DHT11溫濕度傳感器通過51單片機(jī)1602液晶的顯示
hy1611192142
時(shí)間:
2018-7-13 10:47
(5.21 MB, 下載次數(shù): 68)
結(jié)果展示
2018-7-13 10:32 上傳
單片機(jī)源程序如下:
// DHT21使用范例
//單片機(jī) AT89S52 或 STC89C52RC
//功能 串口發(fā)送溫濕度數(shù)據(jù) 晶振 11.0592M 波特率 9600
//硬件 P2.0口為通訊口連接DHT11,DHT11的電源和地連接單片機(jī)的電源和地,單片機(jī)串口加MAX232連接電腦
//公司 雁凌電子
#include <reg51.h>
#include <intrins.h>
#define LCD1602_DB P0 //LCD1602數(shù)據(jù)總線
sbit LCD1602_RS = P3^5; //RS端
sbit LCD1602_RW = P3^6; //RW端
sbit LCD1602_EN = P3^4; //EN端
//sbit DU = P2^6;//
//sbit WE = P2^7;//數(shù)碼管位選段選用于關(guān)閉數(shù)碼管顯示
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號(hào)8位整型變量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符號(hào)8位整型變量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號(hào)16位整型變量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符號(hào)16位整型變量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號(hào)32位整型變量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符號(hào)32位整型變量 */
typedef float F32; /* single precision floating point variable (32bits) 單精度浮點(diǎn)數(shù)(32位長度) */
typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點(diǎn)數(shù)(64位長度) */
#define Data_0_time 4
//----------------IO口定義區(qū)--------------------//
sbit P2_0 = P2^0 ;
//----------------定義區(qū)--------------------//
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U8 outdata[5]; //定義發(fā)送的字節(jié)數(shù)
U8 indata[5];
U8 a1[5];
U8 b[10];
U8 count, count_r=0;
U8 str[5]={"RS232"};
U16 U16temp1,U16temp2;
void SendData(U8 *a)
outdata[0] = a[0];
outdata[1] = a[1];
outdata[2] = a[2];
outdata[3] = a[3];
outdata[4] = a[4];
count = 1;
SBUF=outdata[0];
void Delay(U16 j)
{ U8 i;
for(;j>0;j--)
for(i=0;i<27;i++);
void Delay_10us(void)
U8 i;
i--;
i--;
i--;
i--;
i--;
i--;
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!P2_0)&&U8FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(P2_0)U8temp=1;
U8FLAG=2;
while((P2_0)&&U8FLAG++);
//超時(shí)則跳出for循環(huán)
if(U8FLAG==1)break;
//判斷數(shù)據(jù)位是0還是1
// 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
U8comdata<<=1;
U8comdata|=U8temp; //0
}//rof
//-----濕度讀取子程序 ------------
//----以下變量均為全局變量--------
//----溫度高8位== U8T_data_H------
//----溫度低8位== U8T_data_L------
//----濕度高8位== U8RH_data_H-----
//----濕度低8位== U8RH_data_L-----
//----校驗(yàn) 8位 == U8checkdata-----
//----調(diào)用相關(guān)子程序如下----------
//---- Delay();, Delay_10us();,COM();
void RH(void)
//主機(jī)拉低18ms
P2_0=0;
Delay(180);
P2_0=1;
//總線由上拉電阻拉高 主機(jī)延時(shí)20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主機(jī)設(shè)為輸入 判斷從機(jī)響應(yīng)信號(hào)
P2_0=1;
//判斷從機(jī)是否有低電平響應(yīng)信號(hào) 如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
if(!P2_0) //T !
U8FLAG=2;
//判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號(hào)是否結(jié)束
U8FLAG=2;
//判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
//數(shù)據(jù)接收狀態(tài)
COM();
U8RH_data_H_temp=U8comdata;
COM();
U8RH_data_L_temp=U8comdata;
COM();
U8T_data_H_temp=U8comdata;
COM();
U8T_data_L_temp=U8comdata;
COM();
U8checkdata_temp=U8comdata;
P2_0=1;
//數(shù)據(jù)校驗(yàn)
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
}//fi
}//fi
*函數(shù)名稱:Read_Busy
*函數(shù)功能:判斷1602液晶忙,并等待
void Read_Busy()
U8 busy;
LCD1602_DB = 0xff;//復(fù)位數(shù)據(jù)總線
LCD1602_RS = 0; //拉低RS
LCD1602_RW = 1; //拉高RW讀
do
LCD1602_EN = 1;//使能EN
busy = LCD1602_DB;//讀回?cái)?shù)據(jù)
LCD1602_EN = 0; //拉低使能以便于下一次產(chǎn)生上升沿
}while(busy & 0x80); //判斷狀態(tài)字BIT7位是否為1,為1則表示忙,程序等待
*函數(shù)名稱:LCD1602_Write_Cmd
*函數(shù)功能:寫LCD1602命令
*調(diào)用:Read_Busy();
*輸入:cmd:要寫的命令
void LCD1602_Write_Cmd(U8 cmd)
Read_Busy(); //判斷忙,忙則等待
LCD1602_RS = 0;
LCD1602_RW = 0; //拉低RS、RW操作時(shí)序情況1602課件下中文使用說明基本操作時(shí)序章節(jié)
LCD1602_DB = cmd;//寫入命令
LCD1602_EN = 1; //拉高使能端 數(shù)據(jù)被傳輸?shù)絃CD1602內(nèi)
*函數(shù)名稱:LCD1602_Write_Dat
*函數(shù)功能:寫LCD1602數(shù)據(jù)
*輸入:dat:需要寫入的數(shù)據(jù)
void LCD1602_Write_Dat(U8 dat)
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
LCD1602_EN = 0;
*函數(shù)名稱:LCD1602_Dis_OneChar
*函數(shù)功能:在指定位置顯示一個(gè)字符
*調(diào)用:LCD1602_Write_Cmd(); LCD1602_Write_Dat();
*輸入:x:要顯示的橫坐標(biāo)取值0-40,y:要顯示的行坐標(biāo)取值0-1(0為第一行,1為第二行)
dat:需要顯示的數(shù)據(jù)以ASCLL形式顯示
/*void LCD1602_Dis_OneChar(U8 x, U8 y,U8 dat)
if(y) x |= 0x40;
x |= 0x80;
LCD1602_Write_Cmd(x);
LCD1602_Write_Dat(dat);
// LCD1602_Dis_Str(5, 1, & humidity [5]);
// LCD1602_Dis_Str(6, 1, & humidity [6]);
// LCD1602_Dis_Str(7, 1, & humidity [7]);
// LCD1602_Dis_Str(8, 1, & humidity [8]);
// LCD1602_Dis_Str(9, 1, & humidity [9]);
*函數(shù)名稱:LCD1602_Dis_Str
*函數(shù)功能:在指定位置顯示字符串
*str:需要顯示的字符串
void LCD1602_Dis_Str(U8 x, U8 y, U8 *str)
if(y) x |= 0x40;
x |= 0x80;
while(*str != '\0')
LCD1602_Write_Dat(*str++);
*函數(shù)名稱:Init_LCD1602
*函數(shù)功能:1602初始化
*調(diào)用: LCD1602_Write_Cmd();
void Init_LCD1602()
LCD1602_Write_Cmd(0x38); // 設(shè)置16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
LCD1602_Write_Cmd(0x0c); //開顯示
LCD1602_Write_Cmd(0x06); //讀寫一字節(jié)后地址指針加1
LCD1602_Write_Cmd(0x01); //清除顯示
/*lcd1602液晶顯示*/
void lcddisplay()
U8 temperature[] = {"temp: "};
U8 humidity [] = {"humi: RH"};
// DU = 0;
// WE = 0;//關(guān)閉數(shù)碼管顯示
Init_LCD1602();//1602初始化
LCD1602_Dis_Str(0, 0, &temperature[0]); //顯示字符串
LCD1602_Dis_Str(0, 1, & humidity [0]); //顯示字符串
a1[0]=U8RH_data_H;
a1[1]=U8RH_data_L;
a1[2]=U8T_data_H;
a1[3]=U8T_data_L;
a1[4]=U8checkdata;
temperature [5] =(0x30+a1[2]/10);
temperature [6] =(0x30+a1[2]%10);
temperature [7] ='.';
temperature [8] =(0x30+a1[3]/100);
temperature [9] =(0x30+(a1[3]%100)/10);
temperature [14] =(0xdf);
temperature [15] =(0x43);
humidity [5] =(0x30+a1[0]/10);
humidity [6] =(0x30+a1[0]%10);
humidity [7] ='.';
humidity [8] =(0x30+a1[1]/100);
humidity [9] =(0x30+(a1[1]%100)/10);
LCD1602_Dis_Str(5, 0, & temperature [5]);
LCD1602_Dis_Str(6, 0, & temperature [6]);
LCD1602_Dis_Str(7, 0, & temperature [7]);
LCD1602_Dis_Str(8, 0, & temperature [8]);
LCD1602_Dis_Str(9, 0, & temperature [9]);
LCD1602_Dis_Str(14, 0, & temperature [14]);
LCD1602_Dis_Str(15, 0, & temperature [15]);
//LCD1602_Dis_OneChar(15, 1, 0xff); //顯示一個(gè)黑方格 請查表
//main()功能描述: AT89C51 11.0592MHz 串口發(fā)
//送溫濕度數(shù)據(jù),波特率 9600
/* 系統(tǒng)初始化 */
TMOD = 0x20; //定時(shí)器T1使用工作方式2
TH1 = 253; // 設(shè)置初值
TL1 = 253;
TR1 = 1; // 開始計(jì)時(shí)
SCON = 0x50; //工作方式1,波特率9600bps,允許接收
ES = 1;
EA = 1; // 打開所以中斷
TI = 0;
RI = 0;
SendData(str) ; //發(fā)送到串口
Delay(1); //延時(shí)100US(12M晶振)
//調(diào)用溫濕度讀取子程序
RH();
//串口顯示程序
str[0]=U8RH_data_H;
str[1]=U8RH_data_L;
str[2]=U8T_data_H;
str[3]=U8T_data_L;
str[4]=U8checkdata;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
51-DHT11 - 1602程序.rar
(67.68 KB, 下載次數(shù): 188)
2018-7-13 10:44 上傳
點(diǎn)擊文件名下載附件
