標題: 單片機數控電壓源的仿真和源碼設計 [打印本頁]
作者: xdc123456    時間: 2018-6-26 09:34
數控電壓源的設計
設計并制作一個數控電壓源,具體要求:
(1)輸出電壓范圍-5V~+5V;
(2)輸出誤差≤1%;
(3)顯示分辨率滿量程的1%以上;
還差一個(4)具有0.1V步進輸出功能。
  1. /////////////lcd variable/////////////////
  2. #include <absacc.h>
  3. #include <reg51.h>
  4. #define REG0   XBYTE[0x8000]
  5. #define REG1   XBYTE[0x8100]
  6. #define REG2   XBYTE[0x8200]
  7. #define REG3   XBYTE[0x8300]
  8. unsigned char bdata busyflag;
  9. unsigned char dat,datn,count;
  10. unsigned char str[16] = "Output Vol:0.00V";
  11. sbit busyflag_7=busyflag^7;
  12. sbit p10=P1^0;
  13. sbit p11=P1^1;
  14. sbit p12=P1^2;
  15. /////////////////end of lcd variable////////////
  16. ///////////////start  of  lcd 1602/////////////////
  17. void busy()
  18. {
  19.         do
  20.         {
  21.                 busyflag=REG1;
  22.         }while(busyflag_7);
  23. }
  24. void wrc(unsigned char wcon)
  25. {
  26.         busy();
  27.         REG0=wcon;
  28. }
  29. void wrd(unsigned char wdat)
  30. {
  31.         busy();
  32.         REG2=wdat;
  33. }
  34. void rdd()
  35. {
  36.         busy();
  37.         dat=REG3;
  38. }
  39. void lcdint()
  40. {
  41.         wrc(0x38);
  42.         wrc(0x01);
  43.         wrc(0x06);
  44.         wrc(0x0c);
  45. }
  46. void wrn(unsigned char word[])
  47. {
  48.         unsigned char i = 0;
  49.         while(word[i]) {
  50.                 wrd(word[i++]);
  51.         }
  52. }
  53. sbit PIN_JIA = P1^0;
  54. sbit PIN_JIAN = P1^1;
  55. sbit PIN_SMG0 = P2^0;
  56. sbit PIN_SMG1 = P2^1;
  57. xdata unsigned char DAC0832DATA _at_ 0x7EFF;
  58. void main()
  59. {
  60.         unsigned char out, out1;
  61.         unsigned int v;
  62.         out = out1 = 0;
  63.         lcdint();//初始化液晶
  64.         wrc(0x80);
  65.         wrn(str);
  66.         while(1) {
  67.                 if(PIN_JIA == 0) {
  68.                         if(out < 0xFF) {
  69.                                 out++;
  70.                                 DAC0832DATA = out;
  71.                         }
  72.                         while(PIN_JIA == 0);                         //等待按鍵釋放
  73.                 } else if(PIN_JIAN == 0) {
  74.                         if(out > 0x00) {
  75.                                 out--;
  76.                                 DAC0832DATA = out;
  77.                         }
  78.                         while(PIN_JIAN == 0);                         //等待按鍵釋放
  79.                 }
  80. ……………………
  81. …………限于本文篇幅 余下代碼請從51黑下載附件…………
shukongdianyayuan.rar (60.05 KB, 下載次數: 91)
作者: 1205528173    時間: 2021-6-17 10:23
有沒有用數碼管的
