標題: 24秒倒計時 [打印本頁]
作者: edc、    時間: 2018-7-12 11:35
標題: 24秒倒計時
#include<stc12c5a60s2.h>
sbit        LED=P2^0;
sbit        BEEP=P1^0;
sbit        CLEAR=P3^3;
sbit        START=P3^2;
typedef unsigned int        uint;
typedef unsigned char        uchar;
void        delay(unsigned        int        i)
        while(i--);
void        main()
        uint        T_Count=0;
        uchar        count;
        LED=1;
        BEEP=1;
        CLEAR=1;
        START=1;
        TMOD=0x01;
        TH0=(65535-50000)/256;
        TL0=(65535-50000)%256;
        while(START);
        TR0=1;
        count=48;
                if(TF0==1)
                        TF0=0;
                        if(++T_Count==10)
                                T_Count=0;
                                LED=~LED;
                                count--;
                                if(count==0)
                                while(CLEAR)
                                        BEEP=1;
                                        delay(200);
                                BEEP=1;
                                while(START);
                                count=48;
