標(biāo)題: 單片機(jī)矩陣鍵盤讀取的仿真實(shí)驗(yàn) [打印本頁]
作者: 憂默HA    時間: 2018-6-20 17:06
程序搬運(yùn)工來了,只希望有少許幫助
  1. config.h源代碼
  2. #ifndef _CONFIG_H_
  3. #define _CONFIG_H_
  4. #include"reg52.h"
  5. typedef unsigned char INT8U;
  6. typedef signed         char INT8;
  7. typedef unsigned short INT16U;
  8. typedef signed         short INT16;
  9. typedef unsigned long INT32U;
  10. typedef signed         long INT32;
  11. typedef float FP32;
  12. typedef double FP64;
  13. #define        LED        P2
  14. #define KEY P1
  15. #endif
  16. main.c源代碼
  17. #include"config.h"
  18. #include"keyscan.h"
  19. #include"ParallelStaticCATLED.h"
  20. void main()
  21. {
  22.         INT8U KeyValue[1]={0x10};
  23.         while(1)
  24.         {
  25.                 KeyValue[0]=keyscan();
  26.                 if(KeyValue!=0x10)
  27.                 {
  28.                         LEDDisplay(KeyValue);
  29.                 }
  30.         }
  31. }
  32. ParallelStaticCATLED.c源代碼
  33. #include"config.h"
  34. INT8U code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  35. void LEDDisplay(INT8U *buffer)
  36. {
  37.         LED=tab[buffer[0]];
  38. }
  39. ParallelStaticCATLED.h源代碼
  40. #ifndef _ParallelStaticCATLED_H_
  41. #define _ParallelStaticCATLED_H_
  42.         void LEDDisplay(INT8U *buffer);
  43. #endif
  44. keyscan.c源代碼
  45. #include"config.h"
  46. #include"delay.h"
  47. INT8U keyscan()
  48. {
  49.         INT8U key_value=0x10;
  50.         INT8U temp,temp0,temp1,temp2,temp3;
  51.         KEY=0xf0;
  52.         temp=KEY&0xf0;
  53.         if(temp!=0xf0)
  54.         {
  55.                 KEY=0xf7;
  56.                 LongDelay(1250);
  57.                 temp0=KEY&0xf0;
  58.                 KEY=0xfb;
  59.                 LongDelay(1250);
  60.                 temp1=KEY&0xf0;
  61.                 KEY=0xfd;
  62.                 LongDelay(1250);
  63.                 temp2=KEY&0xf0;
  64.                 KEY=0xfe;
  65.                 LongDelay(1250);
  66.                 temp3=KEY&0xf0;
  67.                 KEY=0xf0;
  68.                 while((KEY&0xf0)!=0xf0);
  69.                 LongDelay(1250);
  70.                 while((KEY&0xf0)!=0xf0);
  71.         }
  72.         if(temp0!=0xf0)
  73.         {
  74.                 switch(temp0)
  75.                 {
  76.                         case 0xe0:
  77.                                 key_value=0x00;
  78.                                 break;
  79.                         case 0xd0:
  80.                                 key_value=0x04;
  81.                                 break;
  82.                         case 0xb0:
  83.                                 key_value=0x08;
  84.                                 break;
  85.                         case 0x70:
  86.                                 key_value=0x0c;
  87.                                 break;
  88.                         default:
  89.                                 break;
  90.                 }
  91.         }
  92.         if(temp1!=0xf0)
  93.         {
  94.                 switch(temp1)
  95.                 {
  96.                         case 0xe0:
  97.                                 key_value=0x01;
  98.                                 break;
  99.                         case 0xd0:
  100.                                 key_value=0x05;
  101.                                 break;
  102.                         case 0xb0:
  103.                                 key_value=0x09;
  104.                                 break;
  105.                         case 0x70:
  106.                                 key_value=0x0d;
  107.                                 break;
  108.                         default:
  109.                                 break;
  110.                 }
  111.         }
  112.         if(temp2!=0xf0)
  113.         {
  114.                 switch(temp2)
  115.                 {
  116.                         case 0xe0:
  117.                                 key_value=0x02;
  118.                                 break;
  119.                         case 0xd0:
  120.                                 key_value=0x06;
  121.                                 break;
  122.                         case 0xb0:
  123.                                 key_value=0x0a;
  124.                                 break;
  125.                         case 0x70:
  126.                                 key_value=0x0e;
  127.                                 break;
  128.                         default:
  129.                                 break;
  130.                 }
  131.         }
  132.         if(temp3!=0xf0)
  133.         {
  134.                 switch(temp3)
  135.                 {
  136.                         case 0xe0:
  137.                                 key_value=0x03;
  138.                                 break;
  139.                         case 0xd0:
  140.                                 key_value=0x07;
  141.                                 break;
  142.                         case 0xb0:
  143.                                 key_value=0x0b;
  144.                                 break;
  145.                         case 0x70:
  146.                                 key_value=0x0f;
  147.                                 break;
  148.                         default:
  149.                                 break;
  150.                 }
  151.         }
  152.         return(key_value);
  153. }
  154. keyscan.h源代碼
  155. #ifndef _KEYSCAN_H_
  156. #define _KEYSCAN_H_
  157.         INT8U keyscan();
  158. #endif
  159. delay.c源代碼
  160. #include"config.h"
  161. void LongDelay(INT16U i)
  162. {
  163.         while(--i);
  164. }
  165. delay.h源代碼
  166. #ifndef _DELAY_H_
  167. #define _DELAY_H_
  168. void LongDelay(INT16U i);
  169. #endif
全部資料51hei下載地址:
51hei.rar (32.31 KB, 下載次數(shù): 6)
