利用MATLAB識別1-9語音的源碼
matlabxmut
2018-5-22 22:16
利用MATLAB識別1-9語音的源碼
自己做的,識別1-9的語音。
(45.73 KB, 下載次數: 25)
2018-5-22 23:51 上傳
全部資料51hei下載地址:
MATLAB語音識別1-9.zip
(397.37 KB, 下載次數: 31)
2018-5-22 22:16 上傳
源碼:
function trimmedX = myVAD(x)
Ini = 0.1; %Initial silence duration in seconds
Ts = 0.01; %Frame width in seconds
Tsh = 0.005; %Frame shift in seconds
Fs = 16000; %Sampling Frequency
counter1 = 0;
counter2 = 0;
counter3 = 0;
counter4 = 0;
ZCRCountf = 0; %Stores forward count of crossing rate > IZCT
ZCRCountb = 0; %As above, for backward count
ZTh = 40; %Zero crossing comparison rate for threshold
w_sam = fix(Ts*Fs); %No of Samples/window
o_sam = fix(Tsh*Fs); %No of samples/overlap
lengthX = length(x);
segs = fix((lengthX-w_sam)/o_sam)+1; %Number of segments in speech signal
sil = fix((Ini-Ts)/Tsh)+1; %Number of segments in silent period
win = hamming(w_sam);
Limit = o_sam*(segs-1)+1; %Start index of last segment
FrmIndex = 1:o_sam:Limit; %Vector containing starting index
%for each segment
ZCR_Vector = zeros(1,segs); %Vector to hold zero crossing rate
%for all segments
%Below code computes and returns zero crossing rates for all segments in
%speech sample
for t = 1:segs
ZCRCounter = 0;
nextIndex = (t-1)*o_sam+1;
for r = nextIndex+1:(nextIndex+w_sam-1)
if (x(r) >= 0) && (x(r-1) >= 0)
elseif (x(r) >= 0) && (x(r-1) < 0)
ZCRCounter = ZCRCounter + 1;
elseif (x(r) < 0) && (x(r-1) < 0)
elseif (x(r) < 0) && (x(r-1) >= 0)
end
end
ZCR_Vector(t) = ZCRCounter;
end
%Below code computes and returns frame energy for all segments in speech
%sample
Erg_Vector = zeros(1,segs);
for u = 1:segs
nextIndex = (u-1)*o_sam+1;
Energy = x(nextIndex:nextIndex+w_sam-1).*win;
Erg_Vector(u) = sum(abs(Energy));
end
IMN = mean(Erg_Vector(1:sil)); %Mean silence energy (noise energy)
IMX = max(Erg_Vector); %Maximum energy for entire utterance
I1 = 0.03 * (IMX-IMN) + IMN; %I1 & I2 are Initial thresholds
I2 = 4 * IMN;
ITL = min(I1,I2); %Lower energy threshold
ITU = 5 * ITL; %Upper energy threshold
IZC = mean(ZCR_Vector(1:sil)); %mean zero crossing rate for silence region
stdev = std(ZCR_Vector(1:sil)); %standard deviation of crossing rate for
%silence region
IZCT = min(ZTh,IZC+2*stdev); %Zero crossing rate threshold
indexi = zeros(1,lengthX); %Four single-row vectors are created
indexj = indexi; %in these lines to facilitate computation below
indexk = indexi;
indexl = indexi;
%Search forward for frame with energy greater than ITU
for i = 1:length(Erg_Vector)
if (Erg_Vector(i) > ITU)
counter1 = counter1 + 1;
indexi(counter1) = i;
end
end
ITUs = indexi(1);
%Search further forward for frame with energy greater than ITL
for j = ITUs:-1:1
if (Erg_Vector(j) < ITL)
counter2 = counter2 + 1;
indexj(counter2) = j;
end
end
start = indexj(1)+1;
Erg_Vectorf = fliplr(Erg_Vector);%Flips round the energy vector
%This is equivalent to searching backward from last sample for energy > ITU
for k = 1:length(Erg_Vectorf)
if (Erg_Vectorf(k) > ITU)
counter3 = counter3 + 1;
indexk(counter3) = k;
end
end
ITUf = indexk(1);
for l = ITUf:-1:1
if (Erg_Vectorf(l) < ITL)
counter4 = counter4 + 1;
indexl(counter4) = l;
end
end
finish = length(Erg_Vector)-indexl(1)+1;%Tentative finish index
%Search back from start index for crossing rates higher than IZCT
BackSearch = min(start,25);
for m = start:-1:start-BackSearch+1
rate = ZCR_Vector(m);
if rate > IZCT
ZCRCountb = ZCRCountb + 1;
realstart = m;
end
end
if ZCRCountb > 3
start = realstart; %If IZCT is exceeded in more than 3 frames
%set start to last index where IZCT is exceeded
end
%Search forward from finish index for crossing rates higher than IZCT
FwdSearch = min(length(Erg_Vector)-finish,25);
for n = finish+1:finish+FwdSearch
rate = ZCR_Vector(n);
if rate > IZCT
ZCRCountf = ZCRCountf + 1;
realfinish = n;
end
end
if ZCRCountf > 3
finish = realfinish; %If IZCT is exceeded in more than 3 frames
%set finish to last index where IZCT is
%exceeded
end
x_start = FrmIndex(start); %actual sample index for frame 'start'
x_finish = FrmIndex(finish-1); %actual sample index for frame 'finish'
trimmedX = x(x_start:x_finish); %Trim speech sample by start and finish
%indices
792403245
2018-11-25 20:13
為啥我識別不出來....
