標(biāo)題: Arduino交通燈仿真 [打印本頁]
作者: wrlsohu 時(shí)間: 2018-6-29 15:33
2018-6-29 15:30 上傳
用ATMEGA328P單片機(jī)最小系統(tǒng)仿真
程序如下:
int Led0 = 2; //Red1
int Led1 = 3; //Green1
int Led2 = 4; //Yellow1
int Led3 = 5; //Red2
int Led4 = 6; //Green2
int Led5 = 7; //Yellow2
void setup() {
unsigned char i;
for(i = 2; i < 8; i++)
pinMode(i, OUTPUT); //循環(huán)設(shè)置Ledi為輸出
digitalWrite(i, LOW); //熄滅Ledi
void Styl1(void) {
digitalWrite(Led5, LOW); // 熄滅LED5(Yellow2)
digitalWrite(Led0, LOW); // 熄滅LED0(Red1)
digitalWrite(Led1, HIGH); //點(diǎn)亮LED1(Green1)
digitalWrite(Led3, HIGH); //點(diǎn)亮LED3(Red2)
delay(50000); //延時(shí)50秒
void Styl2(void) {
unsigned char i;
for(i = 0; i < 6; i++) {
digitalWrite(Led1, LOW); // 熄滅LED1(Green1)
delay(500); //等待500毫秒
void Styl3(void) {
digitalWrite(Led2, HIGH); //點(diǎn)亮LED2(Yellow1)
delay(5000); //延時(shí)5秒
void Styl4(void) {
digitalWrite(Led2, LOW); // 熄滅LED2(Yellow1)
digitalWrite(Led3, LOW); // 熄滅LED3(Red2)
digitalWrite(Led0, HIGH); //點(diǎn)亮LED0(Red1)
digitalWrite(Led4, HIGH); //點(diǎn)亮LED4(Green2)
void Styl5(void) {
unsigned char j;
for(j = 0; j < 6; j++) {
digitalWrite(Led4, LOW); // 熄滅LED4(Green2)
void Styl6(void) {
digitalWrite(Led5, HIGH); //點(diǎn)亮LED5(Yellow2)
void loop() {
Styl1();
Styl2();
Styl3();
Styl4();
Styl5();
Styl6();
