ADC0832轉換5V電壓表源程序
lx5204441
2018-7-25 20:28
ADC0832轉換5V電壓表源程序
(9.77 KB, 下載次數(shù): 31)
5V電壓表
2018-7-25 20:26 上傳
#include <reg52.h>
#include <intrins.h>
#include <string.h>
sbit CS = P1^0;
sbit CLK = P1^1;
sbit DI = P1^2;
sbit DO = P1^2;
sbit RS = P2^0;
sbit RW = P2^1;
sbit E = P2^2;
uchar Result_ADC0832=0;
uchar Display_Buffer [2][16] ={
{"Current Voltage:"},
{"(CH)= 0.00V"}
uchar Get_Value_ADC0832();
void Refesh_Disp_Buffer();
void LCD_Busy_Check();
void LCD_Write_Command(uchar cmd);
void Write_LCD_Data(uchar dat);
void Initialize_LCD1602();
void LCD_Display(uchar str[]);
void DelayMS(uint X);
uchar Read_State();
uchar j;
for(j=0;j<2;j++)
if(j==0)
LCD_Write_Command(0x80);
LCD_Display(Display_Buffer[j]);
LCD_Write_Command(0xC0);
uchar i,dat1=0,dat2=0;
CS=0; _nop_(); _nop_();
CLK=0; _nop_(); _nop_();
DI=1; _nop_(); _nop_();
CLK=1; _nop_(); _nop_();
CLK=0; DI=1; _nop_(); _nop_();
CLK=1; DI=0; _nop_(); _nop_();
for(i=0;i<8;i++)
dat1=dat1<<1|DO;
for(i=0;i<8;i++)
dat2=dat2|((uchar)(DO)<<i);
CS=1;
DI=1;
return Result_ADC0832=(dat1==dat2)?dat1:0;
uint t=Result_ADC0832*500.0/255;
if(t==1) t==0;
Display_Buffer[1][7] = t/100+'0';
Display_Buffer[1][9] =t%100/10+'0';
Display_Buffer[1][10] = t%100/10+'0';
uchar i;
while(X--) for(i=0;i<120;i++);
uchar Read_State()
uchar state;
RS=0;
RW=1;
E=1;
DelayMS(1);
state=P0;
E=0;
DelayMS(1);
return state;
while(Read_State()& 0x80!=0x80);
DelayMS(1);
LCD_Busy_Check();
RS=0;
RW=0;
E=0;
P0=cmd;
E=1;
DelayMS(1);
E=0;
LCD_Busy_Check();
RS=1;
RW=0;
E=0;
P0=dat;
E=1;
DelayMS(1);
E=0;
LCD_Write_Command(0x38);DelayMS(1);
LCD_Write_Command(0x0C);DelayMS(1);
LCD_Write_Command(0x06);DelayMS(1);
LCD_Write_Command(0x01);DelayMS(1);
void LCD_Display(uchar *str)
uchar k;
for(k=0;k<strlen(str);k++)
Write_LCD_Data(str[k]);
DelayMS(2);
s360221867
2018-9-17 19:21
怎么 出不來結果呢 只是5V不動
zimo123
2018-9-23 17:10
第81行的t==0不知道啥意思。第83、84修改成這樣精度可以高一點 Display_Buffer[1][9] =t/10%10+'0';
Display_Buffer[1][10] = t%10+'0';
