標題: ESP8266WiFi模塊 [打印本頁]
作者: 想回家的我    時間: 2018-7-21 11:09
標題: ESP8266WiFi模塊
#include<reg51.h>
#include<string.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit led=P1^0;
sbit led2 = P1^7;
u16 Num = 0;
u8 receive[30];
u8 k;
void delay5ms(void)
    unsigned char a,b;
    for(b=19;b>0;b--)
        for(a=130;a>0;a--);
void connectinit()
char *a="AT+CIPMUX=1\r\n";
char *b="AT+CIPSERVER=1,8080\r\n";
while(*a!='\0')
SBUF=*a;
while(!TI);
TI=0;
a++;
delay5ms();
while(*b!='\0')
      SBUF=*b;
  while(!TI);
  TI=0;
  b++;
void InitUART(void)
    TMOD = 0x20;
    SCON = 0x50;
    TH1 = 0xFA; //??????9600
    TL1 = 0xFA;
    PCON=0X80;
ET1=0;
    EA = 1;
    ES = 1;
    TR1 = 1;
int j;
    InitUART();
connectinit();
led = 0;
  switch(k)
  case '1':
   led=1;
   for(j=0; j<100; j++)
    delay5ms();
   break;
  case '2':
   led=0;
    delay5ms();
   break;
  default:
   led2 = 1;
    delay5ms();
   led2 = 0;
    delay5ms();
void Uart() interrupt 4
char res;
if(RI==1)
  res=SBUF;
  RI=0;
  if(res==':'||Num>0)
   receive[Num]=res;
   Num++;
   if(res=='\n')
    k=receive[1];
    SBUF=k;
    while(!TI);
    TI=0;
    Num=0;
    memset(receive,0,30);
