
EA=1;
if(Color==1) //如果寫入顏色為1
Temp|=MaskTab[w];//在此處查表實現加速
else //如果寫入顏色為0
Temp&=~MaskTab[w];//在此處查表實現加速
EA=0;
Lcd_WriteData(Temp>>8);//先寫入高8位,再寫入低8位
Lcd_WriteData(Temp&0x00ff);
Lcd_WriteCmd(0x30);
EA=1;
向LCD指定位置畫一條長度為Length的指定顏色的水平線
void Lcd_HoriLine(unsigned char x,unsigned char y,unsigned char Length,unsigned char Color)
unsigned char i;
if(Length==0)
return;
for(i=0;i<Length;i++)
Lcd_PutPixel(x+i,y,Color);
向LCD指定位置畫一條長度為Length的指定顏色的垂直線
unsigned char i;
if(Length==0)
return;
Lcd_PutPixel(x,y+i,Color);
向LCD指定起始坐標和結束坐標之間畫一條指定顏色的直線
unsigned int x,y;
unsigned int d_x,d_y;//d_x=x2-x1;d_y=y2-y1;
int err=0;
unsigned char temp=0;
if(y2<y1)
x=x1;
y=y1;
x1=x2;
y1=y2;
x2=x;
y2=y;
d_y=y2-y1;
if (d_y==0)
if (x1>x2)
x=x1;
x1=x2;
x2=x;
for (x=x1;x<=x2;x++)
Lcd_PutPixel(x,y1,Color);
if(x2>=x1)
temp=1;
d_x=x2-x1;
d_x=x1-x2;
x=x1;
y=y1;
Lcd_PutPixel(x,y,1);
if(temp&&(d_y<=d_x))
while(x!=x2)
if(err<0)
x=x+1;
err=err+(y2-y);
x=x+1;
y=y+1;
err=err+(y2-y)-(x2-x);
Lcd_PutPixel(x,y,Color);
else if(temp&&(d_y>d_x))
while(y!=y2)
d_x=x2-x;
d_y=y2-y;
if(err<0)
x=x+1;
y=y+1;
err=err+d_y-d_x;
y=y+1;
err=err-d_x;
else if(!temp&&(d_y<=d_x))
while(x!=x2)
d_x=x-x2;
d_y=y2-y;
if(err<0)
x=x-1;
err=err+d_y;
x=x-1;
y=y+1;
err=err+d_y-d_x;
else if(!temp &&(d_y>d_x))
while(y!=y2)
d_x=x-x2;
d_y=y2-y;
if(err<0)
x=x-1;
y=y+1;
err=err+d_y-d_x;
y=y+1;
err=err-d_x;
向LCD指定左上角坐標和右下角坐標畫一個指定顏色的矩形
unsigned char Temp;
if(x0>x1)
Temp=x0;
x0=x1;
x1=Temp;
if(y0>y1)
Temp=y0;
y0=y1;
y1=Temp;
Lcd_VertLine(x0,y0,y1-y0+1,Color);
Lcd_VertLine(x1,y0,y1-y0+1,Color);
Lcd_HoriLine(x0,y0,x1-x0+1,Color);
Lcd_HoriLine(x0,y1,x1-x0+1,Color);
對稱法畫圓的8個鏡像點
void CircleDot(unsigned char x,unsigned char y,char xx,char yy,unsigned char Color)//內部函數,對稱法畫圓的8個鏡像點
Lcd_PutPixel((x+yy),(y+xx),Color);//第 1 個 8 分圓
Lcd_PutPixel((x+xx),(y+yy),Color);//第 2 個 8 分圓
Lcd_PutPixel((x-xx),(y+yy),Color);//第 3 個 8 分圓
Lcd_PutPixel((x-yy),(y+xx),Color);//第 4 個 8 分圓
Lcd_PutPixel((x-yy),(y-xx),Color);//第 5 個 8 分圓
Lcd_PutPixel((x-xx),(y-yy),Color);//第 6 個 8 分圓
Lcd_PutPixel((x+xx),(y-yy),Color);//第 7 個 8 分圓
Lcd_PutPixel((x+yy),(y-xx),Color);//第 8 個 8 分圓
向LCD指定圓心坐標畫一個半徑為r的指定顏色的圓
void Lcd_Circle(unsigned char x,unsigned char y,unsigned char r,unsigned char Color)//中點法畫圓
{//中點法畫圓
unsigned char xx,yy;
char deltax,deltay,d;
xx=0;
yy=r;
deltax=3;
deltay=2-r-r;
d=1-r;
CircleDot(x,y,xx,yy,Color);//對稱法畫圓的8個鏡像點
while (xx<yy)
if (d<0)
d+=deltax;
deltax+=2;
xx++;
d+=deltax+deltay;
deltax+=2;
deltay+=2;
xx++;
yy--;
清除Lcd全屏,如果清除模式Mode為0,則為全屏清除為顏色0(無任何顯示)
否則為全屏清除為顏色1(全屏填充顯示)
void Lcd_Clear(unsigned char Mode)
unsigned char x,y,ii;
unsigned char Temp;
if(Mode%2==0)
Temp=0x00;
Temp=0xff;
Lcd_WriteCmd(0x36);//擴充指令 繪圖顯示
for(ii=0;ii<9;ii+=8)
for(y=0;y<0x20;y++)
for(x=0;x<8;x++)
EA=0;
Lcd_WriteCmd(x+0x80+ii); //列地址
Lcd_WriteData(Temp); //寫數據 D15-D8
Lcd_WriteData(Temp); //寫數據 D7-D0
EA=1;
Lcd_WriteCmd(0x30);
LCD初始化
PSB=1;
Lcd_WriteCmd(0x30); //選擇基本指令集
delay(5);
Lcd_WriteCmd(0x0c); //開顯示(無游標、不反白)
delay(5);
Lcd_WriteCmd(0x01); //清除顯示,并且設定地址指針為00H
delay(5);
Lcd_WriteCmd(0x06); //指定在資料的讀取及寫入時,設定游標的移動方向及指定顯示的移位
void Delay10ms(void) //誤差 0us
unsigned char a,b,c;
for(c=1;c>0;c--)
for(b=38;b>0;b--)
for(a=130;a>0;a--);
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<10;j++);
按鍵驅動掃描
掃描一次鍵盤以獲得按鍵句柄
注:交OSReadKey()函數調用
unsigned char KeyDown(void)
char a=0;
GPIO_KEY=0x0f;
if(GPIO_KEY!=0x0f)//讀取按鍵是否按下
Delay10ms();//延時10ms進行消抖
if(GPIO_KEY!=0x0f)//再次檢測鍵盤是否按下
//測試列
GPIO_KEY=0X0F;
switch(GPIO_KEY)
case(0X07): KeyValue=0;break;
case(0X0b): KeyValue=1;break;
case(0X0d): KeyValue=2;break;
case(0X0e): KeyValue=3;break;
//測試行
GPIO_KEY=0XF0;
switch(GPIO_KEY)
case(0X70): KeyValue=KeyValue;break;
case(0Xb0): KeyValue=KeyValue+4;break;
case(0Xd0): KeyValue=KeyValue+8;break;
case(0Xe0): KeyValue=KeyValue+12;break;
while((a<50)&&(GPIO_KEY!=0xf0)) //檢測按鍵松手檢測
Delay10ms();
a++;
return KeyValue;
功能說明:讀取按鍵動作
入口參數:無
出口參數:返回按鍵動作
注意:
沒有按鍵動作,則返回0,
使用矩陣按鍵:向上S12;向下S6;向左S12;向右S9;
static unsigned char KeyEventCnt=0;
static unsigned char KeySampleCnt=0;
static unsigned char KeyBuffer=0;
#define SHORT_ON_DITHERING_COUNTER 3//定義短按按下去抖時間
#define SHORT_OFF_DITHERING_COUNTER 3//定義短按松開去抖時間,一般與短按按下去抖時間相同
#if OS_LONG_EYK_EN>0
static unsigned int LongKeySampleCnt=0;
#define LONG_ON_DITHERING_COUNTER 250//定義長按按下確認需要的時間,如果是每1MS調用一次OSReadKey(),則1000意味著這個時間為1S
#define LONG_OFF_DITHERING_COUNTER 3//定義長按松開去抖時間,一般和短按去抖時間相同
#endif
unsigned char KeyTemp;
KeyTemp=DIG_CODE[KeyDown()];
switch(KeyEventCnt)
case 0:
if(KeyTemp!=0)
KeySampleCnt=0;
KeyBuffer=KeyTemp;
KeyEventCnt=1;
return 0;//no key on,return 0
break;
case 1:
if(KeyTemp!=KeyBuffer)
KeyEventCnt=0;
return 0;//is dithering,return 0
if(++KeySampleCnt>SHORT_ON_DITHERING_COUNTER)
KeySampleCnt=0;
KeyEventCnt=2;
LongKeySampleCnt=0;
return ((KeyBuffer-1)<<2)+1;//sure that key on,return (KeyBuffer-1)<<2+1
return 0;//not sure that key on,return 0
break;
case 2:
if(++LongKeySampleCnt>LONG_ON_DITHERING_COUNTER)
KeySampleCnt=0;
KeyEventCnt=3;
return ((KeyBuffer-1)<<2)+2; //sure that key long on,return (KeyBuffer-1)<<2+2
if(++KeySampleCnt>SHORT_OFF_DITHERING_COUNTER)
KeyEventCnt=0;
return ((KeyBuffer-1)<<2)+3;//after short on to off,(KeyBuffer-1)<<2+3
return 0;
KeySampleCnt=0;
return 0;
break;
case 3:
if(++KeySampleCnt>LONG_OFF_DITHERING_COUNTER)
KeyEventCnt=0;
return ((KeyBuffer-1)<<2)+4; //after long key on turn to off,(KeyBuffer-1)<<2+4
return 0;
KeySampleCnt=0;
return 0;
break;
#else
case 1:
KeyEventCnt=0;
if(++KeySampleCnt>=SHORT_ON_DITHERING_COUNTER)
KeySampleCnt=0;
KeyEventCnt=2;
break;
case 2:
if(++KeySampleCnt>=SHORT_OFF_DITHERING_COUNTER)
KeyEventCnt=0;
return 0;
KeySampleCnt=0;
return 0;
break;
#endif
default:break;
return 0;
偽隨機數發生器
double Random(void)
long TmpSeed;
TmpSeed=A*(Seed%Q)-R*(Seed/Q);
if(TmpSeed>=0)
Seed=TmpSeed;
Seed=TmpSeed+M;
return (double)Seed/M;
為偽隨機數發生器播種
Seed=InitVal;
初始化MPU
void InitCpu(void)
TMOD=0x01;
TH0=0;
TL0=0;
TR0=1;
ET0=1;
EA=1;
void Timer0Int(void) interrupt 1
switch(OSReadKey())
case 5:
KeyBuffer=FUNC; //表示級別
break;
case 21:
KeyBuffer=DOWN; //表示右
break;
case 13:
KeyBuffer=UP; //表示左
break;
case 9:
KeyBuffer=RIGHT; //表示上
break;
case 17:
KeyBuffer=LEFT; //表示下
break;
default:
break;
畫墻壁,初始化界面
void DrawBoardf()
unsigned char n;
for(n=0;n<31;n++)
Lcd_Rectangle(3*n,0,3*n+2,2,1);
Lcd_Rectangle(3*n,60,3*n+2,62,1);
for(n=0;n<21;n++)
Lcd_Rectangle(0,3*n,2,3*n+2,1);
Lcd_Rectangle(90,3*n,92,3*n+2,1);
Lcd_HoriLine(93,31,35,1);
Lcd_HoriLine(93,63,35,1);
unsigned char n;
for(n=0;n<21;n++)
打印成績
unsigned char Str[3];
Lcd_WriteStr(6,0,"成績");
Str[0]=(Score/10)|0x30;//十位
Str[1]=(Score%10)|0x30;//個位
Str[2]=0;
Lcd_WriteStr(7,1,Str);
打印速度級別
unsigned char Str[2];
Lcd_WriteStr(6,2,"級別");
Str[0]=Speed_tiaosu|0x30;
Str[1]=0;
Lcd_WriteStr(7,3,Str);
游戲結束處理
void GameOver(void)
unsigned char n;
Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隱出食物
for(n=1;n<snake.node;n++)
Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,0);//消隱食物,蛇頭已到墻壁內,故不用消去
if(snake.life==0)//如果蛇還活著
Lcd_WriteStr(2,1,"過關");
else //如果蛇死了
Lcd_WriteStr(2,1,"輸了");
Lcd_WriteStr(1,2,"游戲結束");
游戲的具體過程,也是貪吃蛇算法的關鍵部分
unsigned char n;
InitRandom(TL0);
food.yes=1;//1表示需要出現新事物,0表示已經存在食物尚未吃掉
snake.life=0;//表示蛇還活著
snake.direction=DOWN;
snake.x[0]=6;snake.y[0]=6;
snake.x[1]=3;snake.y[1]=6;
snake.node=2;
PrintScore();
PrintSpeed();
if(food.yes==1)
food.x=Random()*85+3;
food.y=Random()*55+3;//獲得隨機數
while(food.x%3!=0)
food.x++;
while(food.y%3!=0)
food.y++;
for(n=0;n<snake.node;n++)//判斷產生的食物坐標是否和蛇身重合
if((food.x==snake.x[n])&&(food.y==snake.y[n]))
break;
if(n==snake.node)
food.yes=0;
break;//產生有效的食物坐標
if(food.yes==0)
Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,1);
for(n=snake.node-1;n>0;n--)
snake.x[n]=snake.x[n-1];
snake.y[n]=snake.y[n-1];
switch(snake.direction)
case DOWN:snake.x[0]+=3;break;
case UP:snake.x[0]-=3;break;
case RIGHT:snake.y[0]-=3;break;
case LEFT:snake.y[0]+=3;break;
default:break;
for(n=3;n<snake.node;n++)//從第三節開始判斷蛇頭是否咬到自己
if(snake.x[n]==snake.x[0]&&snake.y[n]==snake.y[0])
GameOver();
snake.life=1;
break;
if(snake.x[0]<3||snake.x[0]>=90||snake.y[0]<3||snake.y[0]>=60)//判蛇頭是否撞到墻壁
GameOver();
snake.life=1;
if(snake.life==1)
break;//蛇死,則跳出while(1)循環
if(snake.x[0]==food.x&&snake.y[0]==food.y)//判蛇是否吃到食物
Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隱食物
snake.x[snake.node]=200;
snake.y[snake.node]=200;//產生蛇新的節坐標先放在看不見的位置
snake.node++;//蛇節數加1
food.yes=1;//食物標志置1
if(++Score>=PASSSCORE)
PrintScore();
GameOver();
break;
PrintScore();
Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,1);
}//根據蛇的節數畫出蛇
delay(Speed_tiaosu*1000); //調速
Lcd_Rectangle(snake.x[snake.node-1],snake.y[snake.node-1],snake.x[snake.node-1]+2,snake.y[snake.node-1]+2,0);
switch(KeyBuffer)
case FUNC:
KeyBuffer=0;
if(++Speed_tiaosu>=10)
Speed_tiaosu=1;
PrintSpeed();
break;
case DOWN:
KeyBuffer=0;
if(snake.direction!=UP)
break;
case UP:
KeyBuffer=0;
if(snake.direction!=DOWN)
snake.direction=UP;
break;
case RIGHT:
KeyBuffer=0;
if(snake.direction!=LEFT)
snake.direction=RIGHT;
break;
case LEFT:
KeyBuffer=0;
if(snake.direction!=RIGHT)
snake.direction=LEFT;
break;
default:
break;
unsigned char n;
InitRandom(TL0);
snake.node=2;
PrintScore();
PrintSpeed();
if(food.yes==1)
while(food.x%3!=0)
food.x++;
while(food.y%3!=0)
food.y++;
break;
if(n==snake.node)
food.yes=0;
break;//產生有效的食物坐標
if(food.yes==0)
default:break;
GameOver();
snake.life=1;
break;
if(snake.x[0]<3||snake.x[0]>=90)//判蛇頭是否撞到墻壁
GameOver();
snake.life=1;
if(snake.life==1)
if(snake.y[0]<3||snake.y[0]>=60)
{ if(snake.y[0]<3)
snake.y[0]=59;
// for(n=0;n<snake.node;n++)
// Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,1);
// }//根據蛇的節數畫出蛇
if(snake.y[0]>=60)
snake.y[0]=3;
// }//根據蛇的節數畫出蛇
food.yes=1;//食物標志置1
PrintScore();
GameOver();
break;
PrintScore();
}//根據蛇的節數畫出蛇
switch(KeyBuffer)
case FUNC:
KeyBuffer=0;
Speed_tiaosu=1;
PrintSpeed();
break;
case DOWN:
KeyBuffer=0;
break;
case UP:
KeyBuffer=0;
snake.direction=UP;
break;
case RIGHT:
KeyBuffer=0;
break;
case LEFT:
KeyBuffer=0;
break;
default:
break;
void scankey(void)
void speed(void)
Lcd_WriteStr(0,1,"Speed1");
Lcd_WriteStr(1,1,"Speed2");
Lcd_WriteStr(2,1,"Speed3");
Lcd_WriteStr(3,1,"Speed4");
void moshi(void)
Lcd_WriteStr(0,1,"mosho1");
Lcd_WriteStr(1,1,"moshi2");
Lcd_WriteCmd(0x01);
Lcd_WriteStr(0,0,"開始游戲");
Lcd_WriteStr(0,1,"速度選擇");
Lcd_WriteStr(0,2,"模式設置");
unsigned char moshi1()
moshiceshi=1;
DrawBoardf();
GamePlayf();
return moshiceshi;
zhujiemian();
unsigned char moshi2()
moshiceshi=2;
Drawboardt();
Gameplayt();
return moshiceshi;
zhujiemian();
void Speed1(void)
unsigned char Speed_tiaosu=1;
zhujiemian();
void Speed2(void)
unsigned char Speed_tiaosu=2;
zhujiemian();
void Speed3(void)
unsigned char Speed_tiaosu=3;
zhujiemian();
void Speed4(void)
unsigned char Speed_tiaosu=4;
zhujiemian();
void game(void)
InitCpu();//初始化CPU
Lcd_Reset(); //初始化LCD屏
delay(5000);
Lcd_Clear(0);//清屏
switch(Speed_tiaosu)
case '1':
Speed1();
break;
case '2':
Speed2();
break;
case '3':
Speed3();
break;
case '4':
Speed4();
break;
default:
Speed4();
switch(moshiceshi)
case '1':
moshi1();
break;
case '2':
moshi2();
break;
default:
moshi1();
GameOver();//游戲結束
heyaodz
2018-8-15 17:42
代碼太長了,估計沒幾個人能看下去吧,發重點
jsq347
2018-8-18 17:46
同求 這么長的東西
