標題: STM32制作RTC實時實驗 - 按鍵+2個鬧鐘+觸屏源碼 [打印本頁]
作者: 1911733869    時間: 2018-8-1 15:38
通過對RTC的時鐘編寫,可實現按鍵修改和TFT液晶顯示
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include "lcd.h"
  6. #include "usmart.h"
  7. #include "rtc.h"
  8. #include "timer.h"
  9. #include "key.h"
  10. #include "24cxx.h"
  11. #include "myiic.h"
  12. #include "touch.h"
  13. _calendar_obj calendar_buf;         //存放設置完成時的值
  14.   _alarm_obj alarm_buf;         //存放設置完成時的值
  15. int main(void)
  16. {
  17.         u8 t=0;
  18.         u8 t1=0;
  19.         u8 temp=0;
  20.         u8 move=0;         //move為移動的偏移量
  21.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 設置中斷優先級分組2
  22.         delay_init();                     //延時函數初始化
  23.         uart_init(9600);                 //串口初始化為9600
  24.         LED_Init();                                //初始化與LED連接的硬件接口
  25.          LCD_Init();                                //初始化LCD
  26.         KEY_Init();
  27.         TIM2_Init(799,89);
  28.         TIM3_Init(799,89);
  29.         usmart_dev.init(72);        //初始化USMART
  30.         tp_dev.init();                        //觸摸屏初始
  31.         POINT_COLOR=RED;//設置字體為紅色
  32.         while(RTC_Init())                //RTC初始化        ,一定要初始化成功
  33.         {
  34.                 LCD_ShowString(60,130,200,16,16,"RTC ERROR!   ");
  35.                 delay_ms(800);
  36.                 LCD_ShowString(60,130,200,16,16,"RTC Trying...");
  37.         }
  38.         //顯示時間
  39.         POINT_COLOR=BLUE;//設置字體為藍色
  40.         LCD_ShowString(0,10,200,24,24,"  Date     ");
  41.         LCD_ShowString(0,45,200,24,24,"         -   - ");
  42.         LCD_ShowString(0,80,200,24,24,"  Week     ");
  43.         LCD_ShowString(0,150,200,24,24,"  Time     ");
  44.         LCD_ShowString(0,185,200,24,24,"        :   :    ");
  45.         LCD_ShowString(0,220,200,24,24,"  Alarm time");        //按鍵調整時間
  46.   LCD_ShowString(0,255,200,24,24,"        :   :  ");
  47.         LCD_ShowString(0,280,200,24,24,"        :   :  ");
  48.         while(1)
  49.         {
  50.     t1=move;
  51.                                 if(TIMChange1&(0x01<<7))                  //每5ms讀一次鍵值
  52.                 {
  53.                         TIMChange1&=(~(0x01<<7));
  54.             tp_dev.scan(0);
  55.                                         if(tp_dev.sta&TP_PRES_DOWN)                        //觸摸屏被按下
  56.                         {
  57.                                 delay_ms(100);
  58.                                 if(tp_dev.x[0]<lcddev.width&&tp_dev.y[0]<lcddev.height)
  59.                         {
  60.                                         if(tp_dev.x[0]>(lcddev.width-230)&&tp_dev.y[0]<290)
  61.                            Press_KEY_SUB(move);        //數值減(下鍵)
  62.                         }
  63.                         }
  64.                 }
  65.                 if(TIMChange&(0x01<<6))                  //每5ms讀一次鍵值
  66.                 {
  67.                         TIMChange&=(~(0x01<<6));
  68.                         temp=KEY_Scan(0);                  //讀鍵值,按移動鍵(右鍵)時不支持連按
  69.                         if(temp==KEY_MOVE)
  70.                         {
  71.                                 if(move==12) move=1;          //偏移量循環
  72.                                 else move++;                  //移動偏移量加一
  73.                                 timcnt=0;                           //移動一次就把閃爍計數值復位
  74.                         }
  75.                         if(move)                                   //處于時間設置模式中
  76.                         {
  77.                                 Press_KEY_MOVE(move); //調用子程序,進行閃爍和移動處理
  78.                                 RTC_ITConfig(RTC_IT_SEC, DISABLE);        // 關閉RTC 秒中斷
  79.                         }
  80.                         if(temp==KEY_ADD)Press_KEY_ADD(move);         //按數值加鍵(上鍵),數值加一,不支持連按
  81.                         //if(temp==KEY_SUB)Press_KEY_SUB(move);        //數值減(下鍵),支持連按
  82.                                         if(temp==KEY_SURE&&move)                                                 //確定鍵(左鍵)
  83.                         {
  84.                                 move=0;        //move復位
  85.                                 calendar_buf=calendar;                                //把設置完的值放入緩沖區
  86.                                 alarm_buf=alarm;                                //把設置完的值放入緩沖區
  87.                                 RTC_ITConfig(RTC_IT_SEC, ENABLE);   //使能 RTC 秒中斷
  88.                                 delay_ms(1);                                                //關閉秒中斷時,RTC還是在走的,開啟秒中斷后要延時一段時間,把舊值覆蓋掉
  89.                                 calendar=calendar_buf;                                //用設置后的值覆蓋舊值
  90.                                 alarm=alarm_buf;                                //用設置后的值覆蓋舊值
  91.                                 RTC_Set(calendar.year,calendar.month,calendar.date,calendar.hour,calendar.min,calendar.sec);//寫入新值
  92.                                 Set_Alarm(calendar.year,calendar.month,calendar.date,alarm.hour1,alarm.min1,alarm.sec1,alarm.hour2,alarm.min2,alarm.sec2);//寫入新值
  93.                         }
  94.                         if((t!=calendar.sec&&move==0)||t1!=move) //秒更新或者按下移位鍵,顯示時間
  95.                         {
  96.                                 t=calendar.sec;
  97.                                 POINT_COLOR=BLUE;
  98.                                 LCD_ShowNum(55,45,calendar.year,4,24);
  99.                                 LCD_ShowNum(125,45,calendar.month,2,24);
  100.                                 LCD_ShowNum(180,45,calendar.date,2,24);
  101.                                 switch(calendar.week)
  102.                                 {
  103.                                         case 0:
  104.                                                 LCD_ShowString(60,115,200,24,24,"Sunday   ");
  105.                                                 break;
  106.                                         case 1:
  107.                                                 LCD_ShowString(60,115,200,24,24,"Monday   ");
  108.                                                 break;
  109.                                         case 2:
  110.                                                 LCD_ShowString(60,115,200,24,24,"Tuesday  ");
  111.                                                 break;
  112.                                         case 3:
  113.                                                 LCD_ShowString(60,115,200,24,24,"Wednesday");
  114.                                                 break;
  115.                                         case 4:
  116.                                                 LCD_ShowString(60,115,200,24,24,"Thursday ");
  117.                                                 break;
  118.                                         case 5:
  119.                                                 LCD_ShowString(60,115,200,24,24,"Friday   ");
  120.                                                 break;
  121.                                         case 6:
  122.                                                 LCD_ShowString(60,115,200,24,24,"Saturday ");
  123.                                                 break;
  124. ……………………
  125. …………限于本文篇幅 余下代碼請從51黑下載附件…………
RTC實時實驗 - 按鍵+2個鬧鐘 +觸屏.rar (480.69 KB, 下載次數: 144)
作者: pql    時間: 2018-9-3 21:22
不錯!!
作者: lwdlwd    時間: 2018-9-27 17:00
好像還可以 應該用的也是m3s那個單片機 哈哈哈哈
作者: xudongqiang    時間: 2019-5-14 14:20
下載下來看看,謝謝分享
作者: quicklee    時間: 2020-3-30 13:11
經過調試,實現了在oled上顯示與調時。但有個問題是alarm這個結構體每次初始化后都為0,且不能觸發鬧鐘中斷是怎么回事
作者: 袁小慶    時間: 2021-8-30 11:17
學習了多個鬧鐘,互相中斷阻塞的問題
