標題: 51單片機設計的頻率計仿真與源代碼 [打印本頁]
作者: zhuzhu@qq    時間: 2018-5-29 17:57
頻率計仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機頻率計源程序如下:
  1. #include<reg52.h>
  2. sbit LED=P1^7;
  3. sbit SW=P3^2;
  4. bit flag=0;
  5. bit CL = 0;
  6. unsigned int high = 0;         //計數器溢出的次數
  7. unsigned int low = 0;
  8. unsigned char cishu = 0;  //定時器溢出次數
  9. unsigned char ch[6];
  10. unsigned char code dsy_code[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  11. unsigned char num[6] = {0};         //存儲各個位的值
  12. void DelayMS (unsigned int x);
  13. void main()
  14. {
  15.                 unsigned char i;
  16.         EA = 1;
  17.                 EX0 = 1;
  18.         IT0=1;
  19.             ES = 1;          //開串口中斷
  20.             SCON = 0x50;  //方式1
  21.             PCON = 0x00;
  22.             TMOD = 0x21;  //定時器T1方式2
  23.             TH1 = 0xFD;
  24.             TL1 = 0xFD;         //波特率9600
  25.             TR0 = 1;
  26.                 ET0 = 1;
  27.                 TH0 = (65536 - 50000) / 256;
  28.                 TL0 = (65536 - 50000) % 256;   //設置T0為50ms溢出一次
  29.                 TCON = 0x50;   //同時開啟定時器T0和計數器T1
  30.                 while(1)
  31.                 {
  32.                         if(flag==1)
  33.                         {
  34.                                 for(i=0;i<6;i++)
  35.                                 {
  36.                                         P2 = 0x04<< i;
  37.                                         P0 = dsy_code[num[i]];
  38.                                         DelayMS(2);
  39.                                         ch[i]=num[i] + '0';
  40.                                         SBUF=ch[i];
  41.                                         while(!TI);
  42.                                         TI=0;
  43.                                 }
  44.                                 SBUF=' ';
  45.                                 while(!TI);
  46.                                 TI=0;
  47.                         }
  48.                   }
  49. }
  50. void Timer0() interrupt 1
  51. {
  52.         if(CL==1)
  53.         {
  54.                 cishu++;
  55. //                TH0 = (65536 - 50000) / 256;
  56. //                TL0 = (65536 - 50000) % 256;
  57.                 if(cishu == 20)
  58.                 {
  59.                         TCON = 0x00;   //暫停定時器,緩解CPU壓力,并不影響頻率值
  60.                         cishu = 0;
  61.                         num[0] = (high*256 + low)/ 100000 % 10;
  62.                         num[1] = (high*256 + low)/ 10000 % 10;
  63.                         num[2] = (high*256 + low)/ 1000 % 10;
  64.                         num[3] = (high*256 + low)/ 100 % 10;
  65.                         num[4] = (high*256 + low)/ 10% 10;
  66.                         num[5] = (high*256 + low)% 10;
  67.                         high = 0;
  68.                         low = 0;
  69.                         TH0 = (65536 - 50000) / 256;
  70.                         TL0 = (65536 - 50000) % 256;        //再重裝初值,保證計數時間為1秒
  71.                         TCON = 0x50;  //同時開啟定時器T0和計數器T1
  72.                         flag=1;
  73.                         LED=1;
  74.                 }
  75.         }
  76. }
  77. void Timer1() interrupt 0
  78. {
  79.         TF0=1;
  80.         low++;
  81.                 TH1 = 0xFD;
  82.             TL1 = 0xFD;         //波特率9600
  83.         if(low==256)
  84.         {
  85.                 high++;
  86. //                low=0;
  87.         }
  88.         TF0=0;
  89. //                if(high==256)high=0;
  90. }
  91. void InterruptUART () interrupt 4
  92. {
  93.         static unsigned char m;
  94.         if(RI)         //接受到字節(jié)
  95.         {
  96.                 RI=0;         //手動清零接收中斷標志位
  97.                 m=SBUF;  //接收的數據+1后發(fā)回,左邊是發(fā)送SBUF,右邊是接收SBUF
  98.                 if(m=='A')
  99.                 {
  100.                         CL=1;
  101.                         LED=0;
  102.                 }
  103.         }
  104. }
  105. void DelayMS (unsigned int x)
  106. {
  107.         unsigned int t;
  108.         while (x--)
  109.         {
  110.                 for(t=0;t<120;t++);
  111.         }
  112.
  113. }
頻率計.zip (70.3 KB, 下載次數: 24)
作者: ziba108    時間: 2018-6-14 21:37
缺少fangboxinhao.hex????
作者: mif    時間: 2018-7-2 16:22
多謝了大佬
