標題: arduino簡易時鐘 [打印本頁]
作者: chen456    時間: 2018-5-30 14:57
標題: arduino簡易時鐘
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY ch IS
PORT(clk: IN STD_LOGIC;
      q1: out INTEGER RANGE 0 TO 9;
      qt: out INTEGER RANGE 0 TO 6;
      co: OUT STD_LOGIC);
END ch;
ARCHITECTURE behav OF ch IS
signal q1a: INTEGER RANGE 0 TO 9;
signal qta: INTEGER RANGE 0 TO 6;
BEGIN
PROCESS(clk,q1a)
BEGIN
IF(clk'EVENT AND clk='1') THEN
  IF(q1a=9) THEN
    q1a<=0;
  ELSE
    q1a<=q1a+1;
  END IF;
  q1<=q1a;
END IF;
END PROCESS;
PROCESS(clk,q1a,qta)
BEGIN
  IF(q1a=9) THEN
    IF(qta=5) THEN
      qta<=0;
    ELSE
      qta<=qta+1;
    END IF;
    qt<=qta;
  END IF;
END IF;
END PROCESS;
PROCESS(clk, q1a, qta)
BEGIN
  IF(qta=5 AND q1a=9) THEN
    co<='1';
  ELSE
    co<='0';
  END IF;
END IF;
END PROCESS;
END behav;
