標題: 求救!!數碼管顯示AD值 [打印本頁]
作者: schwarzenggar    時間: 2011-9-24 16:06
標題: 求救!!數碼管顯示AD值
高手們大俠們父老鄉親們都來看看程序吧   在用3位數碼管顯示連續變化的AD值,我寫的程序怎么就是實現不了啊,求救。
#include<reg51.h>
sbit oe=P1^0;
sbit eoc=P1^1;
sbit st=P1^2;
sbit clk=P1^3;
sbit led2=P2^1;
sbit led3=P2^2;
sbit led4=P2^3;
  int ad_out;
  int div_buf;
  int div[2]; //16????×a10????μ?3??°???ê?3?£?ò2ê?LEDμ??o′?ê?3?
  int xdata *DPTR;
void timer(void) interrupt 1 using 0
 clk=!clk;
void delay(uchar z)
 int i;
 for(i=0;i<=z;i++);
led()
 switch(div_buf)
   case 0: return(0xc0); break; //êy??1ü12??
   case 1: return(0xf9); break;
   case 2: return(0xa4); break;
   case 3: return(0xb0); break;
   case 4: return(0x99); break;
   case 5: return(0x92); break;
   case 6: return(0x82); break;
   case 7: return(0xf8); break;
   case 8: return(0x80); break;
   case 9: return(0x90); break;
void output()
  led2=1;led3=0;led4=0; //μú2??êy??1ü
  div_buf=div[0];
  P0=led();
  delay(123);
  led2=0;led3=1;led4=0;//μú3??êy??1ü
  div_buf=div[1];
  P0=led();
  delay(123);
  led2=0;led3=0;led4=1;//μú4??êy??1ü
  div_buf=div[2];
  P0=led();
  delay(123);
  led2=1;led3=1;led4=1;
  delay(1230000);
void main(void)
   int num=0,j=1;
    TMOD=0x02;//T0·?ê?2
    TH0=0xff;
 TL0=0xff;
    TR0=1;
 EA=1;
 ET0=1;
    DPTR=0x0000;
 *DPTR=0x00;
    delay(123);
    st=1;
 st=0;
 st=1;
 while(eoc==1);//μè′y×a??
 oe=1;
 ad_out=P3;
    oe=0;
      div[0]=ad_out/100;
      div[1]=ad_out%100/10;
      div[2]=ad_out%10;
    output();
用PTOYUSE仿真的電路已經上傳,麻煩高手指點迷津吧!謝過!!!!!!!
原理圖.rar (95.02 KB, 下載次數: 22)
作者: l834492956    時間: 2011-9-25 13:41
找單片機項目開發/代做單片機類畢設。我QQ:834492956
